Factory tachometer instrument cluster conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by bambbrose, Apr 6, 2010.
  1. Apr 6, 2010 at 12:28 PM
    bambbrose
    bambbrose [OP] Active Member
    n/a
    I just purchased a 2002 Tacoma Base 4x4 4cyl and I love everything about it except for the fact that it doesn't have a tachometer.
    I want to convert to the TRD style white face gauges or similar.
    So here are my questions. Assume the mileage is the same on all clusters. I understand all legality issues.
    -What instrument cluster types are compatible? Are only 4cyl 4x4 models from 01-04? what about v6? 4runners? Any info on years & models that work is helpful.
    -What year did the white face amber lit clusters begin? Are they only on V6 TRD or are there 4cyl ones?
    -What is the 3RZ redline at?
    -Are all models prewired? I don't mind if the wiring is complicated.
    -Lastly, what clusters have electronic odometers and what ones are mechanical still? Are the electronic ones programmable? I found that the mileage is indeed stored on the cluster eeprom, so I just need to know if a dealer or similar can reprogram it to match my truck.
    Pics and info greatly appreciated.
    Thanks!
  2. Apr 8, 2010 at 1:02 PM
    bambbrose
    n/a
    anybody?
  3. Apr 8, 2010 at 1:10 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Im pretty sure 4cyl & 6cyl are different. The wiring plugs in. Thats about all I know. Maybe try a wrecking yard? Try this place for used parts info, LKQ/Keystone: 800-525-3667 Im in So Cal, but I believe they are all over U.S. Wish I could help you more
  4. Apr 9, 2010 at 9:37 AM
    REDSEAWATACO57
    REDSEAWATACO57 Active Member
    Chanh
    seattle,wa
    19 Toyota Tacoma Dbl cab TRD
    Modded
    They should be pre-wired for tach. Just find a cluster from 01-04 and install it. Did this to a civic dx with no tach and installed a cluster from a ex with tach and it worked fine. All cars manufacture pre-wrie
  5. Apr 9, 2010 at 4:58 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    the 3rz redline on the tachometer is at 5,500 rpm, i think it cuts spark/fuel or whatever at 6k.
    The newer, modern white faces start at the new interior style (2001).
    I have a 99 and the odo is digital so i'm supposing 98 is the first year for that or maybe even all taco's have digital.
  6. Apr 9, 2010 at 5:01 PM
    h_curtis
    h_curtis Well-Known Member
    If it were me, I would ad a tach and not mess with the dash. It can be done tastefully and it would be much easier. You could probably get one anywhere. Summit or the like. Easy install too.
  7. Apr 11, 2010 at 9:21 AM
    krlang
    krlang NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    Hmmm,
    I have been wanting to do the same, but there arent many going to the junkyards here.
    Another big dilemma of the rust recall. :mad:
