Factory mic help
Discussion in 'Audio & Video' started by KENNY, Apr 16, 2015.
  1. Apr 16, 2015 at 5:40 PM
    KENNY
    KENNY [OP] Well-Known Member
    Does anyone know where I can find the name/harness that connects the factory 2012+ console mic to the 8/28 pin connector? I have a pre 2012 that wasn't wired for this. Thanks.
  2. Apr 17, 2015 at 2:19 PM
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    I'm looking for the harness or just the female connector part number at the MIC too.
    BUMP for Kenny2011.
  3. Nov 3, 2015 at 8:36 AM
    Atomic47
    Atomic47 Well-Known Member
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Leveling kit, AAL, air-ride, Rear diff breather mod, Illuminated 4wd Switch, 4 more D rings, fog lights anytime, 7 pin relocate, Coca-Cola mod, TRD Off-Road hook, Weathertechs, secret custom cargo light, 09 lower dash panel, heated seats, 2013 oem touch screen radio, reverse camera added into Pop'n'Lock locking tailgate handle, black powder-coated TRD Sport rims, 32" light bar in custom fabricated mount, aux reverse lights in rear bumper
    Kenny2011, did you have any luck with this? I'm in the same situation.
  4. Nov 3, 2015 at 8:57 AM
    Jon147
    Jon147 Well-Known Member
    Jon
    Orange County
    '13 TRD Sport-Vader
    Bilstein 5100 RHA/OME 887s/LR UCA's, 5100's in rear w/ Wheelers 3 leaf progressives, wrinkle black/silver TRD front skid plate, emblem removal, LED third brake light, remove/replace TRD Sport stickers with custom black TRD stickers, tail gate lock mod, BLHM & BLTM, VLED 430lm DTRLs, VLED LED rear turn signals, LED headlights from BadAssLED's, black mesh grill, AVEC LED light bar behind grill, AVEC LED light bar lower valance, 91' Cadillac Deville Horns, Hood Scoop LED from C4 Fabrication, Procomp 5001's Satin Black, FlowMaster Dual Exhaust American Thunder, Blue Sea Aux Fuse panel, AVEC 12" ultra slim light bar in bed, Undercover Flex bed cover
    Is this what your looking for? Part # 86730A It's the microphone assembly.
  5. Nov 3, 2015 at 9:32 AM
    Atomic47
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    I have that part. I'm looking for the wiring harness that would connect that part to the head unit. Having the microphone part number is helpful though. Thanks!
  6. Nov 3, 2015 at 2:06 PM
    othater
    SoCal-Walnut
    Denis,
    I ended up making my own harness.
    Male and female connector
    HOUSING CONNECTOR(90980-12211)
    HOUSING CONNECTOR(90980-12212)
    Pins male and female pig tail
    82998-12670
    82998-12690
    Hope that helps.
    Roland (othater)
  7. Nov 3, 2015 at 6:54 PM
    Atomic47
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Thanks, Roland!
    This is what I have from a auto wrecker. It's the panel between the map lights, microphone and a bit of wiring harness. I would need to find the other end that plugs into the back of the radio and the pin configuration to be able to make my own wiring harness. Any assistance would be great!
  8. Nov 3, 2015 at 8:25 PM
    othater
    SoCal-Walnut
    Denis,
    Your lucky you were able to find the MIC with the connector plus a pigtail that you only have to splice to.
    Saves a lot of searching.
    Connector part number 90980-12551 at the radio.
    You can order online or request a sample plus the pins from TE.
    I dont recall the pin's part number. If I find them, I'll post it here.
    Also I notice you have a 08, I have a 06 and had to change the overhead console for the MIC. That piece was solid and not removable.
    You may be able to modify to make it work. (cut and glue).
    Let me know if you have any other questions.
  9. Nov 4, 2015 at 5:16 AM
    Atomic47
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Roland, you're the MAN!
    Who is TE?
    I'll check with my local dealer and see about the part number (and pins). Then I would only need the pin configuration, which a photo of the connector showing the wire colors would provide.
  10. Nov 4, 2015 at 3:45 PM
    othater
    SoCal-Walnut
  11. Nov 4, 2015 at 5:04 PM
    Atomic47
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Roland, you were correct about the overhead console. That piece is not removable in mine either. I'm not willing to try cutting it out at this point so I guess I will use the mic that I bought until I might find another console. Thanks for all your help!
  12. Nov 4, 2015 at 5:59 PM
    othater
    SoCal-Walnut
    There was someone on here that used a dremel to cut the slots in the console and attached then mic inside.
  13. Nov 5, 2015 at 3:26 PM
    KENNY
    Do a search in the for sale forum for the guy that parts out the tacomas, i got mine in mint condition with the mic for $60 shipped. Thanks for the info on the wires guys, I forgot about this thread.. Now i just need the pigtail that connects to the mic connector
  14. Nov 5, 2015 at 4:18 PM
    othater
    SoCal-Walnut
    Hey Kenny,
    I posted the part numbers for the connectors if you want to build your own harness from the MIC to the radio.
    Wasn't hard with the help from the various forums.
  15. Nov 7, 2015 at 5:16 PM
    Atomic47
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Got it installed today with little trouble. The biggest problem was getting the hazard/clock assembly out of the old head unit.
  16. Nov 7, 2015 at 6:12 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Is there not any way to use the existing mic in the truck. If it worked with the 12 HU why can't we use it on an OE touch screen?
  17. Nov 7, 2015 at 6:13 PM
    Atomic47
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    There wasn't an existing mic in my truck. (see post #11)
  18. Nov 7, 2015 at 6:15 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    What if someone already had the existing mic like the OP has. How can you use it?
  19. Nov 8, 2015 at 6:55 AM
    miketyler
    miketyler Well-Known Member
    I just bought the Scion mic for my Entune conversion but want to use the factory one in the console as you are doing. One thing I couldnt help but notice is the Scion mic has four leads on its plug while the one in the pic appears to only have two?
    Also, that TE site is interesting. How can you cross a particular connector over to one in their catalog? Is there an application guide?
  20. Nov 8, 2015 at 7:15 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Hey Mike did you get the Scion mic to work? What I found strange is that the male connector on the mic will plug into the 20 to 28 pin adapter. When I saw that I assumed my factory mic would work when I plugged everything in. It doesn't.
    Scion mic.
    Same connector that plugs into the 20 to 28 adapter.
    20 to 28 pin adapter. You can see the female connector that the mic plugs into.
