Factory Denso 180 Amp Alternator upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Mar 14, 2019.
  1. Mar 16, 2019 at 11:15 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    :popcorn: how'd she work?
  2. Mar 16, 2019 at 11:37 AM
    svdude
    svdude Well-Known Member
    jonathan
    Why wouldn't it charge the battery faster? More amps means a higher flow of electrons to the battery, is there a regulator between the alternator and battery that limits over frequency (high current)?
  3. Mar 16, 2019 at 11:45 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I can think of 68 mods I do before this one but if you really need it I guess it bumps it up the list.
    CB350G and Joe23 like this.
  4. Mar 16, 2019 at 11:52 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Is the 3rd gen towing package 130amp alternator the same as the second gen towing package 130amp one?
  5. Mar 16, 2019 at 11:59 AM
    svdude
    jonathan
    But voltage isn't the only factor. Amperage is the basically the rate at which the volts flow (Coulomb's/seconds). Since there is a higher amperage the 14.8(ish) volts are moving faster to the battery.
  6. Mar 16, 2019 at 12:04 PM
    TireFire
    Olympic Peninsula
    True for 2nd gens but they downsized the battery to 24f in 3rd gens. Even those w towing package
    shakerhood likes this.
  7. Mar 16, 2019 at 12:12 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I had not one but (2) Mean Green alternators fail on my Jeep in a matter of 3 years. Wont make that mistake again!
  8. Mar 16, 2019 at 12:46 PM
    TireFire
    Olympic Peninsula
    Another thing to keep in mind is that max alternator output isn’t as important as what it can put out at idle and cruising speed.
    Joe23 and BigWhiteTRD like this.
  9. Mar 16, 2019 at 12:51 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    So the OEM voltage regulates it to max 14.4V? This has been a big question whether the stock alternator will fully charge an AGM battery to 14.8V.
    Whichever the case, I’ve been putting my AGM on a 7 cycle 14.8V charger every few weeks.
  10. Mar 16, 2019 at 1:08 PM
    TireFire
    Olympic Peninsula
    I do the same. Someone mentioned in here a mod to change a diode to increase voltage. Curious about that... @moe2o4 was that you?
  11. Mar 16, 2019 at 1:08 PM
    TireFire
    Olympic Peninsula
    Sorry quotes wrong guy above @Joe23
  12. Mar 16, 2019 at 1:08 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    How does one set the alternator to charge an agm battery?
  13. Mar 16, 2019 at 1:25 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    so if I understand, if i go from a flooded lead-acid battery to AGM battery, I need to change a setting on my voltage regulator......if so, how would i do that?
  14. Mar 16, 2019 at 1:28 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    I remember Mat @OVTune saying he could adjusts the alternator output in the ecu.
    uploadadventure likes this.
  15. Mar 16, 2019 at 1:40 PM
    #35
    r1200gs4ok
    O. K.
    Irvine, Ca
    thanks.....from the discussions, it sounded like you knew what you were talking about for the Tacoma since this is a truck forum....not a boat forum.....thanks anyway ....i was just confused
  16. Mar 16, 2019 at 2:21 PM
    #36
    svdude
    jonathan
    I just did a little reading on car batteries. Basically what I got was that a car battery is a high output battery so in return it's also a high input, meaning it can also charge with a higher current which will charge it faster. If what I'm understanding is correct, then why won't a higher amperage alternator charge a battery faster? A higher rate of electron flow will fill the battery faster.
  17. Mar 16, 2019 at 3:00 PM
    #37
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    The battery can only intake so many charging amps. It is a percentage of the batteries amp hours and level of charge.
  18. Mar 16, 2019 at 3:17 PM
    #38
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Ya that was me .I bought it when I did dual battery as one of my friends has it . But turns out 3rd Gen doesn't have that same fuse so it doesn't work on 3rd Gen
    It was this
    https://www.hkbelect.com
    And then there was a thread somewhere on here that transferred over from a tuner forum for sounds systems was for a new harness for the alternator that did the same thing.
    But again 3rd Gen has something else and it doesn't work.
    For what it's worth its only in the summer I only get 13.7V
    And I have two North Star group 27. Haven't had any issues . And I have a ctek charger I hook up if I really need it .But haven't yet.
    I just plugged in to the second battery when I was at my girlfriend's trailer for a long weekend and needed extra fridge space.
    So I had my arb and just plugged in since I knew the truck wouldn't really be getting started for 4 days.
    I'm yet to have either battery go flat on me.
  19. Mar 16, 2019 at 3:18 PM
    #39
    Joe23
    Depends on the type of battery.
    And a slow charge is actually better for batteries health
  20. Mar 22, 2019 at 3:47 PM
    #40
    Jowett
    Brian
    North Adams, MA
    No, the Land Cruiser uses a different 4 pin connector, and mounts to the block in a totally different fashion. The rectifier on the LC unit also appears to have vastly more cooling capacity. Has me wondering what else may be different/better.
    mcharfauros likes this.
