Faded factory fender flares - anyone have a good remedy?
Discussion in '1st Gen. Tacomas (1995-2004)' started by '02TRD, Dec 28, 2010.
  1. Aug 26, 2012 at 6:49 AM
    #61
    Taco Sos
    Taco Sos Well-Known Member
    Culpeper, VA
    2001 Tacoma DC TRD 4x4
    Bilstein 5100s in front, 265/75/16 BFG A/T, Grey Wire Mod, Deck Palte Mod, Tint, Clarion Head Unit, Infiniti Speakers, Dual 4 channel amp
    The other day I pulled my rears off and painted em with Krylon Fusion Satin. Little did I realize that all the clips would break and cost $2.19 each and there are 14 of them in the rear. The flares look really good though. I haven't reinstalled them yet but I will take a couple pics when i get finished. I might do it today.
  2. Aug 26, 2012 at 11:49 AM
    #62
    cbreze
    cbreze Well-Known Member
    Jim
    Bend, Oregon
    '12 T4R, '74 LC, '88,'98 04' pickups.
    I use an armor all type of rub in coating. Is a good protectant and I've had good results. Applied after every wash, about once or twice a month. My truck is an 04 and the black fender flares still look like new.
  3. Aug 26, 2012 at 8:16 PM
    #63
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    Anyone that plans to repaint their fenders already try one of the FAT tiped style Sharpie markers. I bet it would work, if not your repainting anyway.
  4. Aug 27, 2012 at 12:12 AM
    #64
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    You can buy all the clips for about $30 or so from online, I have a link on my other dual-boot OS. I'm thinking of bedliner or plasti-dip stuff.
  5. Aug 28, 2012 at 9:52 PM
    #65
    TacoJenn
    TacoJenn *~*
    Jennifer
    Houston, TX
    Campa shell, 5100s
    i use armor all everytime i wash my truck, which is only a few times a year... and it lasts and my flares stay black and look like new in between washes
  6. Aug 29, 2012 at 10:22 AM
    #66
    Smokey11
    Smokey11 You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    Can you use this on the flares like people have on the bumper, anyone try this?
  7. Aug 29, 2012 at 10:54 AM
    #67
    pschmidt
    pschmidt Active Member
  8. Aug 29, 2012 at 1:23 PM
    #68
    scocar
    scocar hypotenoper
  9. Aug 29, 2012 at 7:51 PM
    #69
    1985 4runner
    1985 4runner Member
    Gulfport, Mississippi
    02 Prerunner DC
    Did all mine with magic eraser followed by Mother's back to black. Very impressed.
    Truck has been sitting outside in a hurricane for two days. Will update with pics tomorrow.
  10. Aug 29, 2012 at 8:45 PM
    #70
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    The reason the flares fade is oil slowly moving it's way out of the plastic. Every time you wash your truck, you wash a little bit of oil out of the flares. The dressings that you put on only absorb into the surface. When it rains, the dressing (that has oil in it), gets washed away and you are soon left with faded flares again. There is really no good way to get these flares black again unless you submerged them in a bath of hot or warm oil over night or over the course of a couple days. I am planning on having mine painted, either black with Rustoleum bed liner or professionally done by a body shop to match my truck. I am DONE with shitty looking fender flares :mad::D
    CS_AR likes this.
  11. Aug 30, 2012 at 8:54 AM
    #71
    Madjik_Man
    Colorado Front Range
    Raptor Liner for me eventually
  12. Aug 30, 2012 at 11:04 AM
    #72
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    The best paint you can use on anything is SEM. I've used it on my old trucks dash, flares and never had any fading issues nor peeling.
    Secondly has anyone dyed the flares. I've dyed several at work and for friends. The product listed below is not for changing it to another color. If they were black stock order black. This stuff is absolutely amazing. Apply with a 2" roller or a simple rag.
    http://www.showroomnewproducts.com/shop-car-dye-kits
  13. Aug 30, 2012 at 9:44 PM
    #73
    stevet47
    stevet47 New Member
    Denver, Co
    96 stocker
  14. Sep 2, 2012 at 9:44 PM
    #74
    Hektor
    Hektor Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
  15. Sep 2, 2012 at 9:45 PM
    #75
    Hektor
    Texas
  16. Sep 2, 2012 at 11:52 PM
    #76
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    I rattle canned my flares a couple months ago and they have held up very nice. Steps I used.
    1.Remove flare (you will break clips so buy new ones)
    2.Wash and then sand (type of grit to your liking, more or less creating a surface for the paint to stick too). Green or red scotch type pad also works.
    3. Wipe clean to remove shavings and dust.
    4.Dupli-ColorSandable Primer -I did one coat but recommend 2 (need 2 cans if 2 coats are desired. let dry
    5.Dupli-Color Acrylic Enamel - Once again 2 cans needed for adequate coverage.
    6. Pop the clips on the freshly painted flares.
    7.:proposetoast:
    I did mine maybe 5 months ago and there is no fading. It seems to hold up relatively well too. However a possible clear (non reflective) coat as a protective barrier could be considered. All things said. Cheap and really helps lift the truck up in the looks department.
  17. Sep 3, 2012 at 9:03 AM
    #77
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Did you color match them or just do flat black? I'd like to see how they look :D
  18. Sep 3, 2012 at 9:11 AM
    #78
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    How does that paint hold up to flexing of the flare?
  19. Sep 3, 2012 at 9:20 AM
    #79
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    X2.... Herculiner is the s.h.i.t
  20. Sep 3, 2012 at 6:04 PM
    #80
    BrianLV
    BrianLV Well-Known Member
    Las Vegas
    04 Prerunner SR5
    Herculiner fades fast, and it thins out in the sun.
