Factory Toyota Service Manual
Discussion in '1st Gen. Tacomas (1995-2004)' started by Woodcutter, Jan 14, 2020.
  1. Jan 14, 2020 at 7:04 AM
    Woodcutter
    Woodcutter [OP] Well-Known Member
    Missouri
    3.4L V6 96 Taco 4 x 4 SR5
    Say has anyone purchased a used factory Toyota service manual available from "Factory Repair Manuals"? They list these as in good condition for $196. I paid for a PDF on a CD but found it to be disappointing and would like an actual factory manual for reference. Thanks all! Woodcutter
    bigmw likes this.
  2. Jan 14, 2020 at 7:11 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    There’s one on eBay right now for $170. I’d jump on that. I bought mine for 180 on eBay. Very worth having
  3. Jan 14, 2020 at 7:11 AM
    ToyotaDriver
    Idaho
    Also, it’s new, not used
  4. Jan 22, 2020 at 11:27 AM
    EZ Harley
    EZ Harley Member
    Yakima wa,St.Helens OR, Libby MT
    2000 Tacoma 4X4
    Just purchased a copy. Had been looking for quite a while. 170.00 with Washington tax.
    Thanks
  5. Jan 22, 2020 at 11:45 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    beemerphile, jammer and GQ7227 like this.
  6. Jan 22, 2020 at 12:02 PM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    If you need an FSM in PDF PM me. I have 1995-2004 FSM, EWD, Trans/Diff Info/setup/IPC/ECU info/etc...
    chan2565, jammer and GQ7227 like this.
  7. Jan 22, 2020 at 12:29 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i think I downloaded that from you and briefly looked it over, are there pages covering proper bed removal/ install as well as the fuel tank?
    there's a lot of pages in there
  8. Jan 22, 2020 at 12:59 PM
    Russianman92
    Dunwoody GA
    The official FSM doesn't have info to remove the bed. BUT here is some stuff for reference. Attached is the PDF page for fuel system components. Below is an image of the 6 bolt locations for the bed. I assume you are trying to replace the fuel pump? If so, just remove the 4 front bolts closest to cab and loosen the last 2 in the rear and you can lift the bed up by the cab without damaging anything and put a few 2/4s to hold it up to reach in there. I would get a friend to help.
    Oh and dont forget to unbolt the filler neck from the filler door.
  9. Jan 22, 2020 at 1:03 PM
    Russianman92
    Dunwoody GA
    If you need to remove the bed completely for some reason then just make sure to unhook the harness from the tail lights/license plate light and such. then it's pretty simple to lift the entire thing off with help.
  10. Jan 22, 2020 at 1:06 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i was just curious about reinstallation, like the proper torque on the nuts & bolts :notsure: probably will get some fresh new ones
    needing a complete & thorough frame coating restore, all old beaten failing paint and crust off and new heavy duty primer/paint coating
    not sure about the fuel pump at 135k miles but fuel tank needs to come off to thoroughly clean that frame section in the rear, thats where it gets real from TW pics i have seen
    thank you for the fuel tank diagram, downloaded and saved to folder
    too bad there are no part #s on that as well
  11. Jan 22, 2020 at 1:16 PM
    Russianman92
    Dunwoody GA
    I would go with 67ft-lbs dry on all 6 bed mount bolts
    Source: https://www.tacomaworld.com/threads/bed-mount-bolt-torque-spec.470409/#post-21295071
    See attached for Fuel System Torque Specs
  12. Jan 22, 2020 at 1:21 PM
    Russianman92
    Dunwoody GA
    What year? 1995?
  13. Jan 22, 2020 at 1:26 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    97 sr5
  14. Jan 22, 2020 at 1:31 PM
    Russianman92
    Dunwoody GA
    Go to Partsouq.com and type in your VIN.
    Then go to Body/interior and select Fuel Tank & Tube and Rear Body Mounting for your part numbers.
  15. Nov 16, 2020 at 3:21 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
