Failing Torque Converter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chandler1215, Nov 18, 2019.
  1. Nov 18, 2019 at 7:04 PM
    reloader403
    reloader403 Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    Go to another dealer and have the trans flushed with the WS spec fluid that should be in the trans. I have it done every 30k for situations like this. If you hit up the 4r forum and look up 3rd gen 4r TC slipping or shudder you'll see a WS fluid flush clears it up pretty well. Assuming your TC isn't completely shelling out I think you'd be surprised. It's the only thing worth taking a Toyota to the dealer for service wise imo. I feel for you man, like others have said you can find a low mileage trans much cheaper than 5200....
    Big tall dave and SandyTaco4x4 like this.
  2. Nov 18, 2019 at 7:06 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Take it to independent transmission shop.... screw the dealer
  3. Nov 18, 2019 at 7:10 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Replace the torque converter, then trade the truck
    rmazhi, =JSG= and boston23 like this.
  4. Nov 18, 2019 at 7:14 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    mine started shuttering this past week, but it’s not consistent.
    I just ordered 6qt of fluid and a new filter. Going to flush it the best I can. Hoping that clears it up.
    I’ve been running the t-stat pinned for the last 2.5yrs; so heat had never been an issue. Unless the trans running at 145-150*F is a bad thing?
    it all else fails, guess I’ll be putting my shitty third party warranty to the test.
  5. Nov 18, 2019 at 7:22 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Realistically what i would do
    rmazhi and The hammer[QUOTED] like this.
  6. Nov 18, 2019 at 7:22 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Why would you do this? You don’t think they designed the coolant system to keep the engine and transmission at the correct temperature? It just seems that if 150° was a better temp to run at and pinning open the thermostat was the easy solution, why wouldn’t they have just designed it that way? Makes you wonder if there’s something more to it than that.
    Lt. Dangle likes this.
  7. Nov 18, 2019 at 7:28 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    otherwise it runs 195-205 constantly. Too hot for the trans IMO. That significantly cuts down on the life of the fluid.
    I’ve never heard of a transmission failing because it ran too cool.
  8. Nov 18, 2019 at 7:31 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
  9. Nov 18, 2019 at 7:31 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Call Toyota corporate. A lot of cars (especially Camry’s and ravs) are having issues with torque converter shudder. Coolant is getting into the transmission fluid. A new torque converter and a new transmission cooler puck would make the problem disappear, they have a warranty enhancement on the camrys and ravs. So if you call and complain there’s a good chance they’ll help you out
  10. Nov 18, 2019 at 7:34 PM
    Bishop84
    Bishop84 Well-Known Member
    Flushes don't fix torque converter shudders on Toyota. We tried it many times, never works.
    thewarriordinghy and The hammer like this.
  11. Nov 18, 2019 at 7:35 PM
    Empty_Lord
    Dan
    I’ve had it work sometimes. But the problem comes back in a matter of 10-20k miles.
  12. Nov 18, 2019 at 7:37 PM
    Black Magic 2003
    Black Magic 2003 Well-Known Member
    Edwin
    Mass
    19 Tacoma TRD Pro Double Cab
    Well, for me folks, as a guy whose on his 6th Tacoma and replaced my torque converter on my 2000 Tacoma, my mechanic always told me it was the fuel. You can not use regular gas. It does damaged to the cat. He always told me, so be so friggin cheap. Put super in the tank so I have been using super for the last 15 years in my trucks.
  13. Nov 18, 2019 at 7:39 PM
    Empty_Lord
    Dan
    here is the TSB on the camrys. we replace the Torque converters and Reflash the ECU. Coolant contamination is tested with a tool and if its found the cooler needs to be replaced. (even though its on the customer dime, why i dont know)
    https://static.nhtsa.gov/odi/tsbs/2017/MC-10146516-9999.pdf
  14. Nov 18, 2019 at 7:41 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Might (or might not) be relevant here. My 2007 FJ started shuddering right around the 60k warranty mark. It got pretty bad and it didn't matter which gear: Low load, moderate throttle, and ~1800 rpm would do it. Take it out of OD and no issues whatsoever. I think ultimately there was a TSB and replacements for others. Apparently it would get to where it didn't know whether to lock up or not and vacillated between the two at high frequency. I replaced all the fluids once and it seemed to get better for a bit. I stopped worrying about it somewhere around 100,000 miles. I then put another 90,000 miles on it. My subconscious brain and right foot just learned to give it a touch more gas (or less) whenever it started to shudder.
  15. Nov 18, 2019 at 7:42 PM
    #35
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    so once it starts, best to start looking for a new converter or a whole transmission then?
    LKQ has them for ~$1300 but damn, they should last more than 100k miles. Thought Toyota’s were know for reliability :crazy:
    SandyTaco4x4 likes this.
  16. Nov 18, 2019 at 7:44 PM
    #36
    reloader403
    Acworth, GA
    While heat is a major factor in fluid life, Toyota has designed their vehicles system to run certain temps, I use to stress out about how hot my truck was running with a trailer but after some research I just let it go and pay for a flush every 30k.
    GoldenBrew likes this.
  17. Nov 18, 2019 at 7:47 PM
    #37
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’m gonna pull the pin I believe. Reserve that for trail days in the summer and towing. Although I haven’t seen any adverse effects until now, but I think the fluid is probably shot and needs to be flushed.
  18. Nov 18, 2019 at 7:47 PM
    #38
    Itchyfeet
    Itchyfeet Well-Known Member
    I know on the older Honda Accords this was kind of a big no. The converter will never lock up if the trans ECU doesn't see the correct temp.
  19. Nov 18, 2019 at 8:18 PM
    #39
    chandler1215
    chandler1215 [OP] Well-Known Member
    2016 Black Tacoma TRD Off Road DC
    Waiting to see what toyota says tomorrow morning. Still highly doubtful they offer to help out in anyway so I’m making an appointment with a local reputable transmission shop and hoping for something reasonable. I was prepared to spend about 3 grand if needed today at Toyota to have it fixed but when they quoted 8 for the trans and labor it blew me away. Hoping for the best tomorrow, I’m just ready to have my baby fixed
    Big tall dave likes this.
  20. Nov 18, 2019 at 8:33 PM
    #40
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    By cooler you mean the radiator? How else does coolant get into the ATF?
