Failed My Emission test
Discussion in '1st Gen. Tacomas (1995-2004)' started by gmata, Nov 30, 2009.
  1. Dec 2, 2009 at 5:33 PM
    gmata
    gmata [OP] Well-Known Member
    Gonzalo
    Delaware
    2007 DCB 4x4 TRD sport
    They will missfire only after 20 miles of use?
    Oh man i wish i would've known that before i spent 30 dlls on this plugs.
    Is this a 100% fact that Bosh plugs will missfire?
    Thanks
  2. Dec 2, 2009 at 5:37 PM
    98tacoma27
    Ben
    Not Beech Creek
  3. Dec 2, 2009 at 9:14 PM
    gmata
    Gonzalo
    Delaware
    So i was thinking, if its the sparkplugs and i replaced them all today, why do i still get Missfire on Cylinder #1 the same Cylinder i was getting before i changed the Sparkplugs , I also get Random/Multiple Missfire.
  4. Dec 3, 2009 at 7:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    What he said..................exactly.
  5. Dec 3, 2009 at 8:22 AM
    gmata
    Gonzalo
    Delaware
    Thanks Guys, i will do that today, and keep you guys posted. Thanks for all the help so far!
  6. Dec 3, 2009 at 8:26 AM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    Really? That's pretty cool. Don't let any California users read that, those guys can't even install a CAI.
  7. Dec 3, 2009 at 8:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    We don't have them in my county in PA either................:anonymous:
  8. Dec 3, 2009 at 8:53 AM
    AzPrerunner05
    Tucson
    It's relatively lax here, although the OP of this thread is from Tucson too. New vehicles don't have to test, I've done emissions once in this state, the last year I owned my Camaro. Also, after 25 years you can get the Historic plate and be EXEMPT from emissions. :eek:
  9. Dec 3, 2009 at 9:03 AM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    I literally have to go back to stock to pass emissions unless i want to pony up for airaid which is legal:eek:
  10. Dec 3, 2009 at 4:32 PM
    gmata
    Gonzalo
    Delaware
    I went to buy the Denso Sparkplugs at the Toyota dealership, then i went to the auto hobby shop at the Air force base and installed all 6 plugs. I reseted the codes.
    1.6 miles later after reset the Check Engine Light comes back on. I checked it instantly wit the Scanner, i got P0301 twice, I plugged the scanner again when i got home 15 miles later, and i had again P0301 X2 and P0300, the same codes!
    What is next Wires????
  11. Dec 3, 2009 at 5:01 PM
    gmata
    Gonzalo
    Delaware
    Yes sparkplugs from the dealer where 2 electrodes, I am going to try replacing the Wires since my truck has 136,000 miles and I honestly don't know if the last owner ever replaced them.
  12. Dec 4, 2009 at 6:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2. No autolite!!!!!
  13. Dec 4, 2009 at 9:28 AM
    gmata
    Gonzalo
    Delaware
  14. Dec 4, 2009 at 9:50 AM
    gmata
    Gonzalo
    Delaware
    In case is not the wires, i am going to replace the coil for #1 Cylinder as last resort.
    Any of this good? or do i need to buy the Original Toyota for $94.60
    Thanks
  15. Dec 4, 2009 at 1:57 PM
    #35
    gmata
    Gonzalo
    Delaware
    So, what is the answer, get the coil from Toyota or get it from Amazon? at Half price?
  16. Dec 4, 2009 at 2:25 PM
    #36
    gmata
    Gonzalo
    Delaware
    Thanks guys i will try that.
  17. Dec 4, 2009 at 2:48 PM
    #37
    gmata
    Gonzalo
    Delaware
    What do you guyks think if i switch coil packs, from number 1 to numer 2 for example and see if i get a different Code maybe missfire Cylinder #2 this way i would know for sure it is the Coil pack right???
    Thanks
  18. Dec 4, 2009 at 4:00 PM
    #38
    98tacoma27
    Ben
    Not Beech Creek
    yes it would. you can do that.
  19. Dec 4, 2009 at 4:05 PM
    #39
    gmata
    Gonzalo
    Delaware
    I, will try that, then wires when they get here on tuesday, then compression test, i read on another forum that a compression test would be a good idea, some guy had a bad Valve.
    Wish me luck!!!
  20. Dec 4, 2009 at 4:08 PM
    #40
    98tacoma27
    Ben
    Not Beech Creek
    Luck wished!
