Factory Heated Seats Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Witte, Jan 10, 2018.
  1. Jan 24, 2024 at 8:11 PM
    #481
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    I cut the plug off / added thicker wire to suck some of the heat away and soldered it all back in.. 2 years ago and its working fine... PS do both side while your at it.
    Look at post #373 - 376
    smugly and Age315 like this.
  2. Jan 25, 2024 at 8:21 AM
    #482
    DavR
    DavR New Member
    2016 Tacoma TRD Sport Crew Cab
    Okay thanks for the info and advice!
    jerkwithkeyboard and smugly like this.
  3. Mar 10, 2024 at 7:47 AM
    #483
    motogeek
    motogeek Taco Tueday? Tacos Everyday!
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    2.5 Toytech Inch Lift 285 Cooper SST
    Sunsetsearider likes this.
  4. Mar 18, 2024 at 5:59 AM
    #484
    DavR
    DavR New Member
    No luck with the dealer for me. I actually just took advice from jerkwithkeyboard and cut the plastic around the burnt connection on the module as well as the harness. I then used an ultra small wire brush and contact cleaner to clean both connections plugged it back together. Bingo!! All fixed and back to warm back n buns! 2 mos now and no issues…TY Tacoma World!
  5. Mar 18, 2024 at 10:09 AM
    #485
    motogeek
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    I had a similar outcome. I put it all back together after inspecting myself and just the pulling apart partially melted connector and reconnecting the connector to take it to get looked at Toyota and worked immediately. So appears the melting can cause some residue to seep into the connector and make it loose connectivity. So I will probably switch out the connector like others did above with larger wiring to absorb some of that heat and amps.
  6. Apr 1, 2024 at 2:00 PM
    #486
    flyfisher79
    flyfisher79 Active Member
    Rod
    British Columbia
    2016 Tacoma TRD Sport DCLB 4x4
    My driver side seat heater stopped working. After following the directions I managed to fix it myself.
    Thanks for everyone's input and photos making this an easy fix.
    shakerhood and Canadian Caber like this.
  7. Aug 20, 2024 at 1:16 PM
    #487
    janesy12
    janesy12 Member
    Andrew
    2017 SR5
    2017 SR5.
    Attempted this repair but seat heater still isn’t working. I have different connectors than most folks here due to being in Canada. Below is my wiring before I wrap things and make it permanent. Is this the correct wiring? Shouldn’t it be 1 for 1 as I have done?
  8. Aug 20, 2024 at 4:06 PM
    #488
    janesy12
    janesy12 Member
    Andrew
    2017 SR5
    what was your wire to wire connection from the new connector to the existing wiring from the original connector? I tried to match up the wires the same as the original connector which is
    New connector/factory wiring:
    red to red
    Black to black/red
    Blue to green
    Yellow to brown
    Grey to black
    I soldered them quickly to test it before cleaning it up and wrapping them, but the seat heater still doesn’t work.
    passenger side works fine, and as far as I know they share a fuse so the fuse shouldn’t be the issue. If my wiring is correct I guess it’s the ECU itself..
  9. Aug 25, 2024 at 3:19 PM
    #489
    DoggerDave
    DoggerDave Well-Known Member
    Dave
    2016 Blue TRD Sport 4x4 long bed
    Not much yet. Previous owner put some oversized tires and rims
    I'll have to go back and check my pictures. It's been a while. I'll let you know what I find.
  10. Aug 25, 2024 at 3:23 PM
    #490
    janesy12
    janesy12 Member
    Andrew
    2017 SR5
    I actually got it working after! Removed all the solder from the board, cleaned it up nicely and re-soldered. All good again! Bring on the Canadian winter!!
    Canadian Caber likes this.
  11. Aug 25, 2024 at 3:24 PM
    #491
    DoggerDave
    Dave
  12. Aug 25, 2024 at 3:25 PM
    #492
    DoggerDave
    Dave
    Good to hear.
  13. Aug 25, 2024 at 3:39 PM
    #493
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Man it’s been I think two winters since my driver side failed. This thread notification was a good reminder I should find mine and try to get it fixed haha. I miss my heated seat…just could never get the old pins off the board.
  14. Aug 25, 2024 at 3:42 PM
    #494
    janesy12
    janesy12 Member
    Andrew
    2017 SR5
    I cut the pins off and unsoldered what was left. It took A LOT of heat and time to get all the pins out. If I had my time back I would have taken my time and carefully cut the white connector away, leaving the pins.
    Then just solder the new connector wire to the leftover pins.
  15. Aug 27, 2024 at 12:02 PM
    #495
    janesy12
    janesy12 Member
    Andrew
    2017 SR5
    Anybody know what wire goes to the on/off switch?
    My drivers side is working now, however a little TOO well lol, it works whether the switch is on or off… wondering if the ECU was damaged with the initial wire or something else is wrong with my fix.
  16. Aug 27, 2024 at 12:34 PM
    #496
    DoggerDave
    Dave
    I would think maybe you got the wires mixed up.
  17. Aug 27, 2024 at 2:44 PM
    #497
    janesy12
    janesy12 Member
    Andrew
    2017 SR5
    maybe. It’d be nice to know what each wire does. They’re matched exactly like they are on the original connector however.
  18. Aug 27, 2024 at 3:10 PM
    #498
    DoggerDave
    Dave
    Did you possibly soldier 2 connections together? They are pretty tight. I didn't soldier mine. Got a guy to do it for me.
  19. Aug 27, 2024 at 3:29 PM
    #499
    DoggerDave
    Dave
    It looks like you got the wires connected properly.
  20. Oct 27, 2024 at 9:31 PM
    #500
    Technique
    Alex
    Utah
    Welp, pretty sure I damaged the board when I FINALLY got the pins out.
    I'm ready to call it and order new parts, but looking at previous posts, it sounds like there is a new updated part? I don't really want to pull my seat to add a whole new heating element and harness for $292.
    Is there still just an amp that we can buy for 17' year models, anybody know?
    Edit:
    Answered my own questions. Looks like I can still buy just the seat heater amp
    https://wholesaledirect.moderntoyot...t-heater-control-module-left-right-875010c020
    I'm thinking I"ll buy this new, leave the pins IN the board, and solder the new thicker wire directly to the pins.
