Factory Exhaust Pipe Question
Discussion in 'Performance and Tuning' started by speddmn, Aug 30, 2013.
  1. Aug 30, 2013 at 7:23 AM
    speddmn
    speddmn [OP] Well-Known Member
    Omaha
    TACOCAT
    Basics
    I searched but I think i'm probably using terms that are far too generic - can someone tell me the diameter of the factory exhaust on a V6?
    I have a 2013 DCSB 4.0 4x4
    (also, is it stainless?)
    Thanks!
  2. Aug 30, 2013 at 8:20 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I can't say for certain... but I believe that it's the same as the 2.7 exhaust which has an outside diameter of 2 3/8 inches. I found this out when I had purchased a muffler that fits 2 1/4" pipe and the ends needed to be swedged out to 2 3/8" to slip fit over the pipes. The system is definitely not stainless and is most likely made of aluminized steel.
  3. Aug 30, 2013 at 8:37 AM
    speddmn
    Omaha
    TACOCAT
    Basics
    Thanks for the detailed response dude!
  4. Aug 31, 2013 at 2:28 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    May not matter here, but I can almost guarantee it's stainless steel. Probably a low grade like 409 which is magnetic and will rust and welds easily, but way outlasts bare or aluminized steel.
  5. Aug 31, 2013 at 4:42 PM
    tooter
    Greg
    Los Angeles
    You may be right...
    ...it just sounds funny to read that it's stainless steel...
    ...except that it's magnetic and it rusts. ;)
    Greg
  6. Aug 31, 2013 at 5:56 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors
    I spoke with m welder friend today about picking up 2 feet of tubing and hangers for my exhaust mod / install.
    He said the tubes are 409.
    PK
  7. Aug 31, 2013 at 9:47 PM
    tooter
    Greg
    Los Angeles
    Hey, I'm glad that it's not just plain steel because I want my stock exhaust system to last. It's quiet and doesn't lose low end torque. :)
    I tend to think of stainless steel as more like this...
    .[​IMG]
  8. Sep 2, 2013 at 7:45 AM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    The pretty stuff is higher grade and polished. The cheap stuff could probably be polished, but a crapload of work. I believe all automotive exhausts have been stainless for decades. The oxygenated fuels and emission controls have accelerated corrosion on the exhaust greatly compared to the good ole days. The factory exhaust will last pretty much forever even tho is looks to be rusty.
  9. Sep 2, 2013 at 10:42 AM
    tooter
    Greg
    Los Angeles
    Thanks for the useful information. I'm really happy to hear that because it's good to have materials that last, especially in an exhaust system. :thumbsup:
  10. Sep 3, 2013 at 6:36 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The older gen IIs are 2.25 pipes, but I've "heard" that the newer model years are now 2.5. Not sure on when the switch occurred, but would suspect your '13 is 2.5.
