factory gearing for 95.5 taco 2.7 4x4 auto????
Discussion in '4 Cylinder' started by jmj3918, Oct 24, 2008.
  1. Oct 24, 2008 at 9:04 PM
    jmj3918
    jmj3918 [OP] Member
    wa
    95.5 taco 2.7 auto,
    ,kenwood stereo ipod hook-up & 4 kicker 6.5s, rockford fosgate amp & 8" sub,custom box,smittybuilt nerf bars.bfg t/a k/o 31/10.5/15, 20% tint,canopy,TOYTEC ULTIMATE LIFT+1"BLOCK & SHIMS' DC-1'S
    :confused:how do i find out what my factory gearing is? i would like to go from 225/75/15-----31/10.5/15. problems? mpg? maybe i should've posted this under tires.
  2. Oct 25, 2008 at 4:59 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    welcome to TW Here is a basic chart you have to use the door sticker on your truck to find what gears you hathere is a code on your door tag that will tell you what gears you have.... example is my 96 taco has 3.58 gears and most not all trd taco's have 4.10's and some lucky sob's got 4.56's if they got a 4cyl auto pre runner trd lol
    THIS CHART IS FOR '95.5-04 MODELS ONLY!
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    A = 7.5" ring gear
    B = 8" ring gear
    Next two digits:
    01 = 3:42
    02 = 3:58
    03 = 4:10
    04 = 4:56
    05 = 3:15
    06 = 3:91
    07 = 4.30
    Last digit:
    A = 2 Pinion, Open
    B = 4 Pinion, Open
    C = 2 Pinion OEM Limited Slip
    some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio, at least for the 5sp. RZN171L-CRPDKAB with factory 31s/265s should be 4.56 with the AT.ve
  3. Oct 26, 2008 at 7:21 PM
    jmj3918
    jmj3918 [OP] Member
    wa
    95.5 taco 2.7 auto,
    looks like 8" w/ 4.11s 2 pinion open. think i'll just go w/ 30/9.5/15 keep some power and some mpgs. also thinking about a 3" revtek lift this spring.----income tax return time. :)
  4. Oct 27, 2008 at 7:03 PM
    mudjunkie
    mudjunkie Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
  5. Oct 27, 2008 at 7:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    One way to tell with accuracy is to jack up the rear of the truck, both tires. Turn the tire while counting the turns of the drive shaft. If the drive shaft spins 4 times to 1 turn of the tire, you have the 4.10's. If it turns 3.5 times, then you have the 3.58's. :)
  6. Oct 27, 2008 at 7:11 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    so jack the rear end up and spin the tires and see how many times the tires turn to complete one driveshaft rotstion correct
  7. Oct 27, 2008 at 7:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Turn the TIRE one turn, and count the drive shaft rotations.
  8. Oct 27, 2008 at 8:17 PM
    350TacoZilla
    Hancock MD
    I can tell you from owning 5 tacos (I think..maybe 4 anyhow...) that the chart i provided has been accurate for me entirely... I even had a truck that the stealership claimed had the 4.10 gears and it turned out to have 3.91's just like the chart said it would
