Factory rear locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by ryans4x4, Oct 29, 2019.
  1. Oct 29, 2019 at 11:57 AM
    ryans4x4
    ryans4x4 [OP] Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    A friend of mine owns a wrecking yard and he got a wrecked double cab in with a factory rear locking axle, I have a chance to buy it for 750$. It’s got the 4.10 gear ratio and my truck is a 3.91. Would I need to swap the gears in the front axle or are these close enough to run?
  2. Oct 29, 2019 at 12:12 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    you would need to swap a front differential with 4.10 gears as well
    Hamer95USA and CedarPark like this.
  3. Oct 29, 2019 at 12:20 PM
    ryans4x4
    Why? It’s only a 5% difference in gear ratio. I’ve read several people running that and even more drastic with no issues.
  4. Oct 29, 2019 at 12:27 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    You can probably get away with the front tires wanting to go farther than the rear tires for every turn of the driveshaft on loose ground. But nobody in their right mind would recommend it - on any remotely solid surface it'll bind and put unnecessary strain on the frame, driveshafts, axles, transfer case, etc.
    Do yourself a favor and swap to 4.30's all around.
    Ritchie likes this.
  5. Oct 29, 2019 at 12:33 PM
    eon_blue
    Azusa, CA
    Even if you could get away with it, why take the risk? If it were a beater trail rig then thats one thing but if you need to rely on this truck I would get a matching front diff, shouldn't be hard to find a used one
    Ritchie and QMEDJoe like this.
  6. Oct 29, 2019 at 12:46 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I have heard of sand dragster running a higher ratio in the rear to help drive the front end down but unless you are only operating on very loose surfaces change the front as well. But if all you want to do is add a locker and or different ratio why change the whole axle?
  7. Oct 29, 2019 at 12:56 PM
    eon_blue
    Azusa, CA
    Because the TRD e-lockers only fit the TRD axle housings (slightly different size than the non-TRD ones). Can't just install a TRD e-locker into a non-TRD axle, have to swap the entire axle instead.
    TRD axles housings are 8" if I remember right, the non-TRD ones are 8.4".
    Wulf likes this.
  8. Oct 29, 2019 at 12:59 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Then why are you asking the question?
    Buy once, cry once. That’s my motto. Would you rather risk it and end up buying new, matching gears front and rear or buy the axle and matching gears up front and not worry about it?
    mechanicjon and Wulf like this.
  9. Oct 29, 2019 at 1:08 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    if it's a good deal, buy it and get a front diff with factory gears for like $200
    eon_blue likes this.
  10. Oct 29, 2019 at 1:42 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    TBH I'd spend the $750 and get an aftermarket locker with your gear ratio
    The e- lock axles are smaller anyways
    Hamer95USA and Ritchie like this.
  11. Oct 29, 2019 at 3:05 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I have a 4:10 front diff if you need one.
  12. Oct 29, 2019 at 4:52 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I call BS on the "no issues" statement.
    No, who ever told you that, they just haven't noticed the issues, or don't care. Ever drive in a dry parking lot with your 4wd engaged? Yeah, it'd be like that, but driving straight down the road. 5% doesn't sound like a lot, but the simple fact is that your front and rear tires are moving at different speeds, and that's bad.
    The 8.4" diff still has an 8" ring gear, so there's no real difference except the housing.
    They just use the size difference to denote that the diffs are not interchangeable with the housings.
    RedManRocket[QUOTED] likes this.
