Factory tow reciever replacement: Factory or other?
Discussion in 'Towing' started by jpachard, Nov 3, 2014.
  1. Nov 3, 2014 at 11:09 AM
    jpachard
    jpachard [OP] Well-Known Member
    2006 4WD 4.0L Tacoma 6spd TRD
    So, I have a 2006 TRD offroad with the tow package. My reciever assy is VERY rusty and since I tow I want to replace it. Should I get the factory piece or are there other bolt on options out there?
    I'm also looking for any nice options to relocate the 7 pin connector so it's not so prone to getting smacked.
    James
  2. Nov 3, 2014 at 11:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Since you have a factory receiver, I would replace it with the same. I believe if you go with something else, you'll need a spacer plate for the bumper brackets. Some people have relocated their trailer harness to the driver's side license plate light location and just lost the light.
  3. Nov 4, 2014 at 11:11 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I would doubt that Toyota would use a different frame for models with the tow package. The aftermarket hitches I have installed all fit without extra parts (spacer plates or otherwise). An aftermarket hitch should fit ok. If you have any doubt, compare the frame dimensions of a non-tow package model with yours.
  4. Nov 4, 2014 at 12:44 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    The Reese hitches you can get at Tractor Supply are bolt on and are actually ok for not very much money. Wiring kit is extra. Probably a 1/4 of what a factory setup would cost.
  5. Nov 6, 2014 at 9:55 AM
    jpachard
    OK, thanks for the information guys. I'm going to see what the factory replacement costs and go from there.
    Cheers, James
  6. Nov 6, 2014 at 10:02 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Obvious answer here, but yes this is not the case. I picked up an OEM receiver second hand for $125 with a brand new 2" ball and brand new 2" drop hitch and installed it on my truck which had no tow package or option for a tow package since it's a 4 cylinder. My frame had all of the same holes and bolts and dimensions.
