Factory Security System Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by BondoBuilder, Dec 13, 2011.
  1. Dec 13, 2011 at 3:45 AM
    BondoBuilder [OP] Member
    Nov 23, 2008
    I just picked up a lightly wrecked 1998 Tacoma from a kid. He attempted to do his own maintenance and mechanic work, but ended up causing more headaches in the end, ie: tune up with loose plugs and mixed up wires, head unit/amp install with 18 wire...
    Regardless, if I have the door open for more than 15 seconds, the security system is set off: lights blink and the horn sound.
    I had a 1999 PreRunner for 2 years, and never had this issue. Is there an adjustment to fix this, or a fuse or relay that I can remove to completely eliminate this security system? I don't even lock my house, let alone my car... I'm not too concerned about theft in my area.
    Thanks in advance!
