Factory Denso 180 Amp Alternator upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Mar 14, 2019.
  1. Jan 31, 2022 at 1:55 PM
    #61
    awesomeandy013
    awesomeandy013 Well-Known Member
    Andrew
    Pittsburgh, PA
    '17 MGM DCLB TRD OR, '16 TRD Pro 4RNR QS (wife)
    265/75R16 Wildpeak AT3W, Softopper, Kicker speakers, shift knob, Ventvisors, Tint, Husky Weatherbeaters, Hondo Garage radio knobs. The to do list: Bilstein 6112/5160, 3 leaf add-a-leafs, lights, alu skid, PRP seat covers...
    @Jowett This mod still working out? Anything odd since install?
  2. Jan 31, 2022 at 2:11 PM
    #62
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    I have yet to run this in the truck... it's been in the barn for 2 years. It does bolt up, the side connector needs to be modified so it won't contact the frame during hard hits. I hope to get some things completed this spring.
    JManning1423 and awesomeandy013 like this.
  3. Mar 10, 2022 at 10:48 PM
    #63
    Roberto Paulson
    Roberto Paulson 2017 Tacoma SR5 number 1 bazillion
    2017 V6 SR5 4WD With tow package
    HID bulb kit, metal oil filter cover, modded or mostly sealed rear side storage bins, 265 75 r16 Michelin defenders
    To go to the 130 amp, first check your Alt fuse in the fuse box. On a Tacoma with tow package, the Alt fuse is 140 amps. If you blow that fuse, your Taco is dead in the street.
    To replace that fuse, you have to disassemble the fuse box, because that fuse is bolted to the conductors coming from the alternator, and going to the battery. If you go beyond 140 amps, you need to run a separately fused or on-line circuit breaker 0 cable from the alternator to the battery. In fact, you'll need to do a big 3 wire upgrade.
  4. Mar 11, 2022 at 7:39 AM
    #64
    Jowett
    Brian
    North Adams, MA
    Roberto, a big thanks for pointing out these very basic but required mods! I get so wrapped up in the basic physical bolting in part of the swap, that mentioning these very necessary requirements were neglected.
    Roberto Paulson likes this.
  5. Mar 11, 2022 at 9:28 AM
    #65
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    Thanks for the heads up on that fuse. I got the "big 7" wire upgrade that I have yet to install.
  6. Aug 10, 2023 at 11:39 AM
    #66
    Strekcorp
    Strekcorp Member
    Texas
    2019 Voodoo TRD Pro
    Magnuson TVS 1900
    I understand this is an old thread, but did anyone get around to trying this out and running it? I spoke to Tony at mechman and asked why they were not producing an option for the third gen. He seemed concerned that any alternator that makes greater power than the factory option (for third gen) would essentially not be recognized by the LINBUS/CANBUS system. You would have the power on hand but no way to access it without bypassing the fusebox with a single wire turn on alternator, but that there is a high probability that you will start getting erratic behavior from the ECU and start throwing charging codes, or maybe even lose function of other systems despite power being available.
    I am just a hobbyist, and am learning as I am going, so does this make sense? Or would (as Roberto mentioned above) you just need to run an additional power wire from the alternator to the battery and the additional charge would self distribute (maybe wire in some kind of resistor)?
    Alternatively, is this second wiring path (alternator direct to fusebox) just in case your draw is greater than the 140 amp fuse, you blow the fuse and have the ability to continue to charge the battery?
    NoOne likes this.
