Failed Emissions Test
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thetoyotaman, Jun 12, 2021.
  1. Jun 12, 2021 at 7:46 AM
    thetoyotaman
    thetoyotaman [OP] Well-Known Member
    2017 Tacoma SR AC 5MT 4WD
    My dad failed his LA emissions test in his 16 Tacoma 3.5 for readiness not reading. I live out of state from him but set him up with an Ultragauge to monitor trans temps for towing thanks to @tacoma04. Anyone able to post on this thread pics to help walk him through seeing readiness on his Ultragauge? I sent him their instructions but he's not able to find it. Thanks!
  2. Jun 12, 2021 at 8:04 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Car is under emissions warranty in California. Take it to the dealer?
  3. Jun 12, 2021 at 8:30 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Shouldn’t be the smog supposed to be around 2024 since its a 2016 according to the new California smog law ?
  4. Jun 12, 2021 at 8:44 AM
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    Did you disconnect the battery or interrupt power to the ecu anytime prior to getting the inspection done? reason I ask, car has to complete a drive cycle for readiness points to be available. If you cant get the Ultragauge set up, just drive the vehicle about 100 miles. Also if you go to autozone they dont mind throwing an scanner on it to check readiness.
  5. Jun 12, 2021 at 11:37 AM
    thetoyotaman
    Sorry, LA=Louisiana. We disconnected the battery back in April to install the trailer harness. Battery was replaced March of last year.
  6. Jun 12, 2021 at 12:57 PM
    texbaz
    "Buffalo Creek" TX
    Ok, that means since April, the truck has been driven in or around 100 miles. Or has it just sat?
  7. Jun 12, 2021 at 1:04 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    When he goes for the test do not shut the truck off. Leave it idling in the parking lot while waiting for the test. The engine has to be hot
    Kev250R likes this.
  8. Jun 12, 2021 at 1:10 PM
    texbaz
    "Buffalo Creek" TX
    Like I said before, need to see what service,or services are not coming up as ready.Also, If the truck has never been through a complete drive cycle your required amount of services may not display as ready,even though the battery was disconnected more than a month ago.
  9. Jun 12, 2021 at 1:16 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Emissions not ready just means he needs to put more miles on it. Whenever the battery gets disconnected or a code gets erased it resets the emissions monitors. Takes a certain amount of driving and driving conditions for them to be ready again
    MGMDesertTaco likes this.
  10. Jun 12, 2021 at 1:21 PM
    texbaz
    "Buffalo Creek" TX
    "What does it mean for a vehicle to be “Not-Ready”? “Not Ready” failures imply that a vehicle’s readiness monitors have not been fully reset. The onboard computer resets anytime there is an uncommon electrical event within the car. The most common causes are removing the battery cables, jumpstarting another vehicle, adding out-of-market electrical equipment to the vehicle, and clearing DTCs from the computer. When the onboard computer has been reset, the vehicle must be driven in a certain manner determined by the manufacturer, called a ‘drive cycle’. This drive pattern usually involves a normal combination of city and highway driving for about two weeks. Contact your vehicle’s manufacturer or LDEQ for specific drive cycles. There may be nothing wrong with your vehicle. After completing the drive cycle, return the vehicle to the motor vehicle inspection station for a retest"
    Here is the Link:
    https://www.deq.louisiana.gov/faq/category/18#175
  11. Jun 12, 2021 at 1:27 PM
    texbaz
    "Buffalo Creek" TX
    I read this again, Is the emission tester not able to communicate to retrieve the data?
    "Vehicles that fail due to non-communication fail because the vehicle’s onboard computer did not send a signal to the emissions testing equipment. Occasionally, a vehicle can come off of the assembly line with defects. A non-communication can be the result of a poorly assembled OBD connection port, a blown fuse, or a combination of scenarios involving the inspection process. Check the vehicle’s cigarette lighter to see if it works. If it does not, chances are the fuse is blown. Most manufacturers design vehicles so that the OBD and cigarette lighter run on the same circuit. The fuse is faulty if it is dark inside like the inside of a blown light bulb or if the electrical wires within the fuse are burnt apart and are not connected. In the event of a ”non-comm”, the motorist is instructed to contact the Emissions Challenge Station, where the vehicle will be retested and, if necessary, receive a separate diagnostic scan."
  12. Jun 12, 2021 at 4:17 PM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Drive truck moar!
  13. Jun 13, 2021 at 6:16 AM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    I have not checked readiness with Ultragauge. I did take a quick look and did not see it. I will try to find the Ultragauge info on how to get to it.
  14. Jun 23, 2021 at 9:34 PM
    thetoyotaman
    Thanks for the replys. It was actually driven to Mississippi and to the coast besides stop and go when it had failed. He bought a OBDII code reader with the I/M Readiness. Checked again on Monday and finally the cat and heated o2 were ready. Once everything is ready does it stay ready or do these 2 have to be hot every time it's started to clear?
    The other day the ABS light came on during one drive but has not returned :(
  15. Jun 23, 2021 at 9:54 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Truck has too be too temp. During the test.
    thetoyotaman[OP] likes this.
