Facts behind body lifts??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Texasdynaryder, Dec 20, 2011.
  1. Dec 20, 2011 at 1:37 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Not to bag on your previous forum...but no wonder why so many people ran body lifts...it was a cheby forum...
    I cant even count how many S10's and Silverados I see around here with huge ass body lifts on them.
    I saw a mid 90's silverado a while back with a 4'' Body lift on it...yes, 4''...I had to get out with a tape measure in the parking lot to confirm my suspicions....:eek:
  2. Dec 20, 2011 at 3:21 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It's been said on here before:
    Think about standing on a coke can, or better yet, stand on a deep socket.
    That's what a 3" body lift basically is. You space out the body 3 additional inches away form the frame, and NO body lift comes with some sort of longitudinal brace, so that the body can't roll from side to side/front to back. The only thing keeping the body from slipping to the side (think the coke can falling over) is the tension on the bolts holding the body to the frame (which is not the direction of forces being applied to a 3" body lift). Bolts aren't designed to take bending forces, bolts are meant to only take tention (parallel to the long axis of the bolt) or, in some cases, sheer.
    A 1" BL is "better" than a 3", but I would still not do it.
    The main issue I have with BL's is that they in no way shape or form increase performance. You get all the disadvantages of a suspension lift (higher center of gravity) and none of the benefits (increase travel, ground clearance, etc...).
  3. Dec 20, 2011 at 3:36 PM
    jbrandt
    Justin
    let me guess:
    a 4" body lift, plus a 6" block lift, too... lol
  4. Dec 20, 2011 at 3:57 PM
    TacoMX
    Jonathan
    Deltona, Florida
    actually...it did have a block in the rear...but it was like 3''....:D
  5. Dec 20, 2011 at 7:23 PM
    Texasdynaryder
    Texasdynaryder [OP] Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    Let me ask this then.. If I was was wanting a db lift I might as well go with camburg or total chaos for articulation..correct?? Because you wouldn't be adding any additional wheel travel?
  6. Dec 20, 2011 at 7:27 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    if you go with a DB lift all you're doing is decreasing your ground clearance under the front diff and raising your COG again thus causing your offroad experience to be completely shit.
    On the other hand if you crawl teh malls like myself then DB is beast.
  7. Dec 20, 2011 at 7:50 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    A 1'' BL is 100% safe and presents 0 issues of any kind. If your concern is mechanical there is no concern if your concern is asthetics, there is no concern.
    People are making an issue where there isn't one most likely through a lack of experience and just parroting what they have heard or read others say.
    Your truck body is not going to tear itself away from the frame nor is raising the center of gravity a concern in as much as its a concern for doing a suspension lift. What raises more weight higher a suspension lift or a body lift? Exactly. As for creaking or making other sounds all I can say is huh? If you are serious about offroading in your production model vehicle, you have a body lift. Don't let anyone tell you otherwise.
  8. Dec 20, 2011 at 7:52 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    The 1" bls are fine if one needs tire clearance, but the 3" bls are the ones we rag on
  9. Dec 20, 2011 at 7:56 PM
    TacoMX
    Jonathan
    Deltona, Florida
    With a [good] suspension lift you gain suspension performance and clearance; a "side effect" is an increased COG.
    With a body lift you increase your COG, and get no other benefit other than being able to fit larger tires..
  10. Dec 21, 2011 at 4:42 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i didnt know you worked out :confused::D
  11. Dec 21, 2011 at 7:33 AM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    I don't agree with this. I have a 3" body lift, 3" Fabtech coilovers that are set at approx. 2-1/4", Alcan 8-leaf rear leaf spring set that gives 2" of lift, and I have 33-12.50's Buckshot Mudders that will ocassionally rub in the front while wheeling pretty hard. Slapping on a set of 35" mud tires in my opinion will lead to even more rubbing even in very MINOR offroading. Just my opinion though. These 1st generation tacomas require LOTS of lift in order to stuff large tires underneath of. The rear isn't too bad, but it's the front fender wells that give the most obstruction. Just my opinion though from what I have experienced with my 2000 ext. cab trd 4x4.
  12. Dec 21, 2011 at 7:46 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  13. Dec 21, 2011 at 10:17 AM
    TacoMX
    Jonathan
    Deltona, Florida
    Ay brah...those are some sweet body lifts brah!
    I love how the Black taco in the first pic has a rollpan and a Customtacos sticker :laugh:
  14. Dec 21, 2011 at 11:24 AM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Not lots of lift, just lots of cutting ;)
  15. Dec 21, 2011 at 11:37 AM
    #35
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  16. Dec 21, 2011 at 11:53 AM
    #36
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Shoulda used Bluwood, it prevents mold and termites. This guy clearly doesn't watch Holmes on Homes.
