Failed attempt to lift truck
Discussion in 'Suspension' started by nurseboy, May 16, 2009.
  1. May 16, 2009 at 2:54 AM
    nurseboy
    nurseboy [OP] Well-Known Member
    Jan
    Riverside, Ca
    I am super tired right now and will just give brief info and elaborate tomorrow. Basically I bought the ultimate toytec lift kit for Taco 05+. Long story short, and I will finish it tomorrow, I pretty much spent 8 hours TRYING to lift the right rear end, adding the leaf, and ending up stripping the bolt that holds it in place. Had to stop the project and put everything back to stock. I fucked up :(. Now need to call toytec Monday for new bolt... :confused::(
  2. May 16, 2009 at 2:57 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    which bolt is it? could be possible to go to a hardware store and get a new grade 8 bolt/nut? It all depends what bolt it is.
  3. May 16, 2009 at 2:59 AM
    nurseboy
    Jan
    Riverside, Ca
    i stripped the center pins here...
  4. May 16, 2009 at 3:11 AM
    GotLift37
    North East AL
    07 4Runner 4WD
    Take a trip to home depot or something man. They got everything.
  5. May 16, 2009 at 4:30 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Hey, you should check on the forum here and see if anyone lives close to you. Most of these guys are willing to help out a brother in need. It really isn't that hard once someone who has done it points out the steps. Good luck.
  6. May 16, 2009 at 4:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That's an easy fix....
    If you have a 'spring shop' in town, I'd get the centering bolt there (instead of Home Depot). The centering pins are a bit different than a standard bolt. The head is different shape than a standard bolt. A Grade 8 bolt will work, but you may (or may not) need to file down the head of the bolt to make it fit (depends on the AAL, perch, etc).
    Don't worry...anytime you do work like that, everything and anything happens. If you think something will take you 2 hours to complete, ALWAYS assume it'll take ALL DAY. Always give yourself a full day.
  7. May 16, 2009 at 8:38 AM
    nurseboy
    Jan
    Riverside, Ca
    this picture is what I don't understand. We kinda of messed up by not having the leaf pack jacked up high enough from the crossmember beam. So we kinda of struggled in putting the centering pin in, thus stripping the bolt while trying to lodge it into the add-a-leaf and along the rest of the pack...BUT if we didnt stripp it, I still dont know how the heck to compress all the leaf pack together to be able to tighten the bolt for the centering pin down??? We tried to put the leaf pack back onto the crossmember beam and rested the truck back down to compress the leaf pack, but the add-a-leaf seemed so strong it wouldnt compres...? We put the add-a-leaf with the long side facing the rear or the truck, and it was facing up with the anti friction pad facing up, so I am still stuck on that part? IF and WHEN I do get a higher jack to be able to separate the cross member from the leaf pack so i can easily put the centering pin through HOW the heck do i compress the pack....
    on the write up it just says..."If the AAL has one end that is longer, that end should face the rear of the truck. Next, slip the centering pin up through the rest of the leaves and spin on the nut. Align all the leaves and tighten down the nut." how the heck did he tighten down the nut :confused:
  8. May 16, 2009 at 8:45 AM
    nurseboy
    Jan
    Riverside, Ca
    and from this picture, it looks like they had all the leafs together and had the centering pin tightened down all the way WITHOUT having to use the truck to push them together...how the heck did they do that? when we were trying to compress them with the quickgrip, the new add a leaf seemed so strong and the anti-friction pad was actually pressing against the leaf on top of it making it harder for it to slide up to compress...HELP!!!
  9. May 16, 2009 at 9:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You need to use a "C" clamp to re compress the springs.
    One like this:
    FWIW, and off road shop, or suspension shop should have replacemetn center pins..
  10. May 16, 2009 at 10:00 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Clamp the leafs before you remove the stock center pin
    Then release the clamp
    Add the new leaf and re-clamp all of them. I used jack stands on the frame and a floor jack on the axle. I lowered the axle almost to the point where the drum touched the ground. Carefully watching the brake lines. Then insert the new pin and tighten it with the clamps still on.
    That being said, I saw another method which looked easier. The guy used 2 ratcheting tie down straps. Over the frame and around the leafs holding them up. He was easily able to slide the new leaf under the stock leafs with no clamps. I saw images on TTORA but I cant find it now.
  11. May 16, 2009 at 10:04 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    hey man. I had to try it 4 different times til i got mine to go. Mine didn't come with the super long center pin so i went to lowes and got two 3/8-16 x 3" grade 8 bolts. I then took a very large allen wrench and slid it though the wholes of the leaves. I then used two c-clamps to squeeze the leaves together. Once they were close enough, I put the new bolt i bought through the wholes (once i removed the allen wrench) and tightened it down.
  12. May 16, 2009 at 10:06 AM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    hey man i know exactly what you are going through, we had the same problem happen when i put mine on. the front was a breeze but the rear end sucked we couldnt get it lifted up enough and then stripped out the bolt, went to home depot and got a new bolt, had to file it down a little bit but it worked out fine.... hope it all works for you man goodluck
  13. May 16, 2009 at 1:49 PM
    nurseboy
    Jan
    Riverside, Ca
    see from the original post on how to put an add-a-leaf, it didnt mention using a C-clamp to compress them down, We figured thats what they probably used but then when we put the weight on the truck onto the leaf pack with the add-a-leaf, it didnt even compress it, so we thought how would a c-clamp do it....but anyways, todays project is doing the fronts, hopefully i am more successfull in doing that...
  14. May 16, 2009 at 8:27 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    hang in there.. people are here to HELP you.... gl
  15. May 17, 2009 at 1:35 PM
    nurseboy
    Jan
    Riverside, Ca
    yea i know. THANKS AGAIN jon (jdkeller). now i just have to get a new center pin and a better c-clamp. that add-a-leaf is super strong to compress, cant believe weight of the truck couldnt compress it...
  16. May 17, 2009 at 5:41 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    :cheers:
  17. May 17, 2009 at 5:51 PM
    nurseboy
    Jan
    Riverside, Ca
    when i attempt to do this again. should i take both tires off and lower the whole diff/cross member down, or do i still do one side at a time? Which would make it easier for me to get more room between the leaf pack and the cross member?
  18. May 17, 2009 at 6:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have always just done one side at a time...
  19. May 17, 2009 at 6:40 PM
    FlawedXJ
    Paul
    NorAla
    i used ratcheting tie downs around the frame above the leaves to help compress everything. I used the c-clamp to hold everything in place.
  20. May 17, 2009 at 6:56 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Alright..... lets see if we can sort this out......
    If you look closely, in the first pic I just used the big quickgrip(didnt have a big C-clamp, and it was plenty strong anyways) to hold the factory leaves together(dont try to clamp the AAL in there too, it IS too strong). I then slipped the centering bolt through: the overload spring, the AAL, then the other 3 leaves and spun the nut on a few turns by hand as pictured. Then I removed the quickgrip and tightened the centering bolt down all the way with my impact wrench. No issues or anything. No need to use the weight of the truck to do anything. How long were your centering pins? I'm guessing they were shorter than mine? Maybe thats what caused most of the issue?:confused:
