Factory Fog Lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EvilBetty, Jun 5, 2007.
  1. May 29, 2008 at 8:54 PM
    p38
    p38 Member
    wow thats all sounds great with the acception of $350 for fog lights.
    thanks for the post
  2. Jul 14, 2008 at 5:18 AM
    darnett41
    darnett41 New Member
    nashville,tn
    06 tacoma
    i purchased a set of the bling lights off ebay and when they arrived i called mark at bling lights and requested my money back, i thought they were junk. i much rather have OEM lights
    thats just me.
    david
  3. May 31, 2009 at 1:57 PM
    lightfoot21
    lightfoot21 Member
    Rhode Island
    2009 Tacoma access cab
    just side runners looking for interior overhead console for temp gauge
    Hello taco Friends, I have the 2009 Access cab, 4x4 that I just installed the bug deflector, Aries Bull bar and nasta Nerf bars to. I would like to get the fog lights but there are no wires under the fender, I also wish to do the intermittent wipers and need some wheels, wheel covers ideas.
    If anyone can help me, I am a disaster with electricity though.
    Any info/help from my Taco friends would be greatly appreciated.
    Those Toyo dealers are real ball breakers when it comes to info. updates, etc
    thanks, Rich:)
  4. May 31, 2009 at 6:50 PM
    lightfoot21
    lightfoot21 Member
    Rhode Island
    If the lights do not come with the wiring harnesses and the factory did not place the wires under the fender, how do I wire the new foglights?:eek:
  5. May 31, 2009 at 7:05 PM
    L_Jackson
    L_Jackson Well-Known Member
    Houston, TX
    2007 Black Sand Pearl PreRunner Acce
    Tinted Windows, Tow Hitch, 3" Toytec Lift, American Racing Outlaw II Wheels, Cooper Discoverer 33's, Aries Bull Bar w/ (2) 5" Lights, Nerf Bars, Fog Lights as DTR Lights, Roll Bar w/ (4) 5" Lights, Sony Speakers, 2 Extra Tie Downs
    look really close behind the bumper and up behind the grill. someone told me that a lot of times on trucks that don't come with fog lights, they will have some wiring pre ran and just "dangling" or tied up back there. i think i found some when i did mine, been a while so i don't remember, but i think it that is the case. if not, you'll have to run the wire yourself.
  6. May 31, 2009 at 7:58 PM
    BigT
    BigT Active Member
    Pa.
    16 trd off road
    I have an 05 tacoma I4 with sr5 package ,and I too wanted fog lights, but refused to $400.00+ for factory fogs. After much research on the net and many forums, including this one, I found the perfect solution to my problem. I purchased a fog light kit on ebay from "gummysource". The kit includes the fog light housings which snap in perfectly to the factory mounting points, the bulbs, wire harness , including relay,and a switch all for a little over $200. The only drawbacks were: instructions not very detailed, and switch wasn't factory, however, my 17 yr. old nephew helped me install them, and I can live with the lighted rocker switch that comes with them. I have had them installed for a month or so now, with no problems, and they definitely cut through the fog.:D
  7. Jun 1, 2009 at 9:24 AM
    sonjason
    sonjason Pink Taco Lover
    Western NC
    85 Turbo Diesel 4x4 Yota
    Got pics?
  8. Jun 1, 2009 at 9:24 AM
    sonjason
    Western NC
    I did the same thing... those didn't even come close to fitting the factory hole.
  9. Jun 1, 2009 at 9:27 AM
    sonjason
    Western NC
    All:
    Please see link below for how to install OEM fogs on a truck with no wiring.
    http://www.toyotapart.com/FogLights.html
    Regardless what your actual light is, the same steps should apply to wiring them.
  10. Jun 1, 2009 at 10:00 AM
    lightfoot21
    lightfoot21 Member
    Rhode Island
    looks like duck soup but its the wiring that will get me in trouble as I am not an electrical genius by no means.........QUACK!
    aLSO, hoping I can get an answer on keyless entry.new truck, need key to open door, do I check with dealer to see if there is a chip for the keyless and then just acquire the remote........ARGH. TACO MODS ARE A PAIN IN THE A$$
    BUT FUN.
    Rich
  11. Jun 1, 2009 at 10:52 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You can always just order one of these from ebay & get the factory dash switch seperately. The one with the kit does not fit our dash correctly. You can get yellow or clear & the lights use existing mounting spots just like the factory ones. Lights themselves are identical. Comes with the harness/relay. Just wire it up to the factory switch is what I did........
    http://cgi.ebay.com/ebaymotors/05-0...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
  12. Jun 1, 2009 at 12:48 PM
    sonjason
    Western NC
    Are the lights shown in the link above the same ones I see on your truck in your picture gallery?
  13. Jun 1, 2009 at 11:00 PM
    BigT
    BigT Active Member
    Pa.
    16 trd off road
    ;)I will take some pics and try to post them.
  14. Jun 2, 2009 at 4:08 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The yellow ones in my gallery are the ebay ones. The clear ones are oem that I traded for. They fit exactly the same & they plug in the same exact way. Physically the only thing that is micro different is the little heat vent on the back of them which doesn't matter at all. Quality was no different, both weigh the same & are made of same materials.
  15. Nov 10, 2009 at 10:58 AM
    #35
    Gronk
    Gronk Member
    07 TACOMA TRD SR5
    I have an 07 SR5 with Factory Fogs, and factory switch 84160-04010, I purchased another switch but without female plug. I know I'm brain dead when it comes to electical but can anybody help me out to get these things wired up. I have a Piaa Relay and lights etc.. and have run four wires through the dash and to where the lights will mount on a brush bar. I checked out the Hella Fog lamp schematic but I get lost on where the the purple combines and becomes green to the LH Parking Lamp.... Please help, alreay bald.
  16. Nov 10, 2009 at 11:49 AM
    #36
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Welcome aboard. It may be easier to get the connector & 4 pigtails wires that clip into the connector you need to hook up to your oem switch from the dealer. Then splice/solder the wires to the sw pigtails. That is what I did to get the oem switch hooked to aftermarket harness that came with the fog lights. I'm sure there are some wiring pics/diagrams in the lighting section that should help out. Just wire them to the relay & rest of things just like in the how-tos in the lighting section. Just look around in that section & you'll run into what you need.
  17. Nov 10, 2009 at 1:10 PM
    #37
    Gronk
    Gronk Member
    07 TACOMA TRD SR5
    Thanks much for responding. I ordered the connector $3.86 and the wires $5.98/ea and their all the same color so in a way even after I get them I will be back to square one trying to wire it. I'm kind of simple I guess but how do the wires run? I looked at a schematic but it seemed a bit gray to me. I was looking at the Hella posting. I know the #2 from the top goes to the 86 post on the relay, and #4 goes to a ground, 1 and 3 are the ones that have me a bit confused.
  18. Nov 10, 2009 at 2:42 PM
    #38
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    #38
  19. Jan 10, 2010 at 9:50 AM
    #39
    2010prerunner
    2010prerunner Member
    Paul
    New York
    2010 PreRunner 5spd. SR5
    A simple way to check for factory wired fog lights is in the underhood relay/fuse box. If there are metal receptor clips in the slots where the fog relay plugs into, you're likely pre-wired.
  20. Jan 10, 2010 at 11:30 AM
    #40
    drmadron
    drmadron Member
    don
    md
    2010 toyota tacoma
    how about the relay did you buy that
