Factory Trailer Wiring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris4485, Mar 25, 2017.
  1. Mar 25, 2017 at 3:16 PM
    Chris4485
    Chris4485 [OP] New Member
    2017 Tacoma
    I have a 2017 and it has under the rear of the truck the factory wiring connections for installing the bumper mounted trailer connector, I've looked online for the OEM wiring harness to purchase but can't seem to find a descent price, don't wanna pay $200 for the pigtail and bumper 7 pin connector.
    Anyone know of somewhere to get a descent price kit ?
  2. Mar 25, 2017 at 7:10 PM
    toycoma 2016
    toycoma 2016 Well-Known Member
    jason
    Williamsport, TN
    2021 cement OR 4x4 dcsb
    Lots
    So you have a truck without a tow PKG , right? And you're wanting to put in a wiring harness on said truck to attach to your trailer? If so Curt towing products has a harness that's practically plug and play. Check
    e-trailers.com. Just have to run one of the wires to the battery. Very easy though. I have one myself. And @moe2o4 , can you give this man the link you sent me for the correct 7/4 pin bumper harness from e-trailers. I hope this was the info you were looking for.
    moe2o4 likes this.
  3. Mar 25, 2017 at 8:17 PM
    Chris4485
    2017 Tacoma
    Yes it has no towing package but does have the quick connections under the truck for the trailer wiring, was looking to see about a factory type of wiring pigtail that would be connected into the bumper RV and Trailer plug, I found one of these on eBay just no pigtail.
    moe2o4 likes this.
  4. Mar 25, 2017 at 8:58 PM
    toycoma 2016
    jason
    Williamsport, TN
    Lots
    Well like I said the Curt harness is the only one I know about other than factory. It's only $50, and it plugs into your tail lights then just run the 4 wire pigtail to the bumper plug and connect into it.
    moe2o4 likes this.
  5. Mar 26, 2017 at 3:20 AM
    Chris4485
    2017 Tacoma
    Thank you for the info, I looked into it and went ahead and ordered one from Curt !
    moe2o4 likes this.
  6. Mar 26, 2017 at 4:29 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Yep you guys got it, ordered the 4 pin wiring harness then cut the 4 pin connector off and wired it into the 4/7 pin connector and left the other 3 wires out for the brake controller!
  7. Mar 26, 2017 at 6:26 AM
    Dsmitc90
    Dsmitc90 Member
    2016 Tacoma SR 4WD 5MT
    I installed the Curt 4 Pin Trailer Wiring on my 2016 SR. The only problem I ran into was the converter box is not fuse protected. While out of town Fishing, I had to tow someone else's boat a few miles. Got back that night and noticed I didn't have any running lights on the trailer. Checked all the fuses on the truck and even went and bought a cheap multimeter to test with. Called Curt told them my issue and readings. They said my box had failed due to a short to ground somewhere and said they would Warranty out this first one. So I had to ride back from LA to AL at night with no Trailer running lights. If it happens again, I'll definitely be purchasing an OEM Harness.
    jaxmyth and Hiluxski like this.
  8. Mar 26, 2017 at 8:27 AM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I have a 17 SR without the tow package and I saw those pigtails underneath and I'm going to go with the factory Toyota harness and hitch but the dealers not much help on the wiring. Does anybody have the part number for the OEM harness , The dealer seems confused on this.
    Thanks
  9. Apr 21, 2017 at 4:20 AM
    78 corolla wagon
    78 corolla wagon soon to be for sale
    nip
    rumney nh
    2016 tacoma off road magnetic grey, 2017 taco sr
    i just bought a 2017 sr yesterday, the dealer said it would cost a grand for a hitch (wtf) so if i could get a oem wiring harness part # i would be a big help thanks. i can't seem to find a part # anywhere. a oem fog light harness # would help too. thanks!!
  10. Apr 28, 2017 at 6:43 AM
    toycoma 2016
    jason
    Williamsport, TN
    Lots
    Go with the Curt converter as described above. It's cheap and it's plug and play. As for harness for fogs, buy an aftermarket harness on Amazon or eBay. I have one and again it works and is a lot cheaper than factory. I've seen another write up on here talking about the factory harness. It had to be ordered from Japan and you have to know how to hook it into your ecu to make it work like the factory version. Much more difficult in my opinion. Hope this helps.
  11. Apr 29, 2017 at 2:32 PM
    78 corolla wagon
    nip
    rumney nh
    thanks toycoma 2016,i gave up on the oem stuff!. i will go with the curt converter.i saw the foglights for $60.00 on ebay,i will run with them also. i just installed my weather tech side window deflectors and mud flaps. i also just put in a order for red line oil for the manual trans(if you have not used it you will not believe how good it will shift) and front and rear diffs. you got all the sh**for your sr, i will be looking into some of that stuff too.
