Factory Heated Seats Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Witte, Jan 10, 2018.
  1. May 4, 2022 at 7:23 PM
    #401
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Screw the Plug and just solder it directly because a replacement won't fit anyways.
    look back to post #376 or so for what i did
  2. May 4, 2022 at 7:30 PM
    #402
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I'm not the best at soldering, I felt like solding wire to those pins that are already soldering to the board would be easier?
  3. May 4, 2022 at 7:43 PM
    #403
    jerkwithkeyboard
    You need the heaver gauge wire to "pull" the heat off the board better. ask a friend or go to youtube..... for soldering help
    and fix both sides while your at it..
  4. May 4, 2022 at 11:03 PM
    #404
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    3 things you need to solder well:
    Clean parts
    Flux
    Enough heat to melt the solder quickly.
    It helps to pre-tin the wire(marine grade comes pre-tinned). Clamp the board so it doesn’t move under pressure, slip each tinned wire through the hole, apply flux, then heat, then solder and remove the iron. 63/37 is easiest to use and 60/40 almost the same. 97/03 Lead free is a pain. Your supposed to apply solder to the heated joint but it’s also possible to melt a drop on the iron tip and apply that to the fluxed board/wire and watch until you see it wick into place. If it doesn’t happen within 3-5 seconds stop, clean up, and start over. An iron with heat adjustment and a variety of tips is way better than a fixed temp pencil since the amount of heat needed corresponds to the mass being soldered.
    doublethebass likes this.
  5. May 26, 2022 at 4:53 PM
    #405
    dubktrd
    dubktrd Well-Known Member
    Wichita Kansas
    20220526_175150.jpg 20220526_182842.jpg2017 , got it working again thanks guys and OP
    jerkwithkeyboard likes this.
  6. May 27, 2022 at 11:02 AM
    #406
    jerkwithkeyboard
    Don't forget to "fix" both sides while your at it......
    DoggerDave and dubktrd[QUOTED] like this.
  7. May 27, 2022 at 12:48 PM
    #407
    DoggerDave
    DoggerDave Well-Known Member
    Dave
    2016 Blue TRD Sport 4x4 long bed
    Not much yet. Previous owner put some oversized tires and rims
    Yes definitely do both sides!
    dubktrd likes this.
  8. Aug 22, 2022 at 1:37 PM
    #408
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Do I have to disconnect the battery to tilt the seat?
  9. Aug 22, 2022 at 3:20 PM
    #409
    TegoTaco
    Ontario, Canada
    I can confirm that this works on the 2nd Gen, it’s been too many years without it! Used 14 gauge wiring, man was it a bitch! Soldered and heat shrink! Used about 10” of wire, hopefully it helps with heat dissipation.
  10. Aug 25, 2022 at 8:02 AM
    #410
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    2016 TRD Off Road with 65K miles.
    My driver side seat heater failed about 2 months ago. I use it almost every day for about 5 months of each year. Lower back injury issues and the heat really helps.
    So I finally took it to the dealer to diagnose.
    No charge warranty repair in my case. Warranty of course has expired but they are covering it and I did not ask.
    They quoted TSB T-TCI-5153. I think some of these TSB numbers might be different for CDN vs USA purchased trucks?
    From the service receipt. Waiting for parts to arrive still.
    CORRECTION: NEED TO REPLACE THE HEATED SEAT AND RESISTER BLOCK AND. RETEST. THERE IS A TSB FOR THIS ISSUE T-TCI-5153 FOR THIS
    JOB # 4 1 87510-04050 HEATER ASSY, SEAT
    JOB # 4 1 87530-04030 HEATER ASSEMBLY
  11. Aug 27, 2022 at 12:07 AM
    #411
    smikec
    smikec Well-Known Member
    confused
    TSB T-TCI-5153 refers to vehicle acceleration stumble, nothing related to seat heaters?
    And that is a Canadian bulletin (where you are from).
    Also surprised warranty covering a 6 yo vehicle
    Call me skeptical. But hoping the best for you. Let us know how you make out
  12. Aug 27, 2022 at 10:34 AM
    #412
    ppat4
    Paul
    Kelowna, BC
    Yup, that is the data they gave me, and also verbally said no issues, it is covered under warranty. Was quite surprised by that. Will check next week to see if parts are in.
    However, this is the dealer that has done all the work on the truck for 4 years now, and never an issue with the quality of work. Plus very good customer service.
    Maybe they are just hoping I will do a trade in at some point for a new vehicle. Some dealers do like to keep their customers for life and do what they need to do to make that happen.
  13. Sep 6, 2022 at 7:25 AM
    #413
    Turbo422
    Turbo422 Well-Known Member
    2017 Toyota Tacoma TRD Sport
    Curious. I look up the part number for the module (87501-0C020) but the module that comes up shows it’s only for the Toyota Tundra. Is this the same module? If not can I still use it? Mine is burnt pretty bad and was told by Toyota to go kick rocks so I am going to be replacing mine this weekend.
  14. Oct 13, 2022 at 5:30 AM
    #414
    Firk
    Firk Well-Known Member
    My 2018 with 138000km drivers heated seat stopped today. Thanks for all this info, I will diagnose
  15. Oct 13, 2022 at 5:47 AM
    #415
    TegoTaco
    Ontario, Canada
    It’s been almost two months using it daily and so far so good!
    Firk likes this.
  16. Oct 24, 2022 at 10:40 AM
    #416
    LejaBeatz
    LejaBeatz Member
    16 Tacoma TRD Sport DCSB
    It isn't pretty, but it works.
    jerkwithkeyboard, Firk and shakerhood like this.
  17. Oct 25, 2022 at 4:20 AM
    #417
    Firk
    Mine was burnt and repaired under warranty
    shakerhood likes this.
  18. Oct 25, 2022 at 8:58 PM
    #418
    jerkwithkeyboard
    Did you "FIX" both seats because the other will die also, and it will be easer now that you did the first side. I was surprised how brunt my other one was getting.
    :thumbsup:
    PS: Welcome to TW
  19. Oct 25, 2022 at 9:21 PM
    #419
    Technique
    Alex
    Utah
    I still can't get the plastic oem connectors off the board lol. I need to try and get this hammered out as its snowing now...and my butt misses the heat.
  20. Nov 13, 2022 at 4:50 PM
    #420
    TX_TACO512
    TX_TACO512 Member
    2017 Tacoma TRD OR
    Same failure on driver side seat. Brought it to dealer and it was covered under my extended warranty.
