Failed Inspection 12-6 action
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bowhunter74, Oct 21, 2022.
  1. Oct 21, 2022 at 9:49 AM
    Bowhunter74
    Bowhunter74 [OP] Well-Known Member
    Just failed my inspection due to some slight play in the front driver's side wheel when rocking at 12-6. Last year, I replaced lower control arms, shocks, and stabilizers.
    Should the first repair be UCA ball joints? Before getting into anything else?
    Thanks.
  2. Oct 21, 2022 at 10:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    Miles on vehicle? Any noises from that area? Last alignment was how long ago?
  3. Oct 21, 2022 at 10:07 AM
    Bowhunter74
    162k. There's some wobble from that wheel when driving. I first thought it was a bearing issue, but the 12-6 play seems more ball joint, right? Alignment was a year ago when I did all the rest of the suspension work.
  4. Oct 21, 2022 at 10:12 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Can you take it back to the alignment guys and tell them you failed ? That’s something they should have caught.
  5. Oct 21, 2022 at 10:20 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Get you a helper, jack up the front end, one of you move the wheel and the other can look to see what's loose.
    AllTacosFloat, SR-71A, b_r_o and 2 others like this.
  6. Oct 21, 2022 at 10:24 AM
    Bowhunter74
    I feel a year is a pretty long time for things to fail.
    50Buck and SR-71A like this.
  7. Oct 21, 2022 at 10:29 AM
    spitdog
    What does this mean?
  8. Oct 21, 2022 at 10:32 AM
    Bowhunter74
    That in a year things are bound to fail that aren't on the hands of alignment tech. It wasn't an issue until relatively recently. The alignment was a good year ago, at least.
    50Buck, SR-71A, spitdog and 1 other person like this.
  9. Oct 21, 2022 at 10:36 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    ^^^ Listen to these guys, they know whats up. Helps to have a big prybar to gently persuade things and see what moves.
    If there is play in the 12-6 direction but not the 9-3 direction and no noise from the hub bearing then yeah might be a ball joint. Easy to check and confirm.
    Dm93[QUOTED] likes this.
  10. Oct 21, 2022 at 11:08 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Was it a shop that does automotive repairs that did the inspection?
    If so, you should have asked them for a quote on fixing it.
    Then you’ll know.
    It’s kind of “jerk” thing to do.
    But they failed you. So at least you’ll know why it failed.
  11. Oct 21, 2022 at 11:10 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's not the time to figure out who to blame, it's time to figure out what's loose. Get under there and look
    wi_taco and Dm93 like this.
  12. Oct 21, 2022 at 11:16 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Not really.. They failed him, they should know why. Every shop Ive ever gotten an inspection at would at least tell me over the phone what failed, if not offer a writeup when I paid the inspection fee.
    spitdog and AllTacosFloat like this.
  13. Oct 21, 2022 at 11:19 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    They probably don't know what's bad. That's why they didn't offer an explanation
    TnShooter and spitdog like this.
  14. Oct 21, 2022 at 1:29 PM
    TnShooter
    Deogee
    STOCK
    I can see it from both side.
    From a techs prospective, If there is excessive play, it excessive.
    Kind of like seeing a coolant leak. It’s a leak. It’s obvious. There a problem.
    It could be caused by more than one thing. And figuring it out takes time. Time which the tech wants paid for.
    So I can understand why they didn’t investigate further.
    From the vehicle owners prospective.
    I’d like to know what is causing me to fail the inspection. Not necessarily why I failed.
    Basically, it comes down to how a shop runs their business. Personally, if I owned a shop, I’d tell them what I felt the cause of the problem. I’d likely get more business this way by getting the job.
    I mean, there isn’t much money being made by tell someone “You failed inspection, sorry” and sending them on their way.
    SR-71A[QUOTED], b_r_o and Dm93 like this.
  15. Oct 21, 2022 at 2:28 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Don't forget to check the wheel bearings. In my experience, anything over 100,000 miles in a Tacoma and you're on borrowed time. If it is a wheel bearing, replace them both. Like everyone else has said though. Jack it up and start wiggling before throwing parts at it.
  16. Oct 21, 2022 at 2:52 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Inspection? Glad we don’t have to go through that anymore. Had an 86 Chevy way back when and it passed emission’s then failed it cause the catalytic converters were missing. Idiots.
    PMK likes this.
