Factory supplied oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scwowgph, May 23, 2019.
  1. May 23, 2019 at 10:04 AM
    btcca4
    btcca4 Well-Known Member
    Guilty as charged..
    tonered likes this.
  2. May 23, 2019 at 10:16 AM
    btcca4
    99% agree with that statement.. Mobil1 is not what it used to be. Ever since the Castrol / Mobil lawsuit, the "synthetic" lines have been blurred beyond recognition. My opinion, Mobil1 0W40 "European Formula" is probably the last of the great synthetic oils though.. The VW 502.00 spec is extremely stringent in that only an extremely synthetic oil can be approved. The same goes for any other mfg's that meets that spec.
    Stocklocker[QUOTED] likes this.
  3. May 23, 2019 at 10:30 AM
    btcca4
    Isn't that Group V oils? (Ester-based) RedLine, Motul ect..
  4. May 23, 2019 at 10:39 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Could be? I need to look into it further. The need for conventional oil to support the additive package was 15yr old info stuck in my head. That was why I asked.
  5. May 23, 2019 at 10:49 AM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
  6. May 23, 2019 at 10:54 AM
    btcca4
    To make matters even worse, "Fully Synthetic" & "100% Synthetic" mean two completely different things now. That's why all the oil on the WalMart shelf says "Fully Synthetic", while Amsoil & other high end oils claim "100%" on the bottle. Two different meanings now..
    Paul631 and tonered like this.
  7. May 23, 2019 at 11:13 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The crux of the matter is, no normal human knows what is good or what is not good. We are told “synthetic is good” so we go along with that. If some different society claimed “synthetic is bad”, we’d go along with that as well.
    The ONLY thing that matters is approvals and ratings, and perhaps test results, which are the tools we use to cut through the marketing and assumptions.
    As I mentioned in another thread on a different subject, many extremely expensive and complex electrical devices I work on require Lanolin (sheep oil)-based greases in their critical mechanisms as certain properties of Lanolin exceed the properties of ones we can manufacture from petroleum.
    Spider silk is also a good example of a natural product with extreme properties of strength that cannot easily be replicated by humans from other base stocks. If you could have a spider-silk winch cable, it would beat out dyneema rope.
    Synthetic / Fully Synthetic / 100% Synthetic. I don’t really care about those terms as long as the oil in question meets the specified requirements, and I have confidence I’m not being lied to. Past that, it’s just a case of “choose your favourite label”.
    tAcomaPueblo, AKGSD, tonered and 2 others like this.
  8. May 23, 2019 at 11:31 AM
    Paul631
    In addition the 2GR and 2TR aren't exactly special care & feeding performance engines (e.g. high boost, 100+hp/cylinder); use any oil the meets the spec requirements and you'll be good to go.
    TacomaSport86, btcca4 and Stocklocker like this.
  9. May 23, 2019 at 11:38 AM
    Paul631
    But I would love to know how toyota and other brands maintained engine longevity while using less viscous oils.
    I'm guessing closer tolerances, increased oil pressure, and using vvti and programming to possibly cut power at lower rpm to counter the lower oil shear strengths?
    Interesting interview re: upcoming oil vis oils:
    https://noln.net/2017/06/30/skinny-ow-16-oil/
  10. May 23, 2019 at 11:39 AM
    btcca4
    Absolutely agree! When it is all said & done, any quality oil will work in our engines at a 5K oil change interval. No way on 10k! (IMO)
    I'm not touching the service interval subject on a Thursday :):):):)
    tonered likes this.
  11. May 23, 2019 at 11:44 AM
    Paul631
    And what about the "10k for the oil may be fine, but can the filter maintain efficiency throughout the interval and not go to the bypass valve" debate (another Friday oil thread idea :anonymous:
    tonered likes this.
  12. May 23, 2019 at 11:53 AM
    btcca4
    Just like you have a boss, Toyota has a boss too. It's called the EPA. Toyota & other mfg's guarantee the engine with the approved oil (TOO THIN) for it's warranty span, not a mile over. Read between the lines & use common sense on what you need to do.
    That's another hornets nest of a subject for a Thursday. :):):):)
  13. May 23, 2019 at 12:02 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Well. Let's not go that far. If Taco motors were puking their guts out at 60,001mi, Toyota would ripe for an FCA buyout. Hell, if 1% of Taco motors puked their guts out at 60,001mi . . .
    btcca4[QUOTED] likes this.
  14. May 23, 2019 at 12:06 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    lol 176,000 on my rarely do I change the oil motor
  15. May 23, 2019 at 12:14 PM
    #35
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I was told this is the help group for Toyota owners who don’t obsess over oil?
    I started noticing the signs about a few years back, when people would routinely fight over oil quality and intervals. It’s almost as if... as if...
    I didn’t care. Oh god it feels so good to say it out loud.
    OEM filters, the grade the manual calls for, and anywhere between 5k and 10k whenever the mood strikes.
    Stocklocker and tonered like this.
  16. May 23, 2019 at 12:16 PM
    #36
    stun gun
    Aaronski
    Tacomas.
    This. I have a Toyota...where the engine still runs after 20 years with an abusive owner who rarely changed oil.
    tonered likes this.
  17. May 23, 2019 at 12:18 PM
    #37
    btcca4
    I'm weak.. I can't help myself. :D
    tonered and stun gun like this.
  18. May 23, 2019 at 12:19 PM
    #38
    stun gun
    Aaronski
    Tacomas.
    Come, brother. We’re in this together.
    tonered and btcca4[QUOTED] like this.
  19. May 23, 2019 at 12:45 PM
    #39
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Pick up some Sequoia oil at your local qwik mart:
    Paid 50 cents a qt and still have several cases, also have some property in AZ if yor interested.
  20. May 23, 2019 at 12:49 PM
    #40
    Paul631
    btcca4, tonered and MtnFisher like this.
