factory flares
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeezy, Apr 22, 2011.
  1. Apr 22, 2011 at 7:01 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    does anyone know how to remove the factory fender flares?
  2. Apr 22, 2011 at 7:03 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    undo the screws underneath and pop them off. be careful though as the clips that hold them into the body are very easy to break.
  3. Apr 22, 2011 at 7:09 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    they just sit right underneath the flares?
  4. Apr 22, 2011 at 7:50 AM
    jhodge83
    SC
    17 XLT Sport
    the clips connect the flare to the body. they are attached in the holes in the body and the flare is pushed onto them to hold. there are 2 different colors of clips, so if you break any, make sure you get the right ones again.
  5. Apr 22, 2011 at 2:15 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Use a putty knife, might tape the edge off so you don't scratch and after undoing the bottom bolts just pop it off with the putty knife. You'll probably break the clips. I broke all but a couple on both sides so I plan on heading down to the dealership and just buying new ones.
