Failed Sliders - Discuss
Discussion in 'Technical Chat' started by HBMurphy, Sep 22, 2013.
  1. Sep 22, 2013 at 9:16 PM
    #41
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    2" .250 wall next time!
  2. Sep 22, 2013 at 10:07 PM
    #42
    HBMurphy
    HBMurphy [OP] Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I hope not. Time for someone to post up some other manufacturer's sliders and similar 'dents.' :eek:
  3. Sep 22, 2013 at 11:41 PM
    #43
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    I would love the opportunity to speak to the owner so I can hear the story and see the pictures. I would appreciate it if you could ask the owner to contact me.
    Thanks,
    Tracy Bundrant
    tracy@allprooffroad.com
  4. Sep 22, 2013 at 11:48 PM
    #44
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I sent word to the owner...
  5. Sep 23, 2013 at 12:06 AM
    #45
    Bones2Blood002
    Bones2Blood002 Well-Known Member
    SoCal
    10 Offroad on the build
    Sliders, Old man emu lift with aal in the rear, tc uca, relentless front and rear bumpers, ato skid plates
    So that's my truck the allpro sliders are on. It was the rubicon trail that did that damage. I am not sure where along the trail it happened. The pic was on big sluice at a pretty common obstacle. The other taco that came with me had another companies sliders, which very little kick out. He took a big door hit because of it. As I said on Facebook, I use a lot of little pedal. My door did not take any damage where the slider was bent so...... That being said I will carefully look at the reinforcing on the next set of sliders I get. My friend has already told me to just cut out that section and weld another piece in. Not sure if I feel safe doing that. Will the section be able to take a hit like that and hold up as well? The rubicon trail is a beast. Nothing aside from the hammers has compared to it. Sure short sections of other trails are as hard. But rubicon is 18 miles of hard. I must say that I was surprised to see my pics here.:eek:
  6. Sep 23, 2013 at 5:39 AM
    #46
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    vvvvvvv
    I'm glad you are being realistic about the situation. most people would be freakign out /pissed off, when in reality, a couple feet of tube is a ton cheaper than a new door panel, or the repairing of a bent or punched through frame.
    with good welds and materials, you would be fine cutting out the bad section and welding in a new piece. and like i stated earlier in the thread, that is a very inexpensive operation if you have the means to do it yourself.
    I would think about adding another leg or two, or even just some 90* gussets at the outer corners of the legs.
    I don't have any bends or warps, but my DOM 4x-innovations are full of golf-ball diameter dents on the bottom of the tubing. nothing to compromise the structural integrity to the point of having to replace a section though. sliders, like skid plates, are a wear item. if you wheel long and hard enough, you're "wear" them out. with skids, you may bend it to the point that it is touching a component it shouldn't, or warp them to the point that you can't even get them back on. with sliders you may eventially get a structurally compromising bend or dent. all you have to do is make the decision to either replace or repait, based on the severity and your fabrications skills.
  7. Sep 23, 2013 at 6:00 AM
    #47
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    It's a pretty significant dent on that tube...I'm pretty surprised the owner doesn't know where it happened
    I dont know of any company that makes a slider that is reinforced well enough to prevent something like this...its tube and you can only have so many legs and gussets...
    I would also be interested in knowing if sliders built out of a different tube HREW v DOM wouldve faired differently
    You know whats awesome though? The owner has someone from the company requesting his contact...which is top notch
  8. Sep 23, 2013 at 6:20 AM
    #48
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Short of Demello's rock crushers, I'm not sure if another company's sliders would have made it out without taking a little deformation although some other companies do have more legs to reinforce the outter tube.
  9. Sep 23, 2013 at 7:46 AM
    #49
    HBMurphy
    Paul
    So California Coast
    None
    A great opportunity for both parties - A/P and OP. Now let's see others with similar damage. They must be out there. Where are they? :)
  10. Sep 23, 2013 at 8:17 AM
    #50
    Bones2Blood002
    SoCal
  11. Sep 23, 2013 at 9:07 AM
    #51
    allpro
    Montana
    Thanks! Much appreciated!!
    Tracy
  12. Sep 23, 2013 at 9:09 AM
    #52
    allpro
    Montana
    I sent you a private message.
    Thanks for getting back to me.
    Tracy Bundrant
  13. Sep 23, 2013 at 9:12 AM
    #53
    Manwithoutaplan
    ID
  14. Sep 23, 2013 at 9:18 AM
    #54
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    That took a hell of a hit to cause that bend and where it was located on the slider that would of happened to just about any slider. That said they did their job protecting the truck so I wouldn't say that's a slider failure as the OP said. Those sliders can be fixed and cheaper then new sliders. For about an hour of shop time and a little tube they can be good as new and ready to wheel.
    To do so cut the bad section out & sleeve the tube with a OD tube that fits inside about 6" to 8" long, Grind the sliders cut ends to 45 degrees to get a full pen weld and burn them in. I would add another support in that section where they bent but you could fix those no problem. If you did all the prep work and had them ready to weld I couldn't see this job costing more then $50.00 bucks if you took it to a shop to weld.
  15. Sep 23, 2013 at 3:02 PM
    #55
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    I would say the sliders did their job very well. No damage to the cab of the truck means they did awesome. It had to take a VERY big hit to the sliders for that to happen.
