Factory LSD swap for base model?
Discussion in 'Street Trucks' started by ryoung40911, Aug 17, 2021.
  1. Aug 17, 2021 at 4:44 PM
    ryoung40911
    ryoung40911 [OP] Well-Known Member
    Rich
    NH, USA
    2010 Silver Tacoma 2wd Base Model
    DJM 3/4 lowering kit, 18" ford interceptor wheels, Nitto nt555 g2 tires, X runner sway bar, and many more on the way
    Alright so I have the 2wd base model from 2010 and it has an open diffential with the shitty auto LSD system. I've read that apparently some trucks came with an LSD from the factory so would that be something I could swap in? Or are there any aftermarket LSDs that would be a direct replacement? For the record I'm looking for something less off-road oriented and more street/drifting oriented, since the goal here is to get sendy on the backroads and dirt trails in my lowered truck. Figured I better make a post before I change the oil in my stock diffential for my 30k service. Thanks for any help or ideas tw friends.
  2. Aug 17, 2021 at 4:46 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    A detroit truetrac is what I recommend
  3. Aug 17, 2021 at 4:47 PM
    BassAckwards
    It’s a helical style LSD so it’s an upgrade over the factory one that had clutch packs
    ryoung40911[OP] likes this.
  4. Aug 17, 2021 at 7:03 PM
    ryoung40911
    Rich
    NH, USA
    What size would I need to look up for the 4cyl 2wd? Most seem to be for 4x4s
  5. Aug 17, 2021 at 9:01 PM
    BassAckwards
    You can call east coast gear supply to be sure, but I’ve heard of ppl swapping in 3.73s in the 5 lug trucks, so I’m betting the truetrac for the 4wd/Prerunner trucks is what you need
