failed frame safe?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wdirkin, Oct 23, 2014.
  1. Oct 23, 2014 at 2:32 PM
    wdirkin
    wdirkin [OP] Member
    Wil
    Mt Misery, NJ
    2006 tacoma 4dr
    My 2006 4 door Tacoma failed it's frame inspection the other day. I have a 4+ inch by 3+ inch hole on the inside driver's side by the cat, with a 1 inch by 3 inch hole on the bottom of the frame below it. I'm concerned about driving it for the month and a half that it will take for the replacement to come in. The tech said he'd seen worse. Should I go back and demand a rental?
  2. Oct 23, 2014 at 2:37 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That's amazing they'd let you drive it after 'failing' it.
    Did you talk to a Manager?
    I'd demand a rental. Unless they plan to pay for everything if the frame breaks causing an accident and totaling the truck.
  3. Oct 23, 2014 at 2:41 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  4. Oct 23, 2014 at 2:45 PM
    Ianp05
    Ianp05 Well-Known Member
    IAN
    DETROIT
    2006 Double Cab 4x4 TRD Sport
    absolutely demand a rental!
    bummer to hear. My 4door 2006 is being inspected monday. what did they do for you? Order a new frame or just a partial fix?
  5. Oct 23, 2014 at 2:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Trucks done.
  6. Oct 23, 2014 at 2:57 PM
    T4RFTMFW
    If they refuse a rental, get it in writing that your frame that failed is safe to drive and why. So if it snaps on the freeway and you survive you can retire early with a pile of money to wipe with.
  7. Oct 23, 2014 at 3:04 PM
    wdirkin
    wdirkin [OP] Member
    Wil
    Mt Misery, NJ
    2006 tacoma 4dr
    Total new frame, leaf springs and control arms. Going to be a month and a half.
  8. Oct 23, 2014 at 3:14 PM
    CelsisTaco
    CelsisTaco Well-Known Member
    Anthony
    Des Monies, IA
    2011 DCSB
    2 inch lift. LED fog lights (Cali fab) Alpine head unit. Kicker door speakers. Skar subwoofer.
    Cut/weld in a new piece of metal?
  9. Oct 23, 2014 at 3:22 PM
    Janster
    Jandy
    Lancaster, PA
    You need a good frame to weld to.....
  10. Oct 23, 2014 at 6:03 PM
    Supramacy
    Supramacy Well-Known Member
    That's quite the liability letting you leave with a damaged frame like that.
  11. Oct 24, 2014 at 5:29 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Demand a rental.
    Can't believe they let you drive away with it like that. You would think that since they failed it, they wouldn't let you drive it away.
  12. Oct 24, 2014 at 5:40 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    You should not drive that truck. Although mine looked just as bad and I was driving it until the muffler rotted off and the repair shop told me.
  13. Oct 24, 2014 at 12:55 PM
    wdirkin
    wdirkin [OP] Member
    Wil
    Mt Misery, NJ
    2006 tacoma 4dr
    I called and they are setting my up with a rental on Monday. Thanks.
