Factory radio reception issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KevLot17, Jul 6, 2010.
  1. Jul 6, 2010 at 1:21 AM
    KevLot17
    KevLot17 [OP] Well-Known Member
    Kevin
    Pennsylvania
    '10 Blacked Out TRD Sport
    Debadged, Toytec Ultimate Lift, Banks Monster Exhaust, AFE Pro Dry filter, Black Grillecraft grille, Flat Black background headlights, Red Blinkers and markers with alternating turn signal mod, Krypton Bulbs 6000K Headlights and Fogs, Fog Light anytime Mod, LED interior lights with map light mod, AVS Black Taillight Covers, Tinted Windows, WeatherTech Digital floor liners.
    I didn't realize it because I usually have my iPod plugged in but my girlfriend pointed it out to me. She took my truck to work a few times this week and noticed it. No station seems to come in clear anywhere.... anyone have this issue?
  2. Jul 6, 2010 at 5:27 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The antenna plug in the back of the radio is probably loose.
  3. Jul 6, 2010 at 6:46 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    ^^^ what he said
  4. Jul 6, 2010 at 7:07 AM
    dangerbird
    dangerbird Well-Known Member
    Tacoma SR5
    I have to say, when I got my Tacoma I thought the reception was pretty lousy. I replaced my head unit with a new pioneer and was surprised the reception wasn't much better. That would make me think that the antenna might not be that great. Anyway, I listen to XM most of the time.
  5. Jul 6, 2010 at 7:12 AM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    My factory radio sucked also. ave yourself this and other issues and get an aftermarket H/U with ipod or xm.
  6. Jul 6, 2010 at 7:17 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The factory radio has the sensitivity of a brick.
  7. Jul 6, 2010 at 7:20 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Mine worked fine for close to medium distances, crap for distant stations.
    I have a Pioneer, it's pretty good for all.
  8. Jul 6, 2010 at 7:33 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5sp, 4x4
    Also, you can check to see if the aerial has started to loosen at the mount
    on the fender...mine has gotten loose a couple times.
    I have a habit now of making sure it is tight.
    PC
  9. Jul 6, 2010 at 7:35 AM
    toast
    toast Well-Known Member
    had the HU replaced twice, once because of defect, again because of this. No improvement. Search on here, someone added a booster IIRC which is what I am gonna try next.
  10. Jul 6, 2010 at 8:34 AM
    indycross
    indycross Well-Known Member
    Ross
    Austin, Texas
    2011 Tundra Crewmax 4x4
    I had a lot of issues with my stock radio until i took it in. The dealership said that there were a lot of "radio issues due to a bad batch" (whatever the hell that means). I took it in and they had a new one installed two days after.
    Surprisingly easy process.
  11. Jul 6, 2010 at 9:19 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    I doubt anything is loose, the reception sucked on my factory headunit also. As a matter of fact my aftermarket radio isn't that much better.
