Factory cover issues....?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kw18, Nov 1, 2019.
  1. Nov 1, 2019 at 8:31 PM
    Kw18
    Kw18 [OP] Member
    Keith
    2019 taco
    So I have a 2019 Sport with factory tri fold hard cover. My wife and I have our cleaning equipment in the bed and recently found out that the cover leaks. Has anyone else have this happen to them? My dealership is starting a claim on this issue and hope to get a credit for a different one. What other brand/style is worth its money?
  2. Nov 1, 2019 at 8:41 PM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    Mine lets a little water in. Anything I want to keep dry is kept in 5 gallon buckets with the screw top lids.
  3. Nov 1, 2019 at 8:45 PM
    duckytw
    duckytw Well-Known Member
    Make sure you latch it down tight. You might have a little water run in but not much.
  4. Nov 1, 2019 at 9:16 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    climb in the bed on a sunny day and look for light entry points. Adjust the lid or add a small bead of black rubber silicone to the needed area. Also, close the tailgate then close the lid in order to minimize water entry
  5. Nov 2, 2019 at 6:25 AM
    BlackTRD4Me
    BlackTRD4Me Well-Known Member
    Sean
    2017 Toyota Tacoma Off Road
    Bull bar with lights, Wheels on stock tires, window vents.
    Did they tell you it was water proof? I think they all leak and I don't think they are meant to be water proof.
  6. Nov 2, 2019 at 6:30 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    They do, some more than others. My local truck accessories place, that outfits my work trucks, actually has their customers sign a sheet stating this, before they charge/order/install. He said until they started that, large portion were under the assumption they were watertight and bringing them back in.
  7. Nov 2, 2019 at 6:35 AM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    I have a Gator cover on mine and it works well. It leaks a little bit if it's raining really hard, but like @MidCitiesMildMan anything I don't want together we I keep in plastic bins.
  8. Nov 2, 2019 at 7:02 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    I have an Undercover Flex hard trifold. It's a great tonneau cover but still lets in a little water. I have a Bed Rug so any moisture that gets in is under the rug and helps keep stuff dry.
  9. Nov 2, 2019 at 7:41 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Get inside and look for where you see light .You can seal areas with foam weather striping with adhesive on one side .
    MannyS likes this.
  10. Nov 2, 2019 at 7:49 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Mine leaks big time. Have tried just about everything there is to help stop. I just keep everything in totes now.
  11. Nov 2, 2019 at 9:52 AM
    creedbratton
    creedbratton Well-Known Member
    2019 White Tacoma TRD Sport 6MT
    I've never seen a tonneau cover that doesn't leak at least a little.
    BlackTRD4Me and Chew like this.
  12. Nov 2, 2019 at 9:58 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Mine never leaks. I have it in the garage but park outside all day m-f. Never seen but a couple drops from when I open the tailgate.
  13. Nov 2, 2019 at 10:10 AM
    iamjase
    iamjase Well-Known Member
    Jase
    Maryland
    2023 Tacoma TRD Pro Solar Octane
    I have some water coming in on the sides but near the middle is dry. I did have to take mine completely off and place it back on as it wasn't fully snapped in near the rear windows. You can take it off and back on alone but much easier with a second person.
