Factory stereo difference?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spparmy, Aug 21, 2015.
  1. Aug 21, 2015 at 5:39 AM
    Spparmy
    Spparmy [OP] New Member
    09 Tacoma double cab
    I had my young nephew decide that my truck stereo must have been a jukebox and drop a couple coins in the CD player. Needless to say the stereo doesn't work now. I want to replace it with a factory deck but my local junk yard doesn't have the same serial number of stereo. My question is does it matter which stereo goes in? Or are they all compatible?
  2. Aug 23, 2015 at 3:59 AM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    the same type radio should work just fine
    the thing you need to check is whether or not you have a truck with JBL from the factory or not
    the other thing you might try is take your stock radio out and have a radio repair shop take the change out and test it ... might be just fine
  3. Aug 25, 2015 at 5:47 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Just buy a aftermarket Navigation/stereo. They're reasonably priced and should fit right in
    Dj Suisav likes this.
  4. Aug 25, 2015 at 6:01 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Is it just the CD player, or the whole radio that doesn't work? Had the coins been removed??
  5. Aug 25, 2015 at 7:53 AM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
  6. Aug 25, 2015 at 8:02 AM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    Perfect excuse to justify an aftermarket stereo that will add features and improve sound quality...and it would be probably be the cheaper route too if you end up needing to buy one from the dealer. They are easy to install, and you can keep all of your steering wheel controls. If you don't want to do that, take it to a car audio shop and see if they can repair it or order new parts for it.
  7. Aug 25, 2015 at 10:06 AM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    I remember hearing somewhere that the 2005-2008 head units are slightly different from the 2009-2011, due to the addition of the aux plug in the lower console. I briefly looked into swapping a 2009+ into my 2005 for the addition of the aux and fitment, but decided to do aftermarket in the end.
    Not sure if this is 100% true, so hopefully someone can answer for sure?
  8. Aug 25, 2015 at 10:18 AM
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    If you go aftermarket, you can add bluetooth. That right there would be enough for me to start looking. I prefer Pioneer but there are many good options. I'm keeping stock on mine but as it's a 15, I have bluetooth standard.
  9. Aug 25, 2015 at 11:06 AM
    tgear.shead
    tgear.shead Well-Known Member
    CD player? Whoa, ancient technology.....
