factory steering rack - where to buy?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sundowner, Aug 3, 2015.
  1. May 28, 2018 at 6:40 AM
    #41
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Also if your fluid level is dropping there’s a leak somewhere which you should be able to find. If there’s no leak visible and you’re not losing fluid I would lean towards a bad pump or maybe a rack that’s starting to fail it can be tricky to pinpoint
  2. Jul 13, 2019 at 1:15 PM
    #42
    FruitCakeBlake97
    FruitCakeBlake97 Active Member
    Blake
    Montgomery County, PA
    2006 TRD 6 Speed
    3 inch Toytec FN Five Stars URD short throw shifter
    Anyone knowledgeable on the 1A Auto steering rack. It costs $235. Probably just another chisnese pos?
    Running Board Man likes this.
  3. Jul 13, 2019 at 6:20 PM
    #43
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Try Detroit Axle on Ebay - Good Parts at least everything I've bought
    #43
  4. Aug 31, 2019 at 2:16 PM
    #44
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    I assume their reman axles are good?
    #44
  5. Aug 31, 2019 at 5:52 PM
    #45
    00_5VZ
    00_5VZ Dumbest smart guy you’ll ever meet
    Rob
    Thornton, CO
    2004 DC TRD, S/C, Impulse Red Pearl
    TRD S/C, URD 7th injector, Deck plate mod, gray wire mod, 2 low mod, magnaflow cat back exhaust
    I’ve used rackdoctor.com for my last 2 racks I’ve bought in my 2000 and 2004 Tacoma’s. They give you an option for outer tie rod ends to be included, and the have an option for poly rack bushings. Oh, and if you send your code back within 40 days the rack has a lifetime warranty. I paid $420, and I got outer tie rod ends and poly rack bushings.
  6. Oct 3, 2019 at 6:53 PM
    #46
    99SRP2.7
    99SRP2.7 Member
    Tate
    1995 2.7 Reg Cab 4wd
    @GeoYota65
    Pulling this from test dead but any issues with the cardone rack yet??
  7. Oct 6, 2019 at 2:49 PM
    #47
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    No...I sold my 03' Tacoma in May of this year, but up to that point the Cardone had performed flawlessly.
  8. Aug 24, 2021 at 2:06 PM
    #48
    coldaccord
    coldaccord Well-Known Member
    André
    Buffalo, NY
    2000 Tacoma 3.4L 4x4
    My rack has play. Vibration at certain speeds and you can feel it moving when parked. New urethane rack bushings, inner and outer tie rods, and ball joints.
    Looks like OEM is the best bet, aftermarket options look meh. Rebuilt oem sources seem hit or miss (unless anyone has one they'd recommend).
    I have an account with my local Toyota dealer, my cost is $571 new, seems close to elsewhere.
    My question is this: if I buy a new rack for my truck from the dealer, will it come with the updated rack guide? Or would I have to ask for a rack for an 01-04 (presuming the racks are compatible)?
  9. Aug 24, 2021 at 3:03 PM
    #49
    GillyMac
    GillyMac Well-Known Member
    Albert
    2004 White Tacoma Xtracab V6
    If you haven't yet seen this yet it's probably worth the 20 seconds of your time to check for play in the slip joint on your steering column.
  10. Aug 24, 2021 at 3:09 PM
    #50
    coldaccord
    André
    Buffalo, NY
    Thank you, I have. One person JB Welded it so as to retain the collapsibility in case of an accident, I liked that idea.
    I just ordered the updated rack guide, going to start there first. Thanks
  11. Aug 25, 2021 at 7:41 AM
    #51
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    When I replaced the rack this spring, I bought a new OEM rack from the local dealer. It came with ITREs but not OTREs, so I also bought those as well. Total cost was around $600 ($510 rack & $45/OTRE), and there was no core on the rack because it was new not a reman. All new OEM racks from Toyota have the updated rack guide, and it should be compatible with all 1st Gen 6-lug trucks.
    When you factor in the additional cost of an alignment and your time, it doesn't make as much sense to go with a cheap(er) aftermarket reman rack. If it fails, the cost to replace it again (even if the rack is covered under warranty) almost adds up to the new OEM rack, not to mention the cost of the updated rack guide if you're unlucky enough to get a reman with the older-style guide.
    That's just my $.02 on this. I try to get OEM parts where it makes sense (steering, front brake pads/rotors, engine oil filter, etc) and go with a decent aftermarket version where OEM cost is too high or the replacement time is quick (NAPA for CV axles & S13WL calipers).
    Ritchie and coldaccord[QUOTED] like this.
  12. Aug 25, 2021 at 8:32 AM
    #52
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    ^^ Agreed.
    Simply said, I was tired of the whole rack garbage and SAC'd. Old school Toyota solid axle stuff works.
    RattleTractor likes this.
  13. Aug 25, 2021 at 8:43 AM
    #53
    coldaccord
    André
    Buffalo, NY
    Given that my truck is a 2000 I'm going to try replacing the rack guide first!
  14. Aug 25, 2021 at 8:53 AM
    #54
    RattleTractor
    Harry
    VT
    I agree with your position, wise sir. If only I could justify that too, but I don't crawl the truck and I spent all my fun money on a GFC.
    Definitely worth a try. I recommend saving the packaging & old guide, then driving around for a day to see if it fixes things. If it doesn't you can swap it back, return the new guide parts (cost about $100 IIRC), and just get the new rack instead.
    Even though I have an '04 with the updated guide, I did this before swapping the rack as well just in case it fixed the play on the driver's side. It didn't so I went with the new rack, but if it had then I'd have saved $600+.
