Fail Safe Traction Control?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IcePlant, Apr 18, 2018.
  1. Apr 19, 2018 at 10:15 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Figured to help educate folks from a more technical source at this point for clarity:
    http://www.safemotorist.com/articles/hydroplaning_basics.aspx
    What is Hydroplaning?
    The term hydroplaning is commonly used to refer to the skidding or sliding of a cars tires across a wet surface. Hydroplaning occurs when a tire encounters more water than it can scatter. Water pressure in the front of the wheel pushes water under the tire, and the tire is then separated from the road surface by a thin film of water and loses traction. The result is loss of steering, braking and power control.
    Rubber tires have tread (grooves) that are designed to channel water from beneath the tire. This creates higher friction with the road surface and can help prevent or minimize instances of hydroplaning.
    When does Hydroplaning Occur?
    Hydroplaning can occur on any wet road surface, however, the first 10 minutes of a light rain can be the most dangerous.
    When light rain mixes with oil residue on the road surface, it creates slippery conditions that can cause vehicles, especially those traveling speeds in excess of 35 mph, to hydroplane. This can be a deadly combination for the driver and surrounding motorists.
    The chance of being involved in a motor vehicle accident increases during poor weather conditions such as fog, rain, ice and snow. However, it isn’t necessarily the pounding rain and blinding snow that are the most dangerous; it is the slick conditions that drivers aren’t prepared for.
    This is normally pretty basic, but just to understand the function here...its not uncommon for hydroplaning to happen on the highway as speeds are typically faster than say...35.
    As I have been trying to make my case about...if Im truly hydroplaning when the basic laws of theory here are loss of braking and steering...its a controlled crash until you either lose enough momentum for the weight of the vehicle on the tires to push more fluid out of its way to achieve traction and thus giving you back control.
    Back to the topic at hand...sudden braking when I STILL have control of my vehicle in wet conditions is not desired...for me.
    misdirection1982 likes this.
  2. Apr 19, 2018 at 10:43 AM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    :thumbsup:
    Oh so there's actually a valid reason your truck tries to make you crash, you just left that little tidbit of info out. :facepalm:
    BuddyS likes this.
  3. Apr 19, 2018 at 10:49 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Its part of the height issue when lifting a vehicle. There is a weird bypass for it that Im still trying to find out. For the stockers out there, no need to worry as your gyro will be within spec, but for lifted trucks that have an increased height will see issues as such.
    Many of my friends have theirs permanently disabled that wheel.
  4. Apr 19, 2018 at 11:14 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Yeah I don't really think this is a case of you driving too fast based on what you describe. Its sounds like your suspension setup is negatively affecting it/making it too sensitive. Honestly it works pretty great in my truck apart from randomly kicking in while I make right hand turns under hard acceleration.
    Coot83[QUOTED] likes this.
  5. Apr 19, 2018 at 11:36 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I would agree with you on that...the suspension does a good job on messing with things, but I think the upsize in tires is the real culprit. I have 35s now, but this started back when I threw on 33's. Like most things in this hobby, you learn to be flexible and compromise a little each time you deviate from stock.
    Don't get me wrong, in its stock form traction control is perfect, but when you alter height specifically and other components it can really become an unpredictable deterrent. After getting used to the triggers of it I don't have much issue these days, but initially man talk about a sobering moment.
    Dirty Harry[QUOTED] likes this.
  6. Apr 19, 2018 at 11:58 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Just to let you know, ALL tires AND vehicles are suseptible to hydroplaning at 35+ mph. Didn't they teach you this in drivers Ed? Just because it's possible doesn't mean it ALWAYS happens
  7. Apr 19, 2018 at 12:07 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Traction control sucks. I do drive with a heavy foot, but any freaking snow and taking a turn, unless from a stop, pretty much activates it. I hate the noise of my brakes more than anything, as I am not going fast enough for it to really effect the truck. But don't worry, soon we will only be a passenger in our vehicles.
    Coot83 likes this.
  8. Apr 19, 2018 at 12:26 PM
    Anchovy
    TRD Ferguson
    I don't think it'll take off that easily, don't forget the car culture is about driving your car or truck, not being a passenger. There's no freedom in a self driving car
  9. Apr 19, 2018 at 12:58 PM
    Dirty Harry
    Andrew
    SW Florida
    Yup. Car culture is about freedom. What freedom do you have if a cop/important person can just send the "Move over" code to your automated google car?
    I'm only 28 but I can already see myself sounding like the cranky old grandpa. "Back in my day if you knew how to fabricate you could build the car you wanted!"
    "You kids don't know what freedom is! I used to drive off the road!"
  10. Apr 19, 2018 at 2:27 PM
    Spare Parts
    Southern Maine
    Don't disagree that the car culture is freedom, but every day folks commuting they just want to get to point A to B. Vehicles already auto brake, possibly steer, even back up and parallel park. The recent death with the self driving car put it all back a little bit, but it's coming.
  11. Apr 19, 2018 at 2:39 PM
    Anchovy
    TRD Ferguson
    Despite the fact that the amount of people killed by people driving cars doesn't seem to faze anyone anymore
  12. Apr 19, 2018 at 2:45 PM
    Spare Parts
    Southern Maine
    Not sure how this relates, but ya as a society we are continuing to care less about fellow humans.
  13. Apr 19, 2018 at 2:48 PM
    Anchovy
    TRD Ferguson
    I'm saying that when the driverless cars killed a pedestrian, everybody flipped out and some started to ban them. But when a human kills somebody with a car, nobody really cares
  14. Apr 19, 2018 at 2:55 PM
    Spare Parts
    Southern Maine
    True, cause it's new. And that death from what I saw, was inevitable.
  15. Apr 19, 2018 at 3:10 PM
    #35
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    What gets old is the constant bitching and moaning about safety features which do a fantastic job at keeping us alive. Not everyone is a 16 year old boy riding high on puberty hormones. Some of us try to drive like an adult and are beyond burning off tires by driving like a twat. The truck does what it should and it does it well. If you feel the need to drive irresponsibly and complain your truck has too many nanny features to allow this you are an idiot. It’s ok. We all were little boys with more enthusiasm than brains when we were younger. Most grow out of this.
    I hit black ice this winter when approaching a stop at a T intersection. At the last second I saw the vehicle I was going to blow past as I tried to miss the stop sign and over the snowbank and up the front yard and into the tree line. Those nanny features helped keep the truck under control after hitting black ice and having to dodge a stop sign a tree and then a pine tree line next to the field. I turned around with zero damage and missed all sorts of obstacles that in a pre-abs and nanny featured truck wouldn’t have avoided. So you go and complain about not being able to drive like a twat. I will be quite happy when mine steps in when shit goes sideways.
    BuddyS likes this.
  16. Apr 19, 2018 at 3:29 PM
    #36
    Spare Parts
    Southern Maine
    Dude, why must you resort to name calling? Twat? For real, who is the little boy in this situation?
    tcjacado and Coot83 like this.
  17. Apr 19, 2018 at 9:10 PM
    #37
    Exracer2
    Colchester Ontario
    If the word fits.... I know when I was young and driving like that the word fit me then and the word still fits driving like that. If you have an issue then report me.
    You will have a hard time finding anyone in Toyota corporate to consider the driving described as mature and normal. Therefore the truck they designed is working as designed and is doing this job in keeping you in control. Sorry if you ended up with trucks that don’t allow irresponsible driving.
  18. Apr 20, 2018 at 3:42 AM
    #38
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    Ah, gotcha.
  19. Apr 20, 2018 at 4:36 AM
    #39
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Not sure how old you actually are...but Im sure impressed by the mature dialog you got going on. I remember too when I was a young guy with a hot head for things...you live and learn like most.
    It seems to become more prevalent in this thread that one must excessively explain things...my truck rolls with 35s and 4.56 gearing. Im typically the slow guy by design as it is. When Im driving in granny mode, its normally 7-12 mph UNDER the speed limit.
    Yes, on wet surfaces the tires can get weird as magical things can take place beyond the realm of 35 mph.
    Sorry brother that Im not the speed demon like you advertise.
    Spare Parts likes this.
  20. Apr 20, 2018 at 4:37 AM
    #40
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Wait...are you salty about how critical the third gen community is about their amenities?
