Failing Torque Converter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by auapaul, Jan 20, 2021.
  1. Jan 20, 2021 at 4:47 AM
    auapaul
    auapaul [OP] Member
    Hi everyone,
    Has anyone had to deal with a failing torque converter in their 3rd gen yet? I have a friend who's truck has a hesitation (almost a stumble) when at steady throttle and in almost all gears. It begins at around 20mph, resembling a torque converter going in and out of lock up. The truck has 79k miles on it and has been well maintained.
    The dealership has performed both TSB's 005818 and 006218. They told him that this will be the 10th T/C in a year they have replaced.
    Any other experience would be appreciated.
    MOC221_ likes this.
  2. Jan 20, 2021 at 4:57 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Your friend needs to monitor the proper PIDS and actually see what's going on.
    BTW there's plenty of reports of stuttering/shuddering/hesitations under load on TW. FWIW, some manual trans trucks do it to (like both 3rd gens I've owned).. so it may not be the transmission at all. Heck, it probably isn't a hardware problem, but rather factory tuning (ECM calibration).
  3. Jan 20, 2021 at 5:02 AM
    auapaul
    auapaul [OP] Member
    What PIDS would you recommend?
  4. Jan 20, 2021 at 5:05 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Low on ATF? I would hope the dealer would check that, but maybe not
    Big tall dave likes this.
  5. Jan 20, 2021 at 5:14 AM
    MOC221_
    Frank
    I've used Techstream and OBD Fusion to monitor PIDS on my truck.. but since it's a M/T, well I don't know the exact answer. There is one for TC lockup AFAIK.
    A/T guys will chime in.
    Junkhead likes this.
  6. Jan 20, 2021 at 5:22 AM
    auapaul
    auapaul [OP] Member
    Thanks, T/C lock does not change when the stumble is present.
  7. Jan 20, 2021 at 5:33 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Does the truck have larger tires and stock gearing?
    Junkhead and Chew like this.
  8. Jan 20, 2021 at 5:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If the TC is locked and there's a stumble, it ain't the TC.
  9. Jan 20, 2021 at 5:38 AM
    auapaul
    auapaul [OP] Member
    Factory gearing and tire size.
  10. Jan 20, 2021 at 6:24 AM
    MOC221_
    Frank
    Did the owner buy this truck new, or did he pick it up recently with that mileage on it?
    In other words, are these symptoms new.. or is the truck new to your friend?
    Junkhead and tonered like this.
  11. Jan 20, 2021 at 6:51 AM
    auapaul
    auapaul [OP] Member
    Purchased new, symptoms started in the last few weeks.
    MOC221_[QUOTED] likes this.
  12. Jan 20, 2021 at 7:22 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Interesting, both of your trucks did that?
    My 18 has never done that, even on stock tune. I have always used 91 E0, maybe thats why?
  13. Jan 20, 2021 at 7:47 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I'm on the newest AT ecm factory calibration and have felt the same thing every once in a while. If you have felt it in an MT, I wonder if it's the switch between port and direct injection during light load situations. There's a cleaning cycle when stopped but the 2GR-FKS uses both mpi and gdi depending on load when traveling and switches between Atkinson and Otto cycles. Sounds like a blip during one or both of the switches...
    synaps3 and Kev250R like this.
  14. Jan 20, 2021 at 8:04 AM
    MOC221_
    Frank
    Ah ok..
  15. Jan 20, 2021 at 8:10 AM
    MOC221_
    Frank
    Yessir.
    Tuned or stock, both trucks.
    That's why it's difficult to convince some ppl that the stutter issue exists, because not all trucks do it.
    91 E0 here too, still does it.
    Lt. Dangle and Junkhead[QUOTED] like this.
  16. Jan 20, 2021 at 8:20 AM
    Tone_Barone
    Tone_Barone Member
    2016 Red TRD Sport 4x4
    Mine was replaced a year ago on my '16 sport AT 4x4 (stock everything, California 87 gas) with ~38k miles
    Was most noticable around 20mph turning to a slight incline. Haven't had any trouble since replacement.
  17. Jan 20, 2021 at 9:13 AM
    N5J_Taco
    N5J_Taco Well-Known Member
    Have they done a drain and fill with new fluid? I thought mine was doing funny stuff (slipping/hesitant) so I did a drain and fill twice with 6 quarts and my issues went away. I don't know if it will fix your friends transmission but worth a try. Search 3rd gen trans issues many have replaced fluid and fixed their issues.
  18. Jan 20, 2021 at 9:18 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    At 20mph you're nowhere near full lock...probably flex lockup/torque converter clutch.
    You need to monitor solenoid SLU or SLT...I forget which.
    Even then, it will only indicate a go/no-go condition...performance of hardware can degrade and never set off any bells or whistles.
  19. Jan 20, 2021 at 9:58 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Tell your friend to run a couple of tanks of premium and see what happens. My truck along with a lot of others has a low throttle/low load miss. 93 makes it right. Cheap and easy to test.
    58K on my AT to back it up.
    None of this is for the tranny obviously, but to eliminate another source of shudder that some trucks have.
  20. Jan 20, 2021 at 10:07 AM
    SR-71A
    Zack
    Southern Maine
    Which in turn would confirm fluid level, if done properly
