factory fog switch for Hella Black Magic Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krusey1011, Sep 11, 2009.
  1. Sep 11, 2009 at 2:12 AM
    Krusey1011
    Krusey1011 [OP] Well-Known Member
    Kyle
    Washington
    So I installed my dual Hella Black Magic behind the grill headlights and I ordered the factory fog light switch from the stealership for a factory look. Only thing is, it's a 4 prong switch that requires a plug on the back side that it didn't come with. For my 3 wires. The guy at the stealership told me he could only find it where I purchase the entire harness and wiring with the plug. I could use some other switch but I already paid $70 bucks for this one. (dumb idea!) oh well it's already done. So I looked around and found some similar threads but nothing that helps. IDK maybe I'll just keep the cheap-o-switch I got and waste the $70 bucks. It Don't look bad. I want to move on to bigger and better mods! hahah So if anyone knows, please drop some info. Otherwise F it! Some other time.:pout:
  2. Sep 11, 2009 at 3:21 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    found thses numbers on toyota nation:
    Toyota Connector Housing (90980-11090)
    Terminal Wires for Connector (82998-12340 4 required)
    four wires and the plastic connector that plugs into the back of the switch. insert wires into plastic piece, plug into fog light switch.
  3. Sep 11, 2009 at 3:25 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Probably gonna need this info for my ebay fogs to factory switch hookup. Good info! Rep for u.........
  4. Sep 11, 2009 at 3:26 AM
    Krusey1011
    Kyle
    Washington
    Yeah I seen that here on TW and I think it's the same thing the dealer had but I never gave it a chance. I'll check it out n see if it will do the trick. Thanks for the effort! NE and every bit helps
  5. Sep 11, 2009 at 3:36 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Termainal Wires for Connector (82998-12340 4 required)
  6. Sep 11, 2009 at 3:40 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    OK, rep for u too...because you live in HI
  7. Sep 11, 2009 at 7:34 AM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Just to tick you off, the OEM light switch is U$25 on Ebay.
    There are 4 terminals on the switch. Two are for the backlight, the other two are for the actual switching. A multimeter will let you figure out which terminals do what.
    In my install I didn't bother with a factory connector. I soldered two wires with plugs on the two on/off metal traces of the switch. Didn't bother with backlight.
    Fritz
  8. Sep 11, 2009 at 10:57 AM
    RCBS
    thanks! glad to help when i can.
  9. Sep 11, 2009 at 11:27 AM
    Snyperx
    Snyperx Seniore Marcos
    It's funny this thread came up. I don't have a link at the moment, but I think a bunch of guys over on the FJC forums had this discussion. I think someone ended up finding a switch just like the factory one, but with only 3 standard prongs. I think they ordered from Allied electronics or Digikey. Something like that. In any case it was way cheaper than buying a factory button and special harness.
  10. Sep 11, 2009 at 2:17 PM
    Krusey1011
    Kyle
    Washington
    Yeah, I seen this. Live n learn. I'm sure I could have found a better switch tho too.
  11. Sep 12, 2009 at 1:11 PM
    Krusey1011
    Kyle
    Washington
    Took that part # to the stealership and it turned out to be a single terminal wire. That's it! So, I'm just going to solder the wires onto the switch. :D
  12. Sep 12, 2009 at 2:08 PM
    Snyperx
    Huh? I just and I mean just got back from the dealership picking up the switches using the part number provided in this thread and the two switches I got are both three terminal switches. Not sure what your dealership ordered you or did you order the push button?
  13. Sep 12, 2009 at 2:30 PM
    Krusey1011
    Kyle
    Washington
    Yeah, I got the push button. Same as the fog light push button switch. IDK Why the came up with just a terminal wire. I used the second part # and that's what it came up with. Oh well, soldering should work
  14. Sep 24, 2009 at 6:15 AM
    Fishpig
    Fishpig Well-Known Member
    Lexington, VA
    2020 TRD OFF ROAD DCLB
    Does anyone have the wiring info on the 4 wires to the OEM switch?
  15. Sep 24, 2009 at 7:11 AM
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    Guys I put the OEM fog light switch in the position to the right of the factory fog light switch (Traction Control Switch location I believe) for a DTRL kill switch. When I popped out the blank cover there already was a plug there, and it was wired. All four wires were installed in the plug. This pic is of that prewired connector after I pulled the two of wires for the LED out.
    If your vehicle did not come with a fog lights from factory, you may have the connector already wired behind your blank cover. I don't know for sure because mine had fog lights from the factory. So I reused the two for the LED on my new switch, because they are already were wired to come on with my lights.
    Note that the all of the switches are keyed to go into a certain place on the dash, so I had to modify my new fog light DTRL switch to fit in the open location.
    Here is a pic of the new DTRL kill switch. I need to find a way to label them 'FOG' and 'DTRL' Any Ideas?
  16. Sep 24, 2009 at 7:12 AM
    PSUnick
    MA
    2007 AC 4x4 Sport
  17. Sep 24, 2009 at 7:38 AM
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    I got switch part number 00550-35976 from the dealership for $9. It is not the same as the fog light switch but still is a direct fit & uses 3 wires. It is a rocker style, not push button. It looks good imo, like it belongs there.
  18. Sep 24, 2009 at 11:18 AM
    RCBS
    pic?
  19. Sep 27, 2009 at 12:36 AM
    Krusey1011
    Kyle
    Washington
    Damn! I wish I would have paid closer attention to your post PSUnick. I only paid attention to how to make the switch fit into the slot by removing the notch. I didn't know I could remove the wires with the metal tabs. I cut the wires and pulled them out then re soldered them on. alot of extra work I didn't need to do. Whatever, it's done and working now. Heres what it looked like.
    IMG_1339_6a399837acfb33951015f800b6d54b90e2b07b8a.jpgIMG_1348_23dfcdc82976412e887d0fd6817facedbd8ed6c5.jpgIMG_1351_836a30951bcd7d46cb8a58e2a1400ed26069942a.jpgIMG_1353_8daff2c9822b6e582bc48c7ae7a7a9e7ca7e389d.jpg Alot more work as you can see. Hahah Live n learn! I'm just glad it works:D Great post though man!
  20. Sep 27, 2009 at 3:03 AM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Krusey,
    any pics of the blackmagics behind the grill? This is exactly what I would like to do. I don't have the technical know how.
