Factory cargo divider?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Effenglide, Mar 26, 2015.
  1. Mar 26, 2015 at 5:34 PM
    Effenglide
    Effenglide [OP] Well-Known Member
    Effen
    Montana
    2015 TRD Sport DCLB
    Here we go again!
    Is this useful? I have a chance to pick one up for hall price but can't decide if it would be useful. I've only owned my truck for a month.
  2. Mar 26, 2015 at 5:45 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Ehh, not really. Maybe if you haul alot of groceries in your bed. The second Tacoma i owned came with one in it. I had bought the truck from a real old man. First thing i did was take it out. It sat in my garage for years. I don't even remember what happened to it. I guess they have their place.
  3. Mar 26, 2015 at 5:46 PM
    Flynbyu2
    Flynbyu2 Start every day with a smile and get it over with
    Ron
    Folsom, CA
    '10 Tacoma Sport
    Had my truck almost two years now. I have the bed extender accessory which is WAY more useful in my opinion.
  4. Mar 26, 2015 at 6:00 PM
    Effenglide
    Effen
    Montana
    2015 TRD Sport DCLB
    Here we go again!
    Thanks for saving me money. I owe you both a beer.
  5. Mar 26, 2015 at 6:03 PM
    reece13
    North Carolina
  6. Mar 26, 2015 at 6:20 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    They are good for keeping small loose items from moving around the bed, but can be a hassle if you need the bed's full length and need to remove it on short notice.
    I have found mine useful at times, but at other times it gets in the way.
  7. Mar 26, 2015 at 7:06 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    i like mine.
  8. Mar 26, 2015 at 7:14 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    My current bed setup.
  9. Mar 27, 2015 at 12:05 PM
    TakoJim
    TakoJim Well-Known Member
    Chula Vista, Cali
    2015 PreRunner Limited
    TRD STICKER ON BEDSIDE
    They are nice if it can be swing up, like put a hinges.
  10. Mar 27, 2015 at 2:37 PM
    Hilborn
    Michael
    Utah
    Not hinged, but if you unscrew and pop it out easily like I have mine set up to do.
