Factory Rust Protection
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2018TacomaOffRoadSyracuse, Feb 12, 2018.
  1. Feb 12, 2018 at 6:59 PM
    2018TacomaOffRoadSyracuse [OP] Member
    Dusty
    Syracuse
    TRD OR MT Cement
    Stock
    Ive heard conflicting stories about the importance of rustproofing my new truck. On one hand I hear that the factory rustproofs the undercarriage and many parts are galvanized so do not need rust proofing. On the other hand, I live in Syracuse, NY AKA Salt City USA AKA Snow Capital, so you can imagine the massive amounts of snow & salt I will see. Should I pay the extra $999 to have the rust proofing/sound proofing/paint protection that the dealer provides?
    Cheers!
  2. Feb 12, 2018 at 7:03 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Nope.
    Fluid Film is your friend. Spend some time searching here for it. It's a great product. Kellsport makes a great kit if you've got a compressor.
    nat103 likes this.
  3. Feb 12, 2018 at 7:04 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    You can buy a ton of fluid film for 1k...
  4. Feb 12, 2018 at 7:05 PM
    HerculesRockefeller
    HerculesRockefeller Well-Known Member
    2018 Cement Tundra Double Cab TRD Off Road
    How long will you keep the truck? I live near Buffalo, this is my third Toyota (the other 2 being a 2004 Tacoma and 2010 4Runner) and I haven't rust proofed any of them. I always tried to wash them when the temperature got above freezing, and I got rid of the previous two trucks just shy of 100,000 miles each, and neither had any issues with rust, other than some superficial rusting on the trailer hitch.
    Onehugenut55 likes this.
  5. Feb 12, 2018 at 7:08 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
  6. Feb 12, 2018 at 7:10 PM
    Dusty
    Syracuse
    TRD OR MT Cement
    Stock
    Well, I hope to keep the truck for a long time. Ten years?!
  7. Feb 12, 2018 at 7:13 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    I'm in Syr all so and there's a Krown rustproofing center in Solvay. I've never used the Krown but I have heard good things about it. I had a 2013 taco i traded in on a 2016 and there was quite a bit of rust on the frame on my 2013. They do use a shitload of salt around here.
  8. Feb 12, 2018 at 7:13 PM
    HerculesRockefeller
    At 6 years each for my previous trucks, rust wasn't an issue, but if you're truly in it for the long haul, it's probably worth it.
  9. Feb 12, 2018 at 7:18 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Shootin’ for a new frame. Dealer wants to buy the truck back but not today
  10. Feb 12, 2018 at 7:34 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Go get known or fluid film, and do it yearly. It will protect well and is much cheaper and better than the undercoating crap the dealer wants to sell you.
  11. Feb 12, 2018 at 7:38 PM
    rdjr17
    rdjr17 Well-Known Member
    Ron
    Nepa
    2019 voodoo blue Trd pro
    I have a question about the fluid film , if its oil based dosnt it attract salt to the frame . I've always kept my truck clean at least go to spray car wash once a week and touchless spray every two weeks to get underneath good . then first warm dry week in spring I go under the truck with wire brush to scrape surface rust and spray three coats of rustolium satin black .
  12. Feb 12, 2018 at 7:41 PM
    Riding Dirty
    PlastiDip
    After applying fluid film, drive down a dusty road. It will coat the fluid film, anything that sticks to it after that will easily rinse away. The salty stuff may coat, but like mud, will rinse off but without actually touching the metal. The film keeps water and salt off the metal surfaces.
  13. Feb 12, 2018 at 7:43 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I used this Cavity Wax Spray on the Frame and Underside of my Truck, been thru a lot of salt and sprayed off a couple times at the car wash and everything looks fine. I figured I will continue to use it and spray everything down once a year and should be good to go.
  14. Feb 12, 2018 at 7:50 PM
    rdjr17
    Ron
    Nepa
    ok , dealer sprayed my truck when I bought it not sure what was used , looked like wd 40 its was wet then just dryed up after two days . went under truck last week when it was 50 out and didn't see any rust on frame or rear so what ever they used worked pretty good .. I'll try the fluid film this year seems,lije theres good reviews on it
  15. Feb 12, 2018 at 8:01 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Get it rust-checked at silver city tire in Oneida, it's similar if not the same as fluid film from what research I've done. Way cheaper and better than rubberized undercoating from ziebart.
  16. Feb 12, 2018 at 8:04 PM
    FFBlack
    2019 TRD OFF ROAD
    I tried fluid film on some impact sockets in my tool box drawer and a few weeks later they were all rusted up. It smells terrible all so. The body cavity frame wax is the way to go. We called it frame and body butter. It held up for Years and nothing stuck to it. Shaker knows the real deal. That fluid film couldn't even protect my sockets , I wouldn't waste my time in my truck where it gets exposure to the elements.
  17. Feb 13, 2018 at 7:16 AM
    Toyko Joe
    https://www.garagejournal.com/forum/showthread.php?t=266327
    Post #15
