Factory TRD lift shocks question
Discussion in 'Suspension' started by davered00ss, Aug 10, 2021.
  1. Aug 10, 2021 at 11:52 AM
    davered00ss
    davered00ss [OP] Well-Known Member
  2. Aug 10, 2021 at 12:01 PM
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Can they be paired with diff coils?
  3. Aug 10, 2021 at 12:02 PM
    davered00ss
    I believe only stock coils.
  4. Aug 10, 2021 at 12:03 PM
    davered00ss
    My truck is a 2019 TRD Sport DCSB. The lift says its for 2020 and newer only. Not sure why.
  5. Aug 10, 2021 at 12:04 PM
    jeremyv821
    jeremyv821 Member
    Jeremy
    Queensbury, NY
    2021 Voodoo Blue TRDOR 6AT
    Interested asswell.. especially for the price!
  6. Aug 10, 2021 at 12:05 PM
    davered00ss
  7. Aug 10, 2021 at 12:06 PM
    davered00ss
  8. Aug 10, 2021 at 12:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Shocks don't lift, springs do. The only thing 5100s have are multiple spring perch positions that add preload to a spring to create lift.
    There has to be more to the Toyota OE lift package than just shocks.
  9. Aug 10, 2021 at 12:12 PM
    davered00ss
    The kit really only comes with shocks. the spring position creates the lift. Where you put the snap ring on the front shock creates it.
  10. Aug 10, 2021 at 12:13 PM
    davered00ss
  11. Aug 10, 2021 at 12:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    I think that's what I just said?
    I was just unaware that the OE lift used this method.
    If that's the case, there is no reason to spend the bucks for OE bits, assuming they cost more than aftermarket.
  12. Aug 10, 2021 at 12:18 PM
    davered00ss
    They are actually cheaper than the bilstein 5100's
  13. Aug 10, 2021 at 1:19 PM
    jeremyv821
    jeremyv821 Member
    Jeremy
    Queensbury, NY
    My main question is are these basically rebranded 5100s?
  14. Aug 13, 2021 at 2:01 PM
    KPaige
    KPaige Well-Known Member
    Ken
    2021 Tacoma trd sport 07 FJ Cruiser
    sport- none yet FJ- Bilstien lift 33 x 12.5 BFG, TRD Exhaust, ECG third member
    kit is 1295 at my dealer. If you get it installed at purchase you get the full warranty as if it came from the factory, if you get it installed later you get a 1 yr warranty. Problem is you can not install it yourself if you do and have no record of dealer install all suspension warranty is voided. That being said they want 1200 for install
  15. Aug 26, 2021 at 2:05 PM
    DustyBones
    DustyBones Member
    19 Red TRD Off Road
    I wish I saw this before I ordered 5100s for the exact same price. Looks like only 3 height settings on these instead of 4-5 on the 5100 fronts. I like these better and I bet they pair great with the TRD OffRoad progressive coils
  16. Aug 26, 2021 at 2:22 PM
    KPaige
    Ken
    Here is everything in the kit
    What all do you need to do yours correctly
    Part Numbers:
    • PT84K-35220 (Front 2'' & Rear 1'' Lift Kit & Hardware)(From Toyota)
    • 88210-04080 (Millimeter wave Radar Sensor) Re-calibrated Radar Sensor to accommodate the Lift
    • PT228-35200-20 (Matte Black TRD Pro Style Front Grille)(Hole on top of grille accommodates if you have a front camera, If you don't need Hole Camera Hole Filler also included SEE PHOTO #7 FOR REFERENCE)
    • PTR13-35210 (TRD/Bilstein Tuned Front & Rear Shocks 4 Piece Set)
    • Total Kit Part Number: PT84K-35221 (All Parts Listed Above)
    Everything Included in Kit & Hardware:
    1. Qty 1 TRD Shock Absorber 4 peice Set
    2. Qty 2 Strut Collar's
    3. Qty 1 TRD Pro Style Black Grille
    4. Qty 1 Millimeter wave Radar Sensor(Re-calibrated Radar Sensor to accommodate the Lift)
    5. Qty 1 Grille Garnish for Radar Sensor (TSS Garnish Cover)
    6. Qty 2 90183-06044 Spring Nut To Hold TSS Sensor COver(Grille)
    7. Qty 2 RR Leaf Spring Spacer
    8. Qty 4 U-Bolts
    9. Qty 2 Parking Brake Cable Spacer
    10. Qty 2 Bolt (Park Brake Spacer)
    11. Qty 1 Front Camera Bracket (If you have Multi-Terrain Monitor w/Front Camera Bracket Is needed to Mount Camera Into front Grille Hole Opening)
    12. Qty 2 90167-A0021 Screw (Front Camera Bracket)(If you have Multi-Terrain Monitor w/Front Camera)
    13. Qty 1 Connector Cap*(Needed Only If YOU DO NOT have a Multi-Terrain Monitor w/Front Camera To Plug The Front Grille hole Opening)
    14. Qty 1 Sub-Wire Jumper Harness
    15. Qty 2 Lock Nut for(Front Shocks)
    16. Qty 1 RH Fog Light Dummy Bezel(Only Needed If equipped With Fog Lights)
    17. Qty 1 LH Fog Light Dummy Bezel (Only Needed If equipped With Fog Lights)To install you will need to Remove Fog Lights (if equipped) WARNING: When the TRD Lift Kit installed, the OE fog lights will no longer comply with most US State lighting regulations for fog light height position. The OE fog lights must be disabled & removed in order to comply with these US States’ lighting regulations for on-road usage (at the time of writing these instructions): AL, AR, AZ, CO, CT, DC, FL, GA, ID, IN, KS, LA, MD, ME, MI, MN. MT, ND, NM,
  17. Aug 26, 2021 at 2:23 PM
    KPaige
    Ken
    my truck will arrive between Sept2 and 8th and the lift will be installed right then already have new wheels and tires. Rock rails, and a bed cover sitting in my garage
  18. Aug 26, 2021 at 2:25 PM
    DustyBones
    DustyBones Member
    19 Red TRD Off Road
    lol at removing the fog lights
    rmepilot likes this.
  19. Aug 26, 2021 at 2:35 PM
    KPaige
    Ken
    Thats a legal thing they have to put in there most dealers just ask if you want to do it.
  20. Aug 27, 2021 at 12:13 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What are trd offroad progressive coils? AFAIK, all trims come with the same 700 lb/in coil springs.
