Factory radio won't turn on & is unresponsive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoltinJacket, Nov 1, 2009.
  1. Nov 1, 2009 at 7:45 PM
    JoltinJacket
    JoltinJacket [OP] Member
    Atlanta, Ga
    07 PreRunner SR5
    '07 Tacoma Double Cab w/ factory JBL stereo & 6 CD changer.
    Mods, feel free to move this if it belongs in audio/video section.
    New problem came up this afternoon. I started up the truck and my radio was off. The power button didn't respond at all. After about 30 mins of driving, I noticed the display was back on. All my presets were erased. All buttons were now responsive, but I had no sound at all. I tried switching to the CD player and it worked fine all the way home.
    When I got home, I cut the truck off, turned it back on and the same problem started over again -- no power and it won't cut on. So I turn the switch to Accessory and it sounds like the CD changer is cycling through the entire tray. After about 5 secs, the noise stops, and I can turn the power on, but again there's no sound.
    This has baffled me. This is the first issue of any kind with my truck. I'm calling the dealer in the morning since I'm still in the 36 mo./36,000 mile range. Hopefully it's a simple fix.
    Anyone with ideas, please pass them along.
  2. Nov 1, 2009 at 7:46 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Take it out and use it for target practice, thats whats going to go down as soon as mine takes a crap!
  3. Nov 1, 2009 at 7:46 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I wouldnt worry about it. If it's under warranty, let toyota deal with it.
  4. Nov 1, 2009 at 7:47 PM
    Hoyal
    Devin
    2013 Tundra
    It is a problem that many have ran into if you search you will find numerous rants on it.
  5. Nov 1, 2009 at 10:26 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    sounds like a double din touch screen is in order ;)
