Factory Fog Circuit Not Factory Lighting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by erok81, Jan 19, 2017.
  1. Jan 19, 2017 at 9:36 PM
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    Has anyone utilized the factory switch and most of the circuit in a 2016-2017?
    I don't need the fog lights and want to wire my lights using the factory switch and the dash light for fogs.
    I have a relay in the aftermarket light and can easily cut and splice the power from the stock switch. But I want to see if anyone else has done this.
    I'm not interested so much on older Tacomas. These newer ones seem to get jacked up when you mess with any of the factory wiring - see LED headlights or LED interior lights.
    Note: I'm not using any of the out of cab wiring for the lights. That's all aftermarket and hooked to the battery. I'm only interested in the stock switch and dash light.
  2. Jan 20, 2017 at 9:12 AM
    erok81
    Imposter
    Anyone? Does what I'm saying make sense?
  3. Jan 20, 2017 at 12:01 PM
    erok81
    Imposter
    So I was confused. For some reason I thought the fogs were on a push button. They aren't. It's on the indicator stalk. After briefly thinking about tearing apart the column to find the wire, I figured why not power the relay from the actual fog pigtail. Since that powers the fogs I don't see why I can't power a relay.
  4. Jan 20, 2017 at 12:08 PM
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
  5. Jan 20, 2017 at 12:21 PM
    erok81
    Imposter
    I have aftermarket lights and have removed my stock fogs. So I want to utilize the factory fog switch (and dash light) to operate my new aftermarket lights.
    That link helped though. I remembered one thing I didn't like about them. The fogs turn off with the high beams.
    So I either need to get over that hurdle so they stay on. Or just stick with the switch I have now.
  6. Jan 21, 2017 at 11:46 AM
    ExplorHer
    Near Pittsburgh
    I think there is a thread on here for that as well, but it doesn't interest me so I don't have a link to it.
    Kilokato and Herniator like this.
  7. Jan 21, 2017 at 1:50 PM
    erok81
    Imposter
    I've looked and found a couple. Seems too involved (unlike the 2nd mod). I figure these lights are so bright having my brights on at the same time probably won't make a difference.
