Factory diff gears?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeff6001, Aug 2, 2009.
  1. Aug 2, 2009 at 9:11 PM
    jeff6001
    jeff6001 [OP] Well-Known Member
    San Antonio, TX
    99 trd prerunner
    Wondering if anybody can help me find out what size of factory diff gears are in my 99 trd/AT tacoma? I am guessing 4:10 but wanted to know when I throw on some 35's. Thanks
  2. Aug 2, 2009 at 9:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You should have an axel code on the door jamb. It will be a "B" followed by 2 numbers, then an "A", "B", or "C".
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
  3. Aug 3, 2009 at 4:54 AM
    JVTACOMA
    JVTACOMA Well-Known Member
    i could be wrong but think all 1st gen TRD taco's came with 4:10's. As chris said above, double check the codes on the jamb
  4. Aug 3, 2009 at 6:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. They came with alot of different gear options. Mine had 4:30's. :)
  5. Aug 3, 2009 at 8:00 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    x2 remember JVtacoma, mine also had 4.30s
  6. Aug 4, 2009 at 8:24 PM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    Thanks for the help. Will check as soon as i get out of work.
