Factory Tank Average Gas Mileage Calculation Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frank_Zuccarini, Oct 3, 2018.
  1. Oct 3, 2018 at 12:56 PM
    Frank_Zuccarini
    Frank_Zuccarini [OP] Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Out of simple curiosity, does anyone know how the truck 'knows' that I have put fuel into the tank, so that it begins a new Tank Average MPG determination?
    Does it register that I have removed the gas cap, and thus infer that I have refilled the tank?
    Is there a gas tank scale that, if it sees the weight increase, infers that I have refilled the tank?
    What prompted my question is that I recently added only one gallon of gas from a can, and the truck started recalculation my tank average MPG.
    Anyone have any insight?
    Thanks................... Frank
  2. Oct 3, 2018 at 2:15 PM
    Fett85
    Fett85 Well-Known Member
    Ohio
    2021 Tacoma TRD Off Road 4x4
    I have had it where I added just a gallon or two and it didn't reset (I was curious), so there has to be a sensor in the tank and I was just filling the fill tube.
  3. Oct 3, 2018 at 3:50 PM
    Frank_Zuccarini
    Frank
    Chicagoland
    Thank you. That's what I wanted to know.
    Frankly, I'm surprised that this method can work, since gas is always sloshing back and forth, and the one gallon that I added has to be nearly perceivable by a float mechanism. But I guess that this is the simplest way to do it.
    Thanks for your help.................... Frank
  4. Oct 3, 2018 at 4:03 PM
    DanRN
    DanRN Member
    Daniel
    Southern CA
    2018 MGM Tacoma TRD Sport 4x4
    Its most likely a sensor placed in the tank. Its probably on a bobble style to know when it moves.
  5. Oct 4, 2018 at 8:47 AM
    Jeremy4x4
    Jeremy4x4 Zero frucks given
    2017 sr5 4x4 double cab
    3by2 level kit 285 70 17 nitto tires,
    Float in tank connected to sending unit
  6. Oct 4, 2018 at 9:30 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There used to be a BMW mechanic on here, he had a car hooked up to a diagnostic unit and the car showed the date that gas was put in and also showed the grade, no idea if our Trucks go that deep.
