Factory security system
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Garrett75x, Mar 4, 2017.
  1. Apr 17, 2017 at 8:55 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Limited should have the factory alarm AFAIK. Glass breakage sensor is an add-on though.
    On my OR I tried the following a while ago: Window down, then I locked doors and waited until the light started flashing to show the alarm had armed. I forget whether the alarm went off (horn honking) when I reached in and unlocked the door or when I actually opened the door. Either way, it made plenty of noise.
    Easy for anyone curious to test their own truck. Key is to wait the 30 seconds or so until the system arms (light starts flashing).
    Since yours made no noise, I believe it either it was defective or you maybe didn't lock the doors. Factory alarm doesn't auto-arm. I don't know if that's a changeable setting like it was on my old 4Runner. Hasn't been an issue for me, and if I'm ever unsure I just send a lock command via SmartStart.
  2. Apr 17, 2017 at 10:22 AM
    TravoHTX
    TravoHTX 2017 TRD OR
    Travis
    Westminster, Colorado
    Doors were definitely locked, they wouldn't have had to break the window if they weren't. Idk what the deal was. My new alarm has a Viper 2-way pager so if the alarm goes off the pager starts beeping
    NIU_Huskies likes this.
  3. Apr 17, 2017 at 10:25 AM
    gpb
    Atlanta
    As easy as it is to break a window, and as often as I've heard of broken windows on unlocked vehicles, I wouldn't necessarily assume a broken window means it was locked. :D
    Regardless, sorry it happened. Had a window busted and stuff stolen from my 4runner years ago. Really sucks.
  4. Apr 17, 2017 at 10:28 AM
    Mark_R
    Mark_R Well-Known Member
    Mark
    2016 Toyota Tacoma TRD Off-Road
    I'll have to try this. This morning while I was in my truck with the engine off I locked all my doors. Then I waited about 10 seconds and opened the door, and nothing happened. I am assuming I didn't wait long enough. I am going to go out at lunch and roll down my window, lock it up via the FOB, and then wait 30 seconds and reach in and opens the door. I'll report back with what happens. BTW I have a 2016 TRD OR AC.
  5. Apr 21, 2017 at 6:11 AM
    gpb
    Atlanta
    Following up. Just had a chance to test it again.
    Opened the driver's window and locked the truck. Walked away and waited for the security light to start flashing, 30 seconds or so.
    I reached in the window and hit the manual unlock on the door.
    The truck immediately started blaring the horn and flashing the lights.
    Factory alarm seems to be doing its job.
    BTW, since I have a remote start and DEI SmartStart module installed, it alerted me of the facotry alarm going off. Cool. (D2D references the data interface)
  6. Apr 21, 2017 at 9:33 AM
    trrn11500
    trrn11500 Well-Known Member
    If you have the factory alarm i am assuming all you would have to add is the glass breaking sensor am I correct?
    Can you just add this sensor to a 2017limited.
  7. Apr 21, 2017 at 11:45 AM
    gpb
    Atlanta
    I believe so, and I believe so. GBS sensor occupies one of the empty switch locations left of the steering wheel I believe.
    That said I have no idea how good it is or isn't.
  8. Apr 21, 2017 at 1:32 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    https://www.toyotapartsdeal.com/installation/my16 tacoma rs3200 plus issa.pdf
    RS3200 info for 2016 Taco. This is the entire kit PT398-35160 which includes GBS sensor.
    The GBS sensor is adjustable, see p. 10. The GBS microphone is inserted into the dash panel to left of steering wheel, see p. 14. No telling if the GBS ECU and mic can be ordered separately.
    Techstream is used to turn the system from 'off' to 'on', see p. 19
  9. Apr 21, 2017 at 2:37 PM
    gpb
    Atlanta
    Good find. I searched briefly, but didn't run across it.
    Looking at the linked PDF and the kit contents, this seems to be just the GBS ECU and associated bits and pieces. i.e. it's the Glass Breakage Sensor add on to the factory alarm.
    BTW, the TRDs (presumable all the PTS Tacos) already have the hood switch installed. Pop the hood and see if it tells you about it in the instrument cluster. :)
    $99 isn't bad... I hadn't thought I needed this, but for $99 it might just be worth it... https://www.amazon.com/Toyota-PT398-35160-Intrusion-Protection-Security/dp/B014JF36QQ
  10. Apr 21, 2017 at 3:24 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I think this is the one I was trying to think of before sir..
  11. Apr 21, 2017 at 3:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    Ignorance. Fancy truck, double din, should be awesome in my clapped out Corolla. All Toyota parts interchange, right?
    gpb[QUOTED] likes this.
  12. Apr 21, 2017 at 3:30 PM
    trrn11500
    I see no wiring in that kit?
  13. Apr 21, 2017 at 5:28 PM
    trrn11500
    i ended up[ ordering the one for 99 bucks. It was the lowest price anywhere. this is the correct one to order of you have a factory alarm. i just don't know why toyota gives you an alarm but leaves out the glass breakage sensor.
  14. Apr 21, 2017 at 5:51 PM
    CXP8PRO
    CXP8PRO Well-Known Member
    Andrew A
    17' TRD PRO Super White
    I also just tested if my pro had a factory alarm, and it does :bananadance:. Didn't know it came with one. Another awesome reason for joining this forum. I've learned so much so far. Now i just need to add that glass breakage sensor you'all talking about.
  15. Apr 21, 2017 at 6:10 PM
    #35
    Garrett75x
    Garrett75x [OP] Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Did you take it to the dealership or did you have it done before you picked up the truck?
    For $150 I might just take it to them
  16. Apr 22, 2017 at 10:13 PM
    #36
    Swiftks
    Swiftks Well-Known Member
    Spring, TX
    2016 TRD OR
    Bilstein 6112 (front) Bilstein 5160 (rear) Headstrong Progressive AAL ShiftSense Pro SumoSprings BakFlip F1 Tonneau Cover BAMF Grille aFe intake w/ scoop Custom Exhaust - URD Y-Pipe, Vibrant Ultra Quite Resonator & MagnaFlow Muffler 4Runner TRD Pro 17" Wheels Wrangler DuraTracs - 265/70R-17 Redline Hood Struts OPT7 LED Headlights (Highs & Lows) Baja Designs Squadron Pro Fog Lights LED Interior Lights Total Chaos Bed Stiffeners TRD Pro Skid Plate TRD Pro Tail Lights TRD Pro Shift Knob @CBoy808 Custom Bedside Decals FormulaOne Pinnacle Window Tint OEM Tacoma Bed Mat OEM Tacoma All Weather Floor Mats Fumoto Valve Amsoil Fluids
    I had it done a day or two after I purchased the truck.
  17. Nov 10, 2018 at 9:36 PM
    #37
    N8iV Warrior
    N8iV Warrior Well-Known Member
    Johnny
    Indian Reservation Not by Choice
    07 Silver Dble Cab Trd Sport 6" fabtech lift
    6" Fabtech lift, 34" tires , AFE Cold air intake, Cobra wxst75 cb, Rocky Mountain Radar, L.e.d Headlights, L.e.d maplights,dome light, license plate lights, Tinted frnt windows 35% to match rear windows. ARB bumper with XD-9000 Warn Winch, Pro-Tech HeadAche rack with Pro-Tech Toolbox, Icon Front Coilovers for 6" Fabtech lift, Blacked out Taillights PIAA plasma ION 520 Lights, AFE CAI Pro Dry S Filter, 22" Led light bar, Yakima Mega Warrior basket
    I just tried my Tacoma it’s an 2007 trd sport and the alarm didn’t do crap. Just the blinking light, locked the doors with unrolled window reached in and didn’t do anything. Also sat inside and locked doors and didn’t do anything either. What gives? Is my truck able to add glass breakage kit too?
  18. May 2, 2020 at 10:29 AM
    #38
    DTOM TACO
    DTOM TACO Well-Known Member
    2018 Black Tacoma Trd Sport
    New door speakers and an all in 1 10in. Sub, bed cover, bed stiffeners, new grill, tailgate inlays, Mat black emblems overlays, new led map and dome lights, plenty more in the plans.
    I did this too with my 2018 Trd sport and I got nothing aswell. A buddy of mine asked if I had my keys on me when I did this and I did. I tried it again but I took the keys into the house and away from my truck. Upon opening the door the alarm went off. I’m not sure if this would make a difference for you but it might help.
  19. May 2, 2020 at 11:09 AM
    #39
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    Have to see if I can add a pic, but do you have the "Toyota Auto Alarm" decals on your front door windows?15884428787943028871924471296021.jpg
  20. May 2, 2020 at 2:13 PM
    #40
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I don't believe you can use this on MTs.
