Failing leafs or Tacoma lean?
Discussion in '5 Lug' started by Rola2010, Nov 4, 2020.
  1. Nov 4, 2020 at 12:07 PM
    Rola2010
    Rola2010 [OP] Well-Known Member
    Honolulu, HI
    2010 Tacoma 2wd base RC
    My truck: 2010 reg cab, X Runner leafs, 2” tapered lowering block, QA1s
    I took a measurement today and find the rear driver side is 1” lower than the passenger side (axle to fender). Is this typical Tacoma lean or is the leaf spring failing?
    Gunshot-6A likes this.
  2. Nov 4, 2020 at 12:11 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Do you have a sway bar front or rear? How much fuel is in the tank? With sway bar removed, 1" is within the margin of error for Taco Lean on the two 6-luggers I've owned. :notsure:
  3. Nov 4, 2020 at 12:11 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Prob a little of both to be honest. Original leafs?
  4. Nov 4, 2020 at 1:39 PM
    Rola2010
    Honolulu, HI
    Thanks for the input; I have a full tank, and the leafs were switched probably around 4 years ago. I’ll continue to watch it and see if it gets better or worse as we go.
