Factory Susp. Larger Tire
Discussion in '3rd Gen. Tacomas (2016-2023)' started by red-white-&-paps, Oct 4, 2018.
  1. Oct 4, 2018 at 11:39 AM
    red-white-&-paps
    red-white-&-paps [OP] Member
    2018 Quicksand
    Hey everyone,
    I'm looking to swap my wheel and tires.
    Honestly, pretty set on Black Rhino Armory 17x9.5 -18mm wheels. But still looking for tires.
    https://www.blackrhinowheels.com/off-road-wheels-rims-armory.php
    I want to keep the factory suspension at least for the time being, what are you guys running if you have a similar set up and still allowing enough room for tire movement over difficult terrain?
  2. Oct 4, 2018 at 11:40 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    265/70/17
    Savage1978 likes this.
  3. Oct 4, 2018 at 11:43 AM
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    With those wheel specs, even with a smaller (265/70/17) you will rub on stock suspension.
    CoastieRon likes this.
  4. Oct 4, 2018 at 11:49 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Yep. I went with 265-70-17 on a 17x8" zero ET and the fronts rubbed on the OEM mudflaps at half turn (or a little further) with the stock hitachi suspension. You can take them off, but if you are "articulating" and turning, you will stuff the tire.
  5. Oct 4, 2018 at 11:50 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    255/75/17 may fit with mudflapper removal
  6. Oct 4, 2018 at 11:51 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    They would still rub and woukd look stretched on that size wheel.
  7. Oct 4, 2018 at 11:54 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Ohhhh :fistbump:
  8. Oct 4, 2018 at 11:56 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    :drunk:
  9. Oct 4, 2018 at 11:57 AM
    red-white-&-paps
    2018 Quicksand
    Well then shit. Anyone know any wheels that have a similar style and would allow large more off road appropriate tires?
    (I sound like a guy that only cares about looks, but promise I don't. HA)
  10. Oct 4, 2018 at 11:59 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    What do you care about more?
    A) Fitting the tallest tires?
    B) Fitting the fattest tires?
    C) Fitting wheels/tires that poke out?
    D) A combination of the above?
    MattCowsmasher likes this.
  11. Oct 4, 2018 at 12:01 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    265/70/17 in a beefy AT will work great an allow full articulation of the stock suspension. Plenty of folks running one sized bigger tire an do knarly wheeling just gotta pick your lines carefully.
  12. Oct 4, 2018 at 12:02 PM
    red-white-&-paps
    2018 Quicksand
    D?
    I'm a autocross guy finally getting his first truck and wanting to get into off-roading out here in the Southwest. So looking for clearance and grip in all sorts of terrain.
  13. Oct 4, 2018 at 12:03 PM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
  14. Oct 4, 2018 at 12:05 PM
    ZYBORG
    TX / S. FL
    3G TRD OR
    Well, you can get those same wheels in the same size but +6 offset. Which should allow you to fit the 265/70/17 without rubbing.
  15. Oct 4, 2018 at 12:13 PM
    red-white-&-paps
    2018 Quicksand
    Wow, I didn't even see the +6 on the chart on their website.
  16. Oct 4, 2018 at 12:15 PM
    ZYBORG
    TX / S. FL
    3G TRD OR
    Now keep in mind that offset does impact “the look”. IMO, +6 will not look as aggressive as -18.
    You can run the -18s, will just have to trim. Possibly align to max caster.
  17. Oct 4, 2018 at 12:31 PM
    red-white-&-paps
    2018 Quicksand
    had to refresh my knowledge on offset for a second...
    How would a -18 rub suspension but +6 wouldn't?
  18. Oct 4, 2018 at 12:34 PM
    ZYBORG
    TX / S. FL
    3G TRD OR
    It doesnt rub against the suspension. It can rub against the inner fender well and cab mount when you turn.
  19. Oct 4, 2018 at 12:41 PM
    red-white-&-paps
    2018 Quicksand
    ahhhhh..
  20. Oct 4, 2018 at 12:43 PM
    ZYBORG
    TX / S. FL
    3G TRD OR
    Yep.
    Too much positive and you can run the inside of tire against suspension components. Too much negative and you can rub outside of tire against fender/cab mount.
    0 tends to be comsidered a good happy medium. It sits basically flush with the fender.
