Failed VA safety insp, no airbag light. Need Airbag SRS module, but it's discontinued
Discussion in '1st Gen. Tacomas (1995-2004)' started by kee much, Oct 28, 2014.
  1. Oct 28, 2014 at 12:53 PM
    kee much
    kee much [OP] New Member
    My head is spinning on this one, I joined this forum to see if anyone has ideas. Failed in VA for
    • If the air bag indicator fails to light or stays on continuously.
    My trusted mechanic bypassed the module and it is not the bulb nor the fuse. He said I need a new module, which is not made, nor does anyone have any in stock. I went back to the inspector and he said he won't pass it.
    I'm at a loss, the inspector actually told me I may need to total this 1995 Tacoma with <100k, that runs absolutely perfectly, minus an airbag light that won't light up.
  2. Oct 28, 2014 at 12:58 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    You could always get one from a newer first gen.
  3. Oct 28, 2014 at 2:06 PM
    hutch84
    hutch84 Whitewater Dreamin'
    Jeremy
    Blacksburg, VA
    2000 Tacoma SR5 & 2017 Tacoma SR5 (stock)
    5100 w/881's @ 0", OME Dakars, OME greaseable shackles, blinker mod......321K and still kickin'
    Ask around and find a inspector that is not a hard ass. Good luck!
  4. Oct 28, 2014 at 2:07 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Salvage yard?
  5. Oct 28, 2014 at 8:01 PM
    SilverTaco04
    SilverTaco04 New Member
  6. Oct 29, 2014 at 4:21 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Most airbag inflators have a ohm rating of 2.2 or 2.4 so if you could remove the steering wheel and remove the connector to the airbag unit, you can solder a resistor to the connector and bypass the airbag. Your airbag unit will no longer work but the light should work like the airbag is good.;)
  7. Oct 29, 2014 at 4:36 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    check with Jimmy Bowers used auto parts 828/67o-II66 he go what i needed to rebuild my 96 wheel and air bag,i think he is in South Carolina.
  8. Oct 29, 2014 at 4:42 AM
    Bamo
    Bamo Well-Known Member
    Barry
    North Port, FL
    09 Regular Cab 4x4
    This is why I love this forum.
  9. Oct 29, 2014 at 4:43 AM
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    This is actually a good idea. You already knew the module was bad anyway. If you do a 'fix' like this though, be sure to disclose it if you ever sell (I've had a buyer sign a discloser letter before, and I keep it on file just in case).
  10. Oct 29, 2014 at 5:17 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    WARNING!!!!!!!
    I forgot to add this, DO NOT.......DO NOT try to read the ohms across the airbag inflator itself. It requires only a tiny amount of voltage/amps to set the airbag off. It will deploy and injury and burns will occur.
  11. Oct 29, 2014 at 11:02 PM
    arigoni24
    arigoni24 Well-Known Member
    Tyler
    Holloway Ohio
    2003 Tacoma Extracab SR5 4x4
    Grey wire mod, 3 inch level/lift kit from Truxx, 3 inch body lift, 285-70-17 (33's) on pro comp xtremes, custom rear tube bumper, cold air intake by Spectra, corner turn signal mod/ fog light where old turn signals were, hid headlights by vvme, smoke headlights and taillights by spyder, flow master muffler, tinted windows, red led turn signals and brake lights, brushguard and taillight guards yet to put on, MORE TO COME: relocate rear diff breather, black front bumper filler, shackles on front end, IF ANYONE HAS ANYMORE IDEAS PLEASE LET ME KNOW!
  12. Oct 30, 2014 at 8:06 AM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    Have you chatted with a Toyota dealer? No way you would total a perfectly good working truck due to an SRS fault. I bet many states would not even check that. SRS modules need to be replaced over time, so there must be a replacement for it. Go to the dealer, they will have an answer.
    If you start mucking around with the system like reading resistance or bypassing with resistors and all that, you better have that unit out of the truck, on a bench, and know what you are doing, or you will wind up deploying it and have more problems on your hands.
