Facts or opinions on topping off gas tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Loganc08, Dec 25, 2016.
  1. Dec 25, 2016 at 5:59 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    The risk may be low but the reward in most cases is lower.
  2. Dec 25, 2016 at 7:28 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I had to replace my charcoal canister. Cost me $300 or $400(can't remember)for a new one. I don't top off as aggressively as I used to. I had a Chrysler 300 that suffered the same problem. It's a real pisser and kinda unbelievable that pumping too much gas in your tank will break shit. :rolleyes:
  3. Dec 25, 2016 at 8:55 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I top mine off 10-12 litres extra usually.
  4. Dec 26, 2016 at 5:11 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2
  5. Dec 26, 2016 at 5:25 AM
    Avail211
    Avail211 Well-Known Member
    2016 BBP TRD OR
    I bought a used 07 Xterra in 2011 that the previous owner topped off all the time and ruined the charcoal canister. It was around $500 to repair. I never top off or even click to round ff, it's not worth the risk for the very little gain IMO.
    I yelled at the gas attendants in Oregon when they'd keep clicking it to a round number, I couldn't care less if my gas is $27.64 instead of $28.00.
    Mush Mouse likes this.
  6. Dec 26, 2016 at 5:36 AM
    Dwrat
    Dwrat Well-Known Member
    Dan
    Phoenix
    2014 TRD 4X4
    The EPA realized that overfilling the gas tank can damage the EVAP system thereby producing more emissions so they demanded the auto makers devise a method to prevent that from happening. So the auto manufacturers came up with the RO/OF valve. ROLL OVER/OVER FILLING valve. This is a ball in a cage with a weight at the bottom at the end of the fill tube. When filling the gas to the full level in the tank the ball floats up and blocks the fill neck thereby shutting off the gas nozzle. And no matter how much you try you can't overfill the gas tank because the ball prevents gas from being introduced the nozzle keeps shutting off. In the event of a roll-over accident, the weight under the ball forces the ball against the end of the filler neck thereby preventing gas from running out of the gas tank. The EPA doesn't want unburned gas in the air, in the water, or on the ground.
    JSU likes this.
  7. Dec 26, 2016 at 5:48 AM
    george3
    New Jersey
    You guys read this tread - canister - $300, $400, $500 - and you still want to top off - must have Benjamin's burning a hole in your pocket - CFS.
  8. Dec 26, 2016 at 6:41 AM
    TegoTaco
    Ontario, Canada
    I did it to my TL for almost 5 years with no issues.
  9. Dec 26, 2016 at 6:45 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I drive a lot, like almost 800 miles a week, I top off to the nearest dollar, just to be safe. Don't have Benjamin's burning a hole in anything.:mad:
    Norton likes this.
  10. Dec 26, 2016 at 6:50 AM
    badger
    badger Well-Known Member
    07 SR5
    So how does this problem manifest?? Does it trigger a code. Does it actually effect the running of the truck? Does it effect the ability to pass emissions testing? How do people know their canister is ruined?
  11. Dec 26, 2016 at 6:52 AM
    Gearheadesw
    Davenport Fl
  12. Dec 26, 2016 at 6:53 AM
    farnorth01
    farnorth01 Member
    Ben
    British Columbia
    2011 SR5 4x4 ACLB
    Icon Stage 1, Dakars, Duratracs
    How do you know if your charcoal canister craps out? Does it create an immediate issue?
  13. Dec 26, 2016 at 7:02 AM
    Pigpen
    Dan
    Northwest Montana
    IIRC, it manifested as a CEL in my buddy's truck and caused rough running until he replaced it.
  14. Dec 26, 2016 at 7:07 AM
    Justinlhc
    CEL turns on. I didn't notice any rough running condition in the Tacoma, but the 300 would not start the first time you turned the key.
  15. Dec 26, 2016 at 7:08 AM
    #35
    ColoradoTom
    ColoradoTom Team Velveeta™
    Colorado
    2014 Tacoma 4x4 Access Cab
    And neither do I for that matter. Basic rule for me is that once it clicks I'm done. I heard years ago that topping off introduces more gas vapor into the atmosphere and unburned gas vapor is a worse global warming impact than vehicle exhaust. Plus it's a waste, gas I'm paying for evaporating out of the filler neck. I do however slow down the flow once I know it's within a gallon of full. When I stop to get gas I look at the gauge. It's not rocket science to figure out a pretty good estimate of what it's going to take. Start fueling with the hold open clip wide open. Once it gets close I move the hold open clip to the lowest flow setting. Pump shuts off, replace nozzle in pump, take receipt, reset trip odometer A, drive the fook away.
  16. Dec 26, 2016 at 8:44 AM
    #36
    SB Taco
    SB Taco Well-Known Member
    Santa Barbara, CA
    2007 Silver Tacoma DCLB 4x4
    I have found you can safely top off by waiting 30 seconds after the shut off then pump another .1-.2 gallons till it shuts off again. Its not much
  17. Dec 26, 2016 at 8:51 AM
    #37
    badger
    07 SR5
    My guess is that the perfect storm is a severe overfill + warm temps + little or no driving after the fill. I guess I have never hit that trifecta, but I learned something today. I'll be more thoughtful about this in the future.
  18. Dec 26, 2016 at 9:28 AM
    #38
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Attendant topped mine off a few years ago... sent fuel into the charcoal canister and tripped a cel dash light. Got it fixed at the dealer. They warned about the canister needing replacement if it keeps happening.... not cheap.
  19. Dec 26, 2016 at 9:47 AM
    #39
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Filled it way too much earlier this year. I was going on a long trip and rather than hit the gas station before leaving, I filled up with what was left in my gas can, It bubbled out the neck of the filler. Thankfully no CEL or other issues so far.
  20. Dec 26, 2016 at 10:05 AM
    #40
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Considering how your rig is setup for being off road... why no Rotopax or Jerry cans?
    Much cheaper than replacing charcoal canister.
    RogueTRD likes this.
