Factory Heated Seats Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Witte, Jan 10, 2018.
  1. Nov 21, 2019 at 10:35 AM
    #181
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    so i just ordered a new 87501-0c020 to replace my fried one along with a new connector and terminal pins. if it works ill have 4 extra connectors because there was a 5 min order quantity. ill keep everyone posted
    heres the info FYI:
    Connector: Molex P/N 39-01-4050
    Terminals: Molex P/N 39-00-0039 (Qty: 5)
    curtiousy of Jeff Lange
  2. Nov 21, 2019 at 11:12 AM
    #182
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    When Toyota updates a part, they don't generally discontinue the old one, they will just supersede it to the newer number. In cases like this one where a part that is still in production is discontinued, it is usually because Toyota no longer wants to sell that part individually and you need to order an assembly. That is what happened in this case, instead of selling the amplifier by itself, you are forced to buy the entire seat heater assembly with the heater, wiring and amplifier.
    In this case, the part is no longer even in the diagram for the seat, not selectable, and not listed anywhere. It's no longer a serviceable part.
    Canadian TSB is 5153.
    82167-04030 is not the wiring harness that plugs into the amplifier/ECU, it is the wiring harness that plugs into the wiring harness that plugs into the amplifier/ECU, which is why it's not needed.
    If you do find an amplifier separately, and want to repair the connector, the information was just posted. It's a Molex connector, part number 39-01-4050 and the terminals are part number 39-00-0039 (need 5).
    Originally when you could order the part, it actually came as the amplifier/ECU with the small harness coming out of it (at least on the 2013 Tacomas that used 87501-04020).
    Jeff
    bigmw and shakerhood like this.
  3. Nov 21, 2019 at 11:17 AM
    #183
    mobgma
    mobgma Well-Known Member
    Edmonton, AB, Canada
    2016 Toyota Tacoma TRD Double Cab Long Box
    Thanks Jeff. Gateway helped me out thanks to you. All I needed was 87510-04050 and 1.5 shop labour and it is now fixed.
    Jeff Lange[QUOTED] likes this.
  4. Nov 21, 2019 at 11:22 AM
    #184
    Jeff Lange
    Calgary, Canada
    Yeah I didn't even realize who I was replying to here until after I posted, haha. Glad you got it sorted.
    Jeff
  5. Nov 21, 2019 at 1:06 PM
    #185
    zeagle50
    zeagle50 Well-Known Member
    There have been other older posts in 3rd gen about the same heated seat module fail. I hope Toyota steps up and fixes the problem as more of them are failing.
  6. Nov 21, 2019 at 1:19 PM
    #186
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Even the aftermarket heaters fail, sometimes at a faster rate. All electronics fail and on a long enough time line, their survival rate drops to zero.
  7. Nov 21, 2019 at 1:21 PM
    #187
    Jeff Lange
    Calgary, Canada
    Have there been many reported failures on 2019-2020 models or 2016-2018’s that had the TSB completed?
    Jeff
  8. Nov 21, 2019 at 3:17 PM
    #188
    mobgma
    As I understand the issue is only with 2016-2018s
  9. Nov 21, 2019 at 3:24 PM
    #189
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    My ‘13 modules are melted. Went to the dealership to snag plugs and the parts guy told me the only way I could fix it was to order new seats:crazy:
  10. Nov 21, 2019 at 3:31 PM
    #190
    Jeff Lange
    Calgary, Canada
    The 2013 modules used to be listed separately, but now need to be ordered with the heater pad as well (87510-04011). I am mostly curious about newer vehicles (2019+) though.
    Jeff
  11. Nov 21, 2019 at 5:39 PM
    #191
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Would you happen to have the part # for the seat heater ECU too? Would I be able to cut the plug off and splice the new one or or would I be better off taking my seat apart and doing the whole 9 yards. Probably answer my own question there just looking for the easiest way.
    Lucifer1 likes this.
  12. Nov 25, 2019 at 2:47 PM
    #192
    Scotty_P
    Scotty_P New Member
    Jo
    Toyota
    None
    I have purchased part 87510-04050 for my 2016 Tacoma. It comes with the pad and heater amp. I am going to pull my seat out and cut the connector off the original heating element and solder this new one on. I think it will work fine. Will report back when complete.
  13. Nov 25, 2019 at 4:13 PM
    #193
    roth_nj
    Keep us posted...
    I wasted a week trying to by them online only to have the order cancelled and refunded cause they couldn’t actually get them
  14. Nov 25, 2019 at 4:15 PM
    #194
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Call a Toyota regional service rep, not the dealer. You stand a better chance of getting it replaced past warranty.
  15. Nov 25, 2019 at 5:44 PM
    #195
    Scotty_P
    Scotty_P New Member
    Jo
    Toyota
    None
    davidstacoma likes this.
  16. Nov 25, 2019 at 5:49 PM
    #196
    Scotty_P
    Scotty_P New Member
    Jo
    Toyota
    None
    Also I have spliced in the new amp to the original heating pad and it works fine. I took 30 minutes to do this. I decided to try this way after watching a video of someone installing an aftermarket butt heater, looks like a bit of a PITA to have to take the pad out and put pack in.
  17. Nov 25, 2019 at 7:56 PM
    #197
    roth_nj
    Yes sorry for not being clear. I was trying to find an old one so I didn't have to tear apart the seat. I watched some videos and it seems like something I could handle easily... Just don't want to at all
  18. Nov 27, 2019 at 11:49 PM
    #198
    Carter
    Carter Well-Known Member
    Carter
    Calgary AB
    14' Tacoma TRD Sport
    Toyotec Boss 3", Ridged Industries grill/light bar combo, TRD exhaust, Fender flares, 16" wheels with 33" Duratracs, Parrot Android Smart Deck, Custom Black Leather with red stitching.
    My 14' suffered this failure last year. I dug out the melted plastic and it worked for another year. Ordered a new connector, anyone source the amp separately yet?
  19. Nov 28, 2019 at 7:59 AM
    #199
    wanz5632
    wanz5632 Member
    Noticed last night that my heated seats stopped working - checked under the seat and same issue. Working good after the splice? I'm thinking about doing the same to save on some labour.
  20. Nov 28, 2019 at 10:23 AM
    #200
    wanz5632
    wanz5632 Member
    Has anyone in Canada been able to find a site that will ship? Every single parts place I've clicked on won't ship to canada and if I call them, it just rings and rings. The only place I've found that will ship to Canada is ToyotaPartsDeals.com and its 80 bucks shipping. As a last resort I'll do what I have to, but just wondering if any Canadians have had better luck?
