Failed steering rack. Should I rebuild?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Oct 11, 2020.
  1. Oct 11, 2020 at 3:21 PM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    After some offroading yesterday, I noticed power steering fluid pouring out of my inner tie rod boot. Should I rebuild the rack, or get a new/reman one??
  2. Oct 11, 2020 at 3:25 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Going through all that work I’d prefer a “Toyota” rack assembly going back in
    Freeheelbillie and TnShooter like this.
  3. Oct 11, 2020 at 3:26 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Is changing the rack that bad?
  4. Oct 11, 2020 at 3:28 PM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    It’s just time consuming and putting one back in that’s rebuilt... just not my thing. I’d rather not do it twice especially if it’s your DD.
    Chris(NJ), $yoda$ and TnShooter like this.
  5. Oct 11, 2020 at 3:42 PM
    Muddinfun
    Muddinfun Well-Known Member
    Prerunner or a 4wd with a drop bracket lift is not to bad. A 4wd without a drop bracket lift is a bitch.
    Torspd, Too Stroked and TnShooter like this.
  6. Oct 11, 2020 at 3:45 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Cool, just a 4wd with a 3" lift. Oh well, I'm sure I've done worse jobs on this truck.
  7. Oct 11, 2020 at 3:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  8. Oct 11, 2020 at 4:39 PM
    JeffBoyardee
    Jeff
    Seminole, FL
  9. Oct 11, 2020 at 5:00 PM
    TnShooter
    Deogee
    STOCK
    Not really, I haven’t had to R/R one on a Tacoma yet.
    The last one I had was involved with was on a Lexus car.
    I know the job itself sucks, and OEM is Expensive.
    I’ve had pretty good luck with Napa parts.
    And I’d probably look at them if I were not going OEM.
    And that’s only my opinion, based on my luck with their parts.
    I honestly don’t know what to tell you.
    Pick one and hope it works?
  10. Oct 11, 2020 at 5:03 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Just be careful with "recommendations." Lots of folks recommend something that replaced an OEM part with 100,000 miles on it after some ridiculously short period of time. I only listen to folks who've put serious miles on something.
    TnShooter likes this.
  11. Oct 11, 2020 at 5:05 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    yes, always with a grain of salt. I tend to take recommendations seriously only when there's an overwhelming lean towards one mfg. I'm thinking no matter which way I go it's going to be a crapshoot, because I'm not spending OEM money.
  12. Oct 11, 2020 at 5:06 PM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    I haven’t seen a replacement Toyota oem rack fail....
  13. Oct 11, 2020 at 5:11 PM
    Too Stroked
    Tom
    All parts fail - eventually. Even OEM Toyota parts fail eventually. One needs to look at percentages and longevity here.
    ovrlndkull likes this.
  14. Oct 11, 2020 at 5:14 PM
    TnShooter
    Deogee
    STOCK
    I agree, especially with a job like this.
    Unfortunately, sometimes in life we can’t afford OEM.
    When this happens, it like OP said. “It a crap shoot”.
    All you can do is pick one, then Hope and Pray it works.
  15. Oct 11, 2020 at 5:14 PM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Guess depends how long op wants to keep his truck and how often he beats it in the trail...
  16. Oct 11, 2020 at 5:25 PM
    Too Stroked
    Tom
    Oh I hear ya, and fully understand and agree. I work in a Toyota dealership and get to see OEM parts fail every single day. I also get to see aftermarket junk that somebody "saved money on" get replaced with OEM stuff after the aftermarket part failed in short order. I'm just cautioning the OP (and everybody else) on the dangers of buying parts purely based on price.
    Now a qualifier. If it's something like a gas cap, there's little risk (and cost) involved if an aftermarket part fails. If it actually works, life is good. With a Steering Rack though - especially one that's a PITA to install like the Tacoma 4x4 one is - one should be extra carful. This is especially true if you're paying somebody else to install it. If it goes bad within the warranty period, they'll only replace the part. They won't pay for the labor - which is significant.
    Like they always say, buy once, cry once.
    Torspd likes this.
  17. Oct 11, 2020 at 5:28 PM
    Too Stroked
    Tom
    BTW, if I were to pick my worst and best aftermarket brands, NAPA would be on top and Dorman would be on the bottom.
    Larzzzz likes this.
  18. Oct 11, 2020 at 5:31 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    No don't flip them on reinstall that's just as dumb as flipping the UCA bolts. If the nut ever comes off the bolt is dropping out of the rack and it will no longer be attached to the truck. At least with them in the stock orientation if the nuts come off the rack will shift around some but not be completely useless and you can get off the road safely.
    I have one of the cardone new racks not the reman and it's been holding up to my abuse for a year now. DD and wheeling on 35s now. I blew up my stock one wheeling too. Now I have a tundra modified rack from Basikbiker that I need to install. The job really isn't that hard. If it weren't for a stubborn and rust seized intermediate shaft on the rack I would of had it done in 3 hrs. It just takes a little patience and finesse getting the DS bolt out and then fishing it out of it's home.
    TnShooter[QUOTED] likes this.
  19. Oct 11, 2020 at 5:33 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Dorman makes a lot of the stuff that is rebranded NAPA, belts and hoses are gates, filters are wix, etc. Lots of house brands are like that made by another actual manufacturing company and just rebranded.
  20. Oct 11, 2020 at 5:37 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Changing a rack is no biggie, cut the driver side bolt out and it will wiggle right out. Just pay attention to the steering spline shaft when reinstalling
    Torspd and TnShooter like this.
