Factory tires suck or is it just me
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BackcountryTacoma, Feb 7, 2022.
  1. Feb 7, 2022 at 7:19 AM
    BackcountryTacoma
    BackcountryTacoma [OP] Member
    21’ Trd Pro
    A lotta stuff ;)
    I had my second flat tire yesterday. I Drive dirt roads and gravel roads a lot. I’m at 20,000 miles on the factory tires. Is that about all they’re good for mileage wise.
  2. Feb 7, 2022 at 7:30 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Need more details. How did the tires fail?
    You have a PRO so assume your truck came with the Goodyear Kevlars... they shouldn't fail that early on gravel roads.
    DingleTower likes this.
  3. Feb 7, 2022 at 7:31 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Well, constant driving on dirt and gravel roads can be pretty rough on a set of tires especially if you have 20K on them already.
    ColdTaco49 likes this.
  4. Feb 7, 2022 at 7:33 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    The factory tires aren't that good for sure. But they shouldn't "fail" that soon. What caused the flat? Tires don't usually just go flat.
    I had two flats on a set of tires that were maybe 200miles old. Both were from roofing nails. That's not a "fail" just shit luck.
    I moved the tires from my Pro to a truck that is pretty much exclusively driven on gravel. No issues.
  5. Feb 7, 2022 at 7:33 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    We can't help you when you give us a vague statement.
    Does that road have jagged rocks?
    Broken pieces of metal?
    Are there nails on the road or other sharp debris?
    Do you drive by or through construction sites?
    Have you hit anything hard recently; causing a bent rim?
  6. Feb 7, 2022 at 7:34 AM
    Hawkijustin
    Hawkijustin Member
    What’s causing the flats? Is it nails, cuts from rocks? Soooo much info left out here that it’s hard to unpack. You could switch them out for 10 ply tires and you won’t get as many flats but you will probably be back on here asking why your gas mileage now sucks just like everyone else who puts on 80lb tires
    blaklabl likes this.
  7. Feb 7, 2022 at 7:34 AM
    Coyote501
    Coyote501 Well-Known Member
    Ohio
    2019 Barc Red AC
    And stock tires could one of a few different brands. My Toyos are great.
  8. Feb 7, 2022 at 7:41 AM
    BackcountryTacoma
    21’ Trd Pro
    A lotta stuff ;)
    Rims are not bent. Roads are crushed granite and regular gravel. My average speed per Garman is 29 mph. There are a lot of potholes. I slow down some. But it’s not nails. No construction site. I work in the Oil field. Mostly just piercing in the tire like through the rubber. I’m guessing it’s the rock. But the tread is not very deep on these anyways compared to normal all-terrain tires. They definitely have worn pretty fast.
  9. Feb 7, 2022 at 7:41 AM
    klatekin
    klatekin Active Member
    2017 MGM TRD OR 6MT
    Bad luck?
    skidooboy and Montana_Actual like this.
  10. Feb 7, 2022 at 7:42 AM
    cts528
    cts528 Well-Known Member
    Northern MA
    2017 TRD Off Road
    My Goodyear Kevlar tires that came with the truck were BALD at 34K. Absolutely disappointed with them, especially being rated for 60K. The truck is a daily driver, tires always rotated, never abused. The only good thing is Goodyear gave me a hell of a discount on brand new Duratracs that have been on for 35K and still have 3/4 tread on them. Something was up with the stock tires.
  11. Feb 7, 2022 at 7:45 AM
    Borracho Loco
    DFW, Texas
    My best guess: When you hit that pothole, you are popping the tire off the rim (the seal wasn't great when it came from Toyota), thus causing a slow or fast leak. That leads to your flat tire. As for the tire tread being shitty, well...join the club.
  12. Feb 7, 2022 at 7:53 AM
    BackcountryTacoma
    21’ Trd Pro
    A lotta stuff ;)
    My apologies guys. I have to hit 50 posts per forum rules to buy/sale on the forum. Unfortunately I am well versed in using the search bar. But I have to reach 50. when I get home I’ll make feedback threads on Wescott lift,Kdmax pro tune, Doug thorley y-pipe, injen evolution intake, recgen mudflaps, beatsonic phone mirroring kit, replacing factory speakers, adding sound deadner in doors, gator hard tri-fold bed cover, total chaos bed stiffeners, offroam cell phone mount, radio screen protector, mirror dongle that allows USB plug-in, and every other mod I have done. I’ve never been one to ask questions. I actually take joy in searching and finding the answer myself. I moderate a charger board with 20,000 members. I don’t require a 50 post. We have a good/bad feedback page. And I like to drop the ban hammer. Makes it much easier than someone having to spend hours making 50 posts that actually makes sense. Because if I spam posts that don’t make sense I’ll probably get banned. So I will ask Thoughtful questions. But I already know the answer because I search for it when I thought of it. I am currently waiting on some 265/70/16 BFG trail terrains coming Wednesday. Thanks
  13. Feb 7, 2022 at 8:12 AM
    Lambo9418
    Lambo9418 Well-Known Member
    JP
    Black 2019 TRD Pro
    This is interesting... I have just over 34,000 on my stock tires (Goodyear Kevlars 265/70R16) and have found myself looking at the treads recently wondering why they look almost bald. Did you get new tires / Goodyear discount through the dealer or by other means? And did you stay with 265/70R16 or change up? (I've already been thinking of moving up to 265/75R16 when it's time for new tires) Thx
  14. Feb 7, 2022 at 8:17 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Im at 26k right now and while not bald, my tires are trash now in the snow. I will slip and slide all over on dry pavement too because the snow sticks to the tires.
    Going to get new tires in the spring.
    shakerhood likes this.
  15. Feb 7, 2022 at 8:18 AM
    cts528
    Northern MA
    2017 TRD Off Road
    I called Goodyear direct and had them set up a time and place close to me to have them looked at by a dealer. They need them to be evaluated before they make a call. I had my service records from the dealership for the first 25K, with all the tire rotations on them, so they couldn't dispute them being rotated at the correct intervals. The dealer measured the tread and called Goodyear with a claim number, had the guy approve the discount right then, and I got new tires installed in an hour. I stayed with the stock size for now, but I could have gone larger. They also wanted to put the same tires back on, and I said no give me the better ones.
  16. Feb 7, 2022 at 8:18 AM
    eurowner
    eurowner Duke Sky
    Scoty
    No tune?
  17. Feb 7, 2022 at 8:18 AM
    cts528
    Northern MA
    2017 TRD Off Road
    That's what made me take a closer look at mine, the first storm that season I was all over the place!
    5nahalf[QUOTED] likes this.
  18. Feb 7, 2022 at 8:21 AM
    Montana_Actual
    Montana_Actual ;)
    Cool story.
    Welcome to TW.
    GuacIsExtra and 9th like this.
  19. Feb 7, 2022 at 8:27 AM
    Borracho Loco
    DFW, Texas
  20. Feb 7, 2022 at 8:30 AM
    BackcountryTacoma
    21’ Trd Pro
    A lotta stuff ;)
    KD max pro tune. 2nd item listed
    eurowner[QUOTED] likes this.
