Factory Heated Seats Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Witte, Jan 10, 2018.
  1. Oct 1, 2023 at 12:42 PM
    #461
    TahomaCamper
    TahomaCamper New Member
    Katherine
    2004 Toyota Tacoma TRD
    Hi all, old thread, but still a reoccurring problem. After a few failed attempts at purchasing the heated seat amp and it being returned due to out of stock or no longer a valid item errors I was able to source one successfully from Sparks Toyota in South Carolina. Now just have to figure out how to rewire it all..
    smugly likes this.
  2. Oct 1, 2023 at 1:43 PM
    #462
    soggyBottom
    soggyBottom Well-Known Member
    Stokes Toyota?
    smugly likes this.
  3. Oct 1, 2023 at 2:03 PM
    #463
    TahomaCamper
    Katherine
    smugly likes this.
  4. Nov 5, 2023 at 5:20 PM
    #464
    easy_E
    easy_E Member
    Ethan
    2016 Tacoma
    None yet!
    Big thanks to @Jeff Lange. I've been putting off this fix for a while but figured with the incoming cold weather up here in Canada, I better get an order into Digikey. Some cleaning of the module and a quick desolder and solder job and my @$$ is toasty once again.
    Cheers.
    Koolbreeze7 and soundman98 like this.
  5. Nov 6, 2023 at 12:56 PM
    #465
    cmatlack
    cmatlack New Member
    Clint
    2013 White Tacoma TRD Sport
    Thanks, Tacoma world peeps. My 2013 TRD Sport driver's side heated seat quit working at 130k. Removed the ECU module, and bought the Amazon 5 pin connector, soldered in place. Maybe an hour job. and then it was Good to Go! Toastie seats again!
    https://www.amazon.com/QOFOWIN-Waterproof-Connectors-Electrical-Connections/dp/B085HNSVY4?keywords=5+wire+connector&qid=1643834747&sr=8-2&th=1
    PXL_20231101_002714935.jpg PXL_20231105_220625257.jpg PXL_20231105_221147346.jpg
    9pm and Canadian Caber like this.
  6. Nov 18, 2023 at 5:52 PM
    #466
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    Great Info. Mine has stopped working except for occasional moments. Great to see the issue I probably have and the solution. Who doesn't need some soldering practice?
    I am able to see the temps of the seats on my OBD code reader in the air conditioner PIDs under network A.
  7. Nov 19, 2023 at 7:27 AM
    #467
    Tacoguy1984
    Tacoguy1984 Member
    13TacomaLimitedLB
    KN cold air
    Any other replacment models #s for 2013 Taco seat heat ecu? I have the 87501-04020-A with the 5th pin terminal burnt. Does the 87501-06010 work as a replacement? Or what other model #(s)? Thanks!
    Ethan8484 likes this.
  8. Nov 21, 2023 at 10:40 AM
    #468
    BM85_2022
    BM85_2022 Active Member
    2016 Tacoma Limited
    Also stumbled on this thread after my 2016 limited driver side just went out. I live in Texas (bought truck brand new while living outside DC and moved to Texas shortly after) so we don’t use heated seats much, but looked under and could tell it burned out. Few stealerships wanted 250 for diagnostics without even talking about. Called corporate based on post 91 to start there. Initial reaction is they held position it’s out of warranty, applies to certain vins only, and I’d have to deal with dealers. Mentioned to them this is a fire hazard which should be a recall and all the vins listed in TSB are possibly different models and all use the same parts either way, and finally by time TSB came out most 2016 are already out of warranty (2016 made and sold mid to late 2015) so that it wasn’t fair for those like myself especially living in warmer weather for a potential fire hazard. Now they’re going to have their ‘senior agents’ call back next week. Will keep posted
    Kolter45 likes this.
  9. Nov 26, 2023 at 2:39 PM
    #469
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Add me to the list…2016 trd or…
    No heat=no joy.
    Will have to read rest of thread, but can any one answer this quick question?
    Order my own part and fix or go after Toyota for tsb fix?
  10. Nov 26, 2023 at 3:51 PM
    #470
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Just try and Fix it, my repair is working fine (still)
    Just cut the plug off and add new longer wire,
    Cipher94 likes this.
  11. Nov 26, 2023 at 4:01 PM
    #471
    tombiosis
    T
    Ottawa Canada
    Thank you for the detailed explanation! Lol.
  12. Nov 26, 2023 at 8:36 PM
    #472
    jerkwithkeyboard
    Well if it was able to be under warranty you wouldn't be asking, (possibly) but because you have a 2016 like me you probably don't.
    PS my old parts worked once i replaced the wires to it.
    Better?
  13. Nov 27, 2023 at 5:06 AM
    #473
    janesy12
    janesy12 Member
    Andrew
    2017 SR5
    '17 Tacoma SR5, same issue here, drivers side. Anyone have any luck with the process if you're out of warranty? This is obviously a common issue.
  14. Nov 30, 2023 at 7:08 AM
    #474
    tombiosis
    T
    Ottawa Canada
    I called Toyota Canada and filed a complaint… I don’t think people should be doing wiring hacks on their vehicles that could result in a fire. I doubt I will hear back from Toyota, but I want my heated seats back!
    I guess I will have to break out the ol’ soldering iron.
  15. Jan 19, 2024 at 3:47 PM
    #475
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Still nice and toasty!
    smugly likes this.
  16. Jan 19, 2024 at 3:49 PM
    #476
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    Adding me to the list... Still lights up. can you access the box without removing the seat easily.. or should the seat come off? It's 5 degrees outside before windchill and I don't have a heated garage ... Or even a flat driveway
  17. Jan 19, 2024 at 5:11 PM
    #477
    TegoTaco
    Ontario, Canada
    Unbolt the 4 bolts, lay the seat flat and you should easy access to the ECU and harness for repair.
  18. Jan 20, 2024 at 9:42 AM
    #478
    JonTut
    JonTut New Member
    Jon
    2017Limited4x4
    Stock besides the Seat jackers
    Thank you for everyone that shared. I completed my mods to the module. I removed the old connector and soldered in my new. Then soldered in the seat side. I took this opportunity to add the seat jackers by Desert Does it (they are awesome). The seat heater functions now and probably better than new.
    thanks again for sharing the knowledge.IMG_2875.jpg IMG_2878.jpg IMG_2915.jpg IMG_2920.jpg IMG_2931.jpg IMG_2933.jpg IMG_2936.jpg IMG_2937.jpg IMG_2941.jpg IMG_2942.jpg
  19. Jan 23, 2024 at 11:33 AM
    #479
    DavR
    DavR New Member
    2016 Tacoma TRD Sport Crew Cab
    Another disappointed Tacoma guru! 2016 TRD Sport with the same issue. Thanks to all on the past posts I have now gained a lot of knowledge on this issue! Called Corp and received the you have to take it to your dealership for diagnosis. I said the obvious that I’m paying for something I already know. What a bunch of BS. I said we know where this needs to go and hung up. Thanks all… it’s pull the seat and new wiring harness time!
    smugly likes this.
  20. Jan 24, 2024 at 12:10 PM
    #480
    DavR
    DavR New Member
    So is there really any need to replace the connection? From what I see it looks like some just direct wired it.
