factory trailer tow
Discussion in 'Towing' started by commtrd, Sep 5, 2009.
  1. Sep 5, 2009 at 6:56 AM
    commtrd
    commtrd [OP] commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    So I have the factory trailer tow package. When I install a trailer brake control module, what is the interface with the existing factory trailer tow stuff? It seems like it should just plug into a harness and be ready to go?
    I have seen some tutorials where new wire is being pulled all over the place but is all that necessary if I have the factory trailer tow package?
  2. Sep 5, 2009 at 7:12 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    There should be no need to pull wires just to hookup the Brake control, save you do not have a 7 way round adapter on the truck. I have a link for the draw-tite harness installation for the brake control below I hope it helps.
    http://www.draw-tite.com/fitguides/pdf/N20265.pdf
  3. Sep 5, 2009 at 3:21 PM
    commtrd
    Corpus Christi TX
    Thanx...all that stuff is already on the truck. It should not be too involved to install the device. I wonder how strong the stock clutch is? That may need to be replaced with a clutch less prone to slipping?
